Old Oct 21, 2012, 06:35 AM
impala_gene is offline
Find More Posts by impala_gene
United States, OH, East Liverpool
Joined Sep 2012
How's the build coming waiting to see more pics
impala_gene is offline Find More Posts by impala_gene
Old Oct 22, 2012, 03:28 PM
BE77 Pilot is offline
Find More Posts by BE77 Pilot
SUPER DOG!
BE77 Pilot's Avatar
Joined May 2010
I have the plane built and am waiting for another 4500 4s pack to finish it. Looks like the airplane balances perfectly with the 110 and a ICE 100 under the dash area. That is going to be perfect for putting batteries directly under the CG with easy access. I'll get more pictures up in a few days. AUW ended up being 11.5 pounds which is great for a wing area of around 1100 sq. in.
BE77 Pilot is offline Find More Posts by BE77 Pilot
Old Oct 22, 2012, 08:00 PM
Joined Sep 2012
That sounds good cant wait to hear about that maiden flight. Good Luck
Old Oct 25, 2012, 07:59 PM
SUPER DOG!
BE77 Pilot's Avatar
Joined May 2010
The second 4S 4500 came in today and I was able to fit them perfectly in the forward area of the lower compartment. With them in this position she balances perfectly and installing the batteries is extremely easy. I added some braces to hold them in place and ran a Velcro strap around them. The last pic is where I mounted the ICE 100. Should get some airflow I'll be running it at about half capacity so I am not too worried.
Old Oct 28, 2012, 06:20 PM
Joined Sep 2012
I can't tell but was wondering what size servo's your running i was thinking something in the 50-60 oz torque range . I'm still not sure if im going gas or electric with this being my 1st conversion. If i go gas im going with the DLE 30
Old Oct 30, 2012, 07:03 PM
SUPER DOG!
BE77 Pilot's Avatar
Joined May 2010
I am using Futaba 9202 coreless servos for elevator and rudder and some old S148's for ailerons. I bet the DLE 30 will make this plane hover at 1/2 power. Double check when you mount the engine. I believe they modified the firewall to add the down thrust but did not change the instructions. The instructions call for mounting the engine 4mm above the crank shaft cross marks and putting in 2 degrees of down thrust, however, it looks like that is not necessary. I will know more after I can get my bird to the field. The weather lately has not cooperated.
Old Nov 04, 2012, 08:12 PM
SUPER DOG!
BE77 Pilot's Avatar
Joined May 2010
Finally got some motor & battery data.
Motor Tacon 110 295Kv Motor
ICE 100 ESC
2, 4S 4500 Nano Tech in series
APC 16 x 8E Prop
1348 Watts @ 43 Amps.
APC 17 X 8E Prop
1567 Watts @ 50.3 Amps
Old Nov 09, 2012, 06:40 PM
SUPER DOG!
BE77 Pilot's Avatar
Joined May 2010
After two weeks of bad weather I was finally able to fly the Cub. It turned out to be all I hoped and more. With the 110 she took off and climbed out nicely with at half throttle, this power combination is perfect. Rolls and loops looked very scale and there was no tendency to climb when power was added so they did change the firewall to add down thrust. Do NOT add more as the instructions call for.
I did find that the gear was very springy and I was unable to land without some bouncing. I am going to add more rubber bands to the gear to stiffen it up a bit.
All in all this turned out to be a perfect plane to convert to electric.
Old Dec 16, 2012, 07:03 PM
cowboy1969 is offline
Find More Posts by cowboy1969
Bigger fly's better
United States, PA, Allentown
Joined Dec 2012
Just ordered this thing,Im not an electric guy so im going with a DLE 20cc gasser!!! Im thinking 30cc or more is too much for this plane,It has a low wing loading like most cubs,Cant wait till spring cause I hate winter time except for some good building time,Have a CMP Yak 54 to put together also,Happy building people!!!
cowboy1969 is offline Find More Posts by cowboy1969
Old Dec 25, 2012, 12:14 PM
57 zulu is offline
Find More Posts by 57 zulu
Joined Dec 2012
I have this plane and was wondering if it would be ok to put dubro inflatable tundra tires on it they are 5 and a half inches alittle heavey and The tail wheel a two inch wheel not inflatable is this ok or would it be bad
57 zulu is offline Find More Posts by 57 zulu
Old Dec 26, 2012, 07:44 PM
57 zulu is offline
Joined Dec 2012
How aerobatic is this cub
Old Dec 27, 2012, 08:10 AM
bassfisha is offline
Find More Posts by bassfisha
Joined Sep 2012
ICE 100 ESC
APC 16 x 8E Prop
APC 17 X 8E Prop
What was your flight times with this setup?
bassfisha is offline Find More Posts by bassfisha
Old Jan 01, 2013, 05:40 PM
SUPER DOG!
BE77 Pilot's Avatar
Joined May 2010
I have not gotten enough flights on this plane to know, but I can tell you about half throttle is all you need even for take off.
Old Jan 01, 2013, 05:42 PM
SUPER DOG!
BE77 Pilot's Avatar
Joined May 2010
IMHO this plane will easily take bigger main wheels and I would recheck CG after adding a heaver tail wheel. As for aerobatic, it's a clipped wing Cub and flies like one.
Old Jan 01, 2013, 05:46 PM
SUPER DOG!
BE77 Pilot's Avatar
Joined May 2010
Good choice, a 30CC is over kill!
Discussion .46 OS AX 1/6 Clipped Wing Cub gjap Fuel Plane Talk 23 Jun 16, 2012 12:58 PM
Discussion Sig 1/5 Cub: Clipped wing vs Std Wing u2builder Scale Fuel Planes 13 May 21, 2012 05:41 AM
Sold Bill Hempel 60% Clipped Wing Cub hosam Aircraft - Fuel - Airplanes (FS/W) 7 Apr 13, 2012 06:51 PM
Help! 1/4 sig clipped wing cub mercurypro Glow to Electric Conversions 2 Mar 25, 2012 10:21 PM
For Sale WM 25% Clipped Wing Cub 30cc BNF GoldCraft Aircraft - Fuel - Airplanes (FS/W) 5 Aug 15, 2011 10:50 PM
