Old Oct 01, 2012, 01:55 PM
gr_yamms is offline
Find More Posts by gr_yamms
Joined Sep 2012
Help!
Best 0.46 cu. in. Nitro Engine?
Hello All,
I've been comparing a lot of .46 cu. in. engines (OS, ThunderTiger, Magnum, ASP, etc.) They all have comparable power output (1.4-1.6 hp), but big variations in price. Any recommendation on the best performing engine? And what about your recommendation makes it the best?
Thanks!
gr_yamms is offline Find More Posts by gr_yamms
Old Oct 01, 2012, 03:55 PM
hutchinstuff is offline
Find More Posts by hutchinstuff
Hutch
hutchinstuff's Avatar
United States, Mt, Bozeman
Joined Jan 2012
I love the os 46ax or fx. They run pretty reliably and are very easy to tune, run well rich. I had a thunder tiger 40 that was nice enough as well. had good luck with mags too! If I were gonna get another 46, I'd get - 46 ax if going used. magnum 46 if going new (as they are a lot less and have a good rep.) they are all going to weigh about the same, turn similar props with similar power. I bet if you cowled an engine and swapped my os with a magnum, TT ..... I wouldn't even know the difference.
hutchinstuff is offline Find More Posts by hutchinstuff
Old Oct 01, 2012, 05:13 PM
iAlex is offline
Find More Posts by iAlex
Jett Engineering Sport Jet .46 wins this contest hands down. But yet you pay for the performance in cost. Mine will turn a 10x6 prop at 16K all day long on the ground. In the air it unloads to around 17K or so. It's a "piped" engine so I wouldn't use it for 3D type flying, but for eveything else you can't beat it. If your cost conscious then it's not for you. But if you have ~$300 burning a hole in your pocket...
iAlex is offline Find More Posts by iAlex
Old Oct 01, 2012, 05:29 PM
Jim Thomerson is offline
Find More Posts by Jim Thomerson
I had an ASP 46 pass through my hands. I ran it on the bench with 10% nitro fuel and APC 12 x 6 prop. It hurt my ears to the point that I shut it down. I haven't experenced anything like that since I ran Control Line Rat Race engines without ear muffs.
Jim Thomerson is offline Find More Posts by Jim Thomerson
Old Oct 01, 2012, 05:38 PM
Roto Rob is online now
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
Kind of depends on what you want out of it, and what your putting it in. An engine good for a 3D plane, will probably not be near as good for a high speed jet.
Roto Rob is online now Find More Posts by Roto Rob
Old Oct 01, 2012, 05:45 PM
gr_yamms is offline
Joined Sep 2012
Thanks for the responses everyone. iAlex, I did see Jett, and I also saw their price. However, I couldn't find its power output anywhere on their site.
Roto Rob, speed is not really a desired characteristic for this project.
Hutchinstuff, by following your advice, I would probably go with the TT or magnum based on other threads that I've read--about the same performance but a lot lighter on cost.
Do any of you advise gear reduction if I want to get ~8lbs of thrust from any of these engines? (Assuming a 11 x 6 prop)
Old Oct 01, 2012, 05:49 PM
Hemikiller is offline
Find More Posts by Hemikiller
-insert witty saying here-
Hemikiller's Avatar
United States, CT, Killingworth
Joined Dec 2005
Manufacturer's rated power output is to be taken with a grain of salt.
IMO, the best deal going is the TT46 engine: OS quality without the ridiculous parts prices.
Hemikiller is offline Find More Posts by Hemikiller
Old Oct 01, 2012, 05:59 PM
jeffie8696 is offline
Find More Posts by jeffie8696
TEAM BOCA
jeffie8696's Avatar
United States, IA, Muscatine
Joined Oct 2009
I agree with Hemi. My Thunder Tigers work great.
TT46Pro on the sons Nexstar (0 min 38 sec)
jeffie8696 is offline Find More Posts by jeffie8696
Old Oct 01, 2012, 06:03 PM
gr_yamms is offline
Joined Sep 2012
jeffie that's a pretty convincing vid. haha.
What's the weight of that plane btw? And anyone have thoughts on gearing?
Old Oct 01, 2012, 06:44 PM
aspeed is online now
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
I wouldn't gear any glow motors. The prop and pitch are the gears. You could go like a 12-4" or 13"-4" for the same effect.
aspeed is online now Find More Posts by aspeed
Old Oct 02, 2012, 12:14 AM
TEAM BOCA
jeffie8696's Avatar
Joined Oct 2009
This one is running an 11X6 MA 3 series prop with great results. Fuel is a 15% custom blended break in mix. Havent weighed the plane combo but its a little heavy in my opinion however the TT46 pulls it very nicely.
Old Oct 02, 2012, 05:42 PM
iAlex is offline
Jett doesn't list the power output on his website. When it comes to horsepower calculations of our small glow engines it is more a question of who can stretch the truth the best. But with the Jett he does say that with a 10x6 APC prop and powermaster 15% fuel a Sport Jett .46 will achieve 16,500 RPM. This is what I found with my .46. Using the same fuel and prop I was able to peak my engine at 16,500 RPM on the ground.
My Top Flight Contender is a blast to fly with this engine.
Old Oct 02, 2012, 11:13 PM
TEAM BOCA
jeffie8696's Avatar
Joined Oct 2009
Some day I will win the lottery and buy some Jett engines. Rich uncle maybe.
OK so I am a cheapskate.
Maybe I can talk them into sending me a test engine, it has happened before.LOL
Old Oct 06, 2012, 10:24 PM
NACA0012 is offline
Find More Posts by NACA0012
Joined Mar 2012
Best performing? Under what conditions?
Things that work well on one plane, may suck on another.
NACA0012 is offline Find More Posts by NACA0012
Old Oct 29, 2012, 05:14 AM
Mgblunt is offline
Find More Posts by Mgblunt
Meramec Mike
Mgblunt's Avatar
Joined Dec 2011
I have two thunder tiger 046 and one OS and the thunder tiger engines out perform the OS and have held up well
Mgblunt is offline Find More Posts by Mgblunt
Sold Groupner OS - I .30 cu.in. Rotary engine scones007 Aircraft - Fuel - Engines and Accessories (FS/W) 10 Jun 17, 2012 04:25 PM
Sold .46 nitro engine helicopterdr Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 27, 2012 07:12 AM
Discussion Elec Motor wattage equivilant to a 46 size nitro engine dakoris73 Beginner Training Area (Aircraft-Electric) 16 Apr 15, 2012 04:01 AM
Sold Saito FA 125a 1.25 cu in 4 stroke engine lmpbpd Aircraft - Fuel - Engines and Accessories (FS/W) 2 Feb 27, 2012 11:12 PM
Discussion 2c 0.25 x 2 cu in... Say What? Gyallis Engines 3 Jul 15, 2006 03:24 PM
