This thread is privately moderated by gromitvt10, who may elect to delete unwanted replies.
Old Oct 01, 2012, 06:42 PM
gromitvt10 is offline
Find More Posts by gromitvt10
Trader Rating: 55
gromitvt10's Avatar
United States, MD, Solomons
Joined Feb 2002
Trader Rating: 55
Sold
MQ-9 Reaper 98"
MQ-9 Reaper 98" 7-CH Brushless Remote Control RC UAV Predator/Drone Airplane RTF (local pickup only). Iíve flown this airplane 2 times and it flies nicely, using a 4s 3300 Lipo (not included). The camera turret has a few drops of hot glue to keep it stationary that can easily be removed to make it spin 360 degrees. CG was set to 50mm behind leading edge which worked well for my flights. Checkout my flight video here: http://www.rcgroups.com/forums/showt...237390&page=33
Link to another build:
http://diydrones.com/profiles/blogs/...ource=activity
Specifications:
Wingspan: 2500mm
Weight: 2500g~2700
Length:1080mm
Wing Area: 32.5 dm^2
Wing Loading: 76~83g/dm^2
Airfoil: Eppler 374 Modify
Radio: 4 Channel 4 Servos
Motor Diameter: 38mm~42mm
ESC: 40~50A
Propeller: 2 Blade 11x6 ~ 12x8 3 Blade 9x6 ~11x6
Battery: LiPo 3S/3500mAh ~4S/4000mAh
Included are all the items below:
MQ-9 Reaper 98"
Ritewing RC (1200kv) Brushless Motor
Ritewing RC 65a ESC
2 Hitec HS-55 Micro Servos (flaps)
2 Hobby King 9g Micro Servos (ailerons)
2 Standard servos (elev, rudder, nws)
1 Hitec Electron 6 rx, ch 11 (futaba)
1 3 blade prop 11X8 plus spinner
Ready to fly, just add you own battery Ė $400.00
Minus $150.00 if you donít want the motor, ESC, prop and spinner
Minus $15.00 if you donít want the Electron 6 RX.
Iím in the Southern Maryland area; I do travel up to Baltimore at least once per month and down to Richmond, VA once or twice a month.
Kyle
gromitvt10 is offline Find More Posts by gromitvt10
Old Oct 02, 2012, 07:03 AM
porcia83 is offline
Find More Posts by porcia83
Trader Rating: 128
United States, CT, Hartford
Joined Jun 2009
Trader Rating: 128
This looks great, wish I was closer.
porcia83 is offline Find More Posts by porcia83
Discussion MQ-9 Predator Reaper Drone - 98" Span xplaneguy Giant Electric Planes 24 Mar 08, 2015 08:53 PM
Discussion MQ-9 Predator Reaper - 98" Span xplaneguy UAV - Unmanned Aerial Vehicles 77 Apr 09, 2014 03:44 AM
For Sale MQ-9 Reaper 98" 7-CH Brushless Remote Control RC UAV Predator/Drone Airplane ARF Kit Rattler767 Aircraft - Electric - Airplanes (FS/W) 5 Sep 23, 2012 11:30 AM
For Sale Re-list MQ-9 Reaper 98" UAV Predator/Drone Airplane Rattler767 Aircraft - Electric - Airplanes (FS/W) 2 Sep 03, 2012 02:45 AM
Sold Projet MQ-9 UAV Reaper 98" (Rare/New in box) TBello Aircraft - Electric - Airplanes (FS/W) 0 May 02, 2010 01:54 PM
