Espritmodel.com Heli Air
Old Oct 01, 2012, 05:41 PM
Joined Feb 2012
PL8 - Cell Over Voltage Press to Reset
All of a sudden I'm getting errors when charging packs, "Cell Over Voltage Press to Reset". I pressing buttons does not reset the error, nor does pressing and holding the Enter button to stop charging. In fact, I need to unplug and restart the charger to get out of the error.
Nothing with the cell voltages seems out of place when I restart the charge. For example the last time this happened, all the cells were at 4.15.
Any ideas as to what is causing this?
defxxx is offline Find More Posts by defxxx
Old Oct 01, 2012, 07:51 PM
D C
I'm Out Sky Dancing!
D C's Avatar
San Anonio, TX
Joined Jan 2009
I also got those over voltage messages and found that cleaning the balance connectors on both the Lipo and the charger balance connector fixed this problem for quite a while.
I believe they get a little dirty from wear and then under charging load, the voltages do not read correctly and the PL8 shuts down thinking there is something wrong with the Lipo.
Wish we had gold connectors because that would fix this problem.
I just used some electronic/contact spray and it worked just great....
Don C
D C is offline Find More Posts by D C
Old Oct 04, 2012, 08:43 PM
Joined Feb 2012
Copy that! I'll give it a try. I think you may be right because I have a second PL8 that I use less frequently and when using it on a shoot yesterday I had zero problems.
Discussion Different voltage readings between PL8 and cell log hlalibe FMA Direct 11 Aug 14, 2012 09:54 AM
Question PL8 as a Voltage booster BVH FMA Direct 2 Jul 10, 2012 04:24 PM
Discussion Will my PL8 charge a 2 cell pack that has no balance tap? WBFAir FMA Direct 7 Jul 04, 2012 11:39 PM
Discussion Low voltage level for PL8 where it won't even see cell anymore? WBFAir FMA Direct 3 Jul 01, 2012 07:24 PM
Discussion PL8, check cell voltage tesa1 FMA Direct 2 Nov 20, 2010 08:12 PM
