Old Dec 01, 2003, 09:11 AM
dannirr is offline
Find More Posts by dannirr
Balloonatic....
dannirr's Avatar
Norcross, GA
Joined Aug 2003
December Fly-In Pics and Conversation
Here's the first for this month
Had a blast yesterday - flew the Dandy Sport for about an hour. Then went home to complete the Tantrum - still have some work to do on that one - anyone have pic of where the cables exit the rear end of the fuselage - that is the one area of the manual that is deficient.
danni
dannirr is offline Find More Posts by dannirr
Old Dec 01, 2003, 11:36 AM
jaywatay is offline
Find More Posts by jaywatay
electron liberator
jaywatay's Avatar
United States, GA, Suwanee
Joined Mar 2003
I can take a pic of mine when I get home tonight.
Jason
jaywatay is offline Find More Posts by jaywatay
Old Dec 01, 2003, 07:09 PM
dannirr is offline
Balloonatic....
dannirr's Avatar
Norcross, GA
Joined Aug 2003
Razor and gearbox
I got a razor 400 that has a B gearbox and pinion already attached. I want to remove the brass pinion from the motor shaft. I need tips on how to do this as it is very tight. Also, how to put the new one on.
danni
Old Dec 02, 2003, 06:23 AM
jaywatay is offline
electron liberator
jaywatay's Avatar
Joined Mar 2003
Danni,
I was having issues with my camera last night but I'll get the pics of the P-P on the Tantrum posted tonight.
Removing the pinion: do you have a gws pinion puller? I have one and it is very easy to remove the pinions. To put on the new pinion, I stand the motor vertical and support the motor shaft on the back of the motor. Then I hold the pinion over the top of the shaft and lightly tap it on with a rubber mallet. This lets me drive the pinion pasted the end of the shaft so that it will line up with the spur in a gws gearbox.
I think Tony has another method where he uses a vice to press the pinions on.
Jason
Old Dec 02, 2003, 10:50 AM
Depdog is offline
Find More Posts by Depdog
Foam Flyer
Depdog's Avatar
Stockbridge, Georgia, United States
Joined Jan 2003
Man, the year is FLYING by, Pardon the punn.
Glenn
Depdog is offline Find More Posts by Depdog
Old Dec 02, 2003, 11:00 AM
Joel Shreenan is offline
Find More Posts by Joel Shreenan
Joel Shreenan's Avatar
United States, GA, Flowery Branch
Joined May 2001
Pinion pushing and pulling...
Danni: Here's an interesting discussion I found in searching around the EZone. Check out rpvpilot's two links that show how he mounted his Razor 350 in an empty 380 can which he then mounted to his GWS gearbox. Pretty clever.
http://www.rcgroups.com/forums/showt...r&pagenumber=1
Best regards! JMS
Joel Shreenan is offline Find More Posts by Joel Shreenan
Old Dec 02, 2003, 12:56 PM
dannirr is offline
Balloonatic....
dannirr's Avatar
Norcross, GA
Joined Aug 2003
New Moths
Hi all,
I was looking for something on the GWS site and came across two new versions / mods of their Tiger moth that look very cool!
They are introducing a 3D version - see http://www.gws.com.tw/english/product/airfly/3dtm.htm
(I'm thinking Mike D and Tony here)
and a 400 version - http://www.gws.com.tw/english/product/airfly/tm400.htm(I'm thinking Michael here)
Now we can have some real dogfights!
Thank G for all that model memory....
danni
Old Dec 02, 2003, 05:42 PM
downeym is offline
Find More Posts by downeym
Electric Addict
downeym's Avatar
United States, GA, Atlanta
Joined Apr 2002
and you might as well forget about inverted flight... it still has the undercambered wing.
Definately more agile, but also definately not 3d...
downeym is offline Find More Posts by downeym
Old Dec 02, 2003, 05:56 PM
tone is offline
Find More Posts by tone
Pontificating Member
tone's Avatar
Atlanta
Joined May 2003
Bill-
I read that thread on what 3d is not. Got a little messy after a while, but the general thing i got is that if you can control the plane when flying below stall speed, That is 3D.
The TM will never, of course, be 3D.
But ailerons might be kinda fun.
and mike D is right. i HAVE flown my Moth inverted.
Not for long, and not under control. heheheh
Tone
tone is offline Find More Posts by tone
Old Dec 02, 2003, 06:00 PM
downeym is offline
Electric Addict
downeym's Avatar
Joined Apr 2002
others have added alierons to the slow stick and TM before and they dont really work that well. With an undercambered wing you will make a lot of comprimises in the name of maximum lift. one is drag and the other is alieron effectiveness. Mostly because the airspeed is very low over the wing to begin with...
Call me skeptical... I think it will be a huge flop... just a heavy TM.
The speed 400 version looks interesting though... flat bottom wing and larger wingspan. Should be interesting...
Old Dec 02, 2003, 06:35 PM
jaywatay is offline
electron liberator
jaywatay's Avatar
Joined Mar 2003
Re: December Fly-In Pics and Conversation
danni
Danni, here are some pics of the pull pull exiting my Tantrum. Where the line went through the covering, I first put a piece of clear tape over the covering then poked a hole in it. The tape will prevent the slit in the covering from growing. Hope these help.
Jason
Old Dec 02, 2003, 06:36 PM
jaywatay is offline
electron liberator
jaywatay's Avatar
Joined Mar 2003
Tantrum P-P
another...
Old Dec 02, 2003, 06:39 PM
downeym is offline
Electric Addict
downeym's Avatar
Joined Apr 2002
if you can build light, the hacker is a good match. I always seem to build heavy though so my hacker didnt quite have enough punch for my flying style.
I am currently using:
mega 16/15/4 (see a pattern here?)
2.5:1 gearbox
12x6 prop
3s2pTP2100
AUW probably close to 30oz
I am using the cheap model motors gearbox which is pretty loud. If you can find a better quality gearbox I would recommend that... this seems to work fine, but is annoyingly loud for an airplane that reverberates like a snare drum!
you will have to modify the firewall to get it to fit. it is designed exactly for the hacker.
I am curious how loud the mega box you have is... It might be a better match. Both are offset innerdriven boxes...
Old Dec 02, 2003, 06:43 PM
tone is offline
tone's Avatar
Atlanta
Joined May 2003
Yeah Mike i agree, and i think the 3D moth is just something Lin wanted his guys to do for him, I don't think it'll be part of the kit.
hehe but ya just never know...
Man those SA "G" planes and the MM Tantrum are just too cool.
Tone
Old Dec 02, 2003, 08:02 PM
dannirr is offline
Balloonatic....
dannirr's Avatar
Norcross, GA
Joined Aug 2003
Jason - thanks very much - that helped a lot - although I did use micro connectors as I could not get the tension rights by pulling the string through the control horn hole - I needed some way to fix it in place while I tied and CA would not do it.
Now when I get the motor ready - I'll be ready! That'll be next week as I leave for a balloon festival on Thursday and won't be back till next week.
I can't wait to fly the Tantrum.
danni
2004- January Fly-In Pics and Conversation Mike Parsons Atlanta Area RC 514 Feb 01, 2004 05:57 PM
November Fly-In Pics and Conversation Bill K. Atlanta Area RC 486 Dec 02, 2003 10:43 AM
October Fly-In Pics and Conversation jaywatay Atlanta Area RC 634 Nov 01, 2003 11:22 PM
September Fly-In Pics and Conversation DavidJ Atlanta Area RC 772 Oct 01, 2003 09:34 AM
August Fly-In Pics and Conversation n111kx Atlanta Area RC 475 Sep 01, 2003 12:03 PM
