Old Oct 01, 2012, 08:08 PM
leadfeather is offline
Find More Posts by leadfeather
Winging it >
leadfeather's Avatar
Joined May 2006
Idea
Jump Jet, vectored thrust experiment; maiden flight success!
Here's what I've been working on this last little while. A VTOL jet configuration that may work with any flight control board, with no special programming required.
With my other VTOL projects I had noticed that the easiest flying was in what I called "fast hover" mode...fans tilted forward about 45 degrees. Now I want to see if I can take it one step further. I want to tilt the fans even further; but not all the way forward; and see if I can control the jet using just the fans to provide attitude control...no control surfaces.
In hover and fast hover it is flying as a quad copter; should be no big deal.
In forward flight there will be enough tilt left in the motors, and the motors are arranged so that the fans will still provide pitch control but it will not fly on the props any longer, most of the lift will be coming from the airframe in this mode. Roll inputs from the stick will cause a yaw which; due to the swept wing; should induce a roll. I'm hoping to be able to do loops and rolls but i will settle for controllable flight.
So in point form:
  • 4 fans
  • 1 servo to tilt the fans, tilt servo plugs into Rx with servo slower
  • no control surfaces or servos
  • no special programming, just the standard MultiWii ( or KK) quad. In the past, programming has always been the most difficult part of the project and I had to rely on cass3825 to do the required coding.
  • EPP airframe to get me through the learning curve.
  • no distinct transition point... I hope.
I'll be starting with 8x4.3 props, but if all goes well I may switch to something faster like a 7x6 prop later.
So far the build is coming out pretty light. This always helps whether hovering or flying on the wing.
leadfeather is offline Find More Posts by leadfeather
Old Oct 01, 2012, 10:32 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
I think it looks cool! The concept seams sound enough to me.
RCvertt is offline Find More Posts by RCvertt
Old Oct 03, 2012, 12:05 PM
Winging it >
Joined May 2006
If we take the concept a little further and raise the rear fans above the center of drag in forward flight, then we can maintain pitch control ( using fans only) with full forward tilt. Hmmm might have to think of a good looking air frame that could use this arrangement if this first experiment works out.
Old Oct 03, 2012, 12:52 PM
superchomper2003 is offline
Find More Posts by superchomper2003
Joined Sep 2012
saweet
superchomper2003 is offline Find More Posts by superchomper2003
Old Oct 03, 2012, 03:47 PM
rcrich is online now
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Cool idea
rcrich is online now Find More Posts by rcrich
Old Oct 03, 2012, 09:24 PM
Winging it >
Joined May 2006
I made a little progress tonight. The rest of the foam air frame is cut out and the power harness is made. It begins to be more fun when it starts to look like something that might fly.
Old Oct 05, 2012, 05:14 AM
AzTrekie is offline
Find More Posts by AzTrekie
Doing Projects Differently
AzTrekie's Avatar
Joined Jan 2012
Cool idea to make hover jet as I have a simular one
leadfeather
I like your idea as I had an interesting idea of my own not sure how to make it work but in the crude design stages now , as I also have to figure out how to make my Enterprise-A fly as it is to underpowered for the frame I built, but getting Back to the Jet I have designed mine between the avengers movie and the green lantern movie
using only two big fans on the wings which will I hope bring the craft off the ground and be able to pitch to 45%angle to bring it forward the have the edf engine which is in the fuselage to be able to take off quicker and hopfuly and do stunts I am still learning how to do that as I am still learning how to fly RCs mainly with my two playmates one kind of bet up one and one the is in almost prestine shape. my drawings are crude right now but tell me what you think of my idea
Dave
PS thanks for being one of my Friends
AzTrekie is offline Find More Posts by AzTrekie
Old Oct 05, 2012, 07:57 AM
Winging it >
Joined May 2006
Dave,
You design looks cool.
I am concerned you may be too ambitious at this time with this project. VTOL is one of the hardest things to do in RC both in terms of design and building skills, and also flying skills.
For this type of VTOL ( a transitioning jet) ; to be successful; you should have pretty good 4 ch fixed wing flying skills and also some multi-copter or 4 ch helicopter flying experience.
With your design I have a couple of concerns:
  • If there are only two lift fans, hovering stability is going to be pretty tricky.
  • With the large holes in the wings there is not much lifting surface for forward flight...wing loading and flying speed will be very fast.
  • With the anhedral tips you'll need ailerons for forward flight. The anhedral tips give a reverse yaw/roll coupling. With only two fans you'll also need an elevator for pitch control in forward flight
Good luck with what ever you decide to do.
Old Oct 05, 2012, 08:28 AM
nadine is offline
Find More Posts by nadine
vtol fan
nadine's Avatar
Joined Jul 2009
Awesome!...Allways,i liked the Harrier
Cheers Lead
nadine is offline Find More Posts by nadine
Old Oct 06, 2012, 02:44 AM
AzTrekie is offline
AzTrekie's Avatar
Joined Jan 2012
Thanks for your advise
Originally Posted by leadfeather View Post
Dave,
Lead
Thanks for your advise I have some other ideas on the burner a vector kite type ( dragon) http://www.rcgroups.com/forums/showthread.php?t=1740834 , a simple type of plane I call the my simple plane here at http://www.rcgroups.com/forums/showt...0#post22926605 and I still have to figure out how to get my Enterprise -A flying all details on my blog at http://www.rcgroups.com/forums/member.php?u=398824
Dave
Old Oct 06, 2012, 09:16 AM
rimshotcopter is offline
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Originally Posted by AzTrekie View Post
leadfeather
Dave
Something similar to this?
Stay tuned: http://www.rcgroups.com/forums/showthread.php?t=1683638
rimshotcopter is offline Find More Posts by rimshotcopter
Old Oct 06, 2012, 01:14 PM
AzTrekie is offline
AzTrekie's Avatar
Joined Jan 2012
sre somthing simular
yes using hat exact fan whith a faster brushless motor
Old Oct 06, 2012, 01:21 PM
Joined Aug 2009
LOL, Interesting.
Old Oct 06, 2012, 07:05 PM
Winging it >
Joined May 2006
First hover
Just hovered it for the first time. So far so good. I need to do a bit of PID tuning and once this is done I will then glue on the rest of the airframe.
Old Oct 06, 2012, 09:31 PM
RCvertt is offline
RCvertt's Avatar
Joined Aug 2007
Hover test looks good. Got to let that bird out and set it free
Be interesting to see how well it works, especially at slow speeds. I'm thinking you might have to land a little faster is all since all your commands will propel you forward a little bit.
Also curious how good pitch will be since the fans aren't spaces as far from the fuselage as the yaw commands will be in forward flight.
Question Anyone with experience in 3 axis thrust vectoring please offer suggestions Razors edge 29 Pusher Prop Jet Models 6 Feb 19, 2014 09:27 PM
For Sale Frewing F-35 vectored thrust jet capt soap Aircraft - Electric - Jets (FS/W) 0 Jun 18, 2012 05:07 PM
Question The thrust vectoring F18 90mm edf jet with 3d devilstriangle Electric Plane Talk 7 Jun 02, 2012 07:42 PM
Video X-31 EDF Park Jet with Thrust Vectoring System jetset44 Electric Plane Talk 4 Apr 25, 2006 02:24 PM
Experiment with vectored thrust...again mopar_man Foamies (Kits) 8 Oct 23, 2002 11:21 AM
