Old Oct 01, 2012, 06:29 PM
nsgil85 is offline
Find More Posts by nsgil85
Joined Sep 2012
Help!
TGY DP frequency amplitude and duty-cycle
I have 4x "TGY DP 3A 1S 1g Brushless Speed Controller" and 4x "HobbyKing AP-03 7000kv Brushless Micro Motor" for my mini quad copter.
I'm building controller from scratch and would like to know what is the frequency amplitude and duty-cycle(max/min) for this ESC to operate the motors.
Gil
nsgil85 is offline Find More Posts by nsgil85
Old Oct 02, 2012, 12:37 AM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
The throttle signal to an ESC is a 1-2ms pulse 1ms being 0 throttle and 2ms being 100%. Typically this is repeated at ~50 Hz but it could be faster, no way to know if the ESC will support a faster rate though. This is not really PWM (though you can use a PWM system with a very short duty cycle and low frequency).
The ESC can likely be calibrated to match its idea of 0% and 100% with your controller.
desertstalker is offline Find More Posts by desertstalker
Old Oct 02, 2012, 06:39 AM
nsgil85 is offline
Joined Sep 2012
about the amplitude can i use 3.3v?
Old Oct 02, 2012, 07:52 PM
Joined Feb 2010
5V is typical, but 3.3V might work as most ESCs are pretty tolerant of signal voltages. May be too low though.
The uC I used had the option of using pull-up resistors (so you had two states 0V and high Impedance) and was 5V tolerant so i used 5V when I was playing with uC controlled ESCs.
Discussion Duty Cycle periquira Hoverfly Technologies 3 Jun 30, 2012 04:09 PM
Help! Servo frequency for a TGY-MG930 bosco49 Electric Heli Talk 3 Mar 17, 2012 03:42 PM
Sold Hextronic 2 gram Outrunner w/ TGY DP 3A 1S 1 gram ESC jrej Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Mar 16, 2012 03:48 PM
Discussion TGY DP 3a 1 Gram Brushless ESC ($20!) critterhunter Scratchbuilt Indoor and Micro Models 180 Oct 01, 2009 06:36 PM
Help! Plantraco 4ch RX with TGY DP 3A 1S 1g ESC Veteran Scratchbuilt Indoor and Micro Models 8 May 19, 2009 11:46 PM
