Old Oct 02, 2012, 12:52 PM
gagallagher044 is offline
Find More Posts by gagallagher044
Maine
Joined Jul 2009
"I do use clear Ultra covering on the bottom of ARFs controls to fill the hinge gap though"
I have heard this many times, I do not understand it. Pics? video? If you fill the gap how does the control surface actuate?
I plan on doing everything as per the manual pretty much.
I do plan on re-enforcing the landing gear for sure.
I will also use 4-40 rods everywhere which will help also.
I did just order 15 robart 1/8th hinges, and the drill guide. Maybe just the elevator, and rudder with these?
I like things simple, reliable, and hassle free. I get reading these threads, and I guess I get paranoid.
gagallagher044 is offline Find More Posts by gagallagher044
Old Oct 02, 2012, 05:14 PM
Gray Beard is offline
Find More Posts by Gray Beard
Joined May 2012
I use the 1/8 pins in most my planes. The planes I just built get the Dubro flat hinges though. Just because of the control thickness, they are a bit on the thin side. I did install some added exttra wood for a better gluing surface. The guide can be used for 1/8 and 3/16 I think. It comes with two screw in addapters. Pins are the easiest to use.
Gray Beard is offline Find More Posts by Gray Beard
Old Oct 02, 2012, 06:50 PM
Maine
Joined Jul 2009
still what is this..you said..
Old Oct 02, 2012, 07:22 PM
Joined May 2012
You iron on the covering onto the stab first then bend the control surface into the full up position, iron the covering into the gap then over the control surface. Now the gap is covered and the control will move up and down. When I cover a plane I do it in one piece and just run the covering over the gap, it's just doing the same thing only not adding a piece of covering over the gap. I do it top and bottom the same way. I can post a photo of that but all you see is the covering with a slight dent when it goes over the control. It just seals the gap and makes clean up easy, no oil ever gets to the wood. You need a photo?
Old Oct 02, 2012, 07:40 PM
Maine
Joined Jul 2009
yup, i need a photo lol maybe a vid... lol
Hey gray beard what do you think I should throw in this bird for servo's? would I am thinking hitec HS-625MG in everything but the throttle. I will be using a 4.8v 2200 nimh rx pack. ( i think) I Would perfer to spend a little less on the servo's but not sure if I can find something suitable and dependable.
Old Oct 02, 2012, 09:46 PM
acdii is offline
Find More Posts by acdii
Garfield is my Pilot
acdii's Avatar
Joined May 2011
Man I would like a Revolver 70 Kit, I am done with Arf's. My 4*120 ARF lost a wing in flight and did a death spiral. Now I am in need of a replacement plane. The wing on the 4* is very crappy construction. I'll find the broken wing and get some pics of where it snapped off, the pieces I recovered are shattered, and not much can be made from them, the left wing is still intact, but busted up. The plane is a loss, and so is the ignition, and at least one servo. I dont know about the other aileron servo, its still in the other wing, I hope.
acdii is offline Find More Posts by acdii
Old Oct 02, 2012, 09:48 PM
acdii is offline
acdii's Avatar
Joined May 2011
It also makes recovering easier since you dont have to try to get the old covering out from between the control surfaces and stab, fin, or wings.
Old Oct 02, 2012, 11:27 PM
Joined May 2012
Hi AC, sorry to hear about the 4*,. Any idea if it was one of the new ARFs sense SIG is under new ownership or could it have been one of the older originals?? The old ARFs from before they were bought out weren't very good but I haven't seen any of there new ones.
I have a HOTs I will be pulling down to charge up tomorrow so I will try to get some good photos of the one piece covering. I have a lot of work to be doing in the shop so it's isn't a problem. I think I may even have some How To photos in my other puter? Maybe. I will look.
Old Oct 03, 2012, 08:01 AM
acdii is offline
acdii's Avatar
Joined May 2011
It was an older one, and upon examination of the wreckage found the cause of the failure. The main spars had NO support whatsoever between the center rib and rib #4. There are two pieces of plywood in front and behind the main spar between C & 4 ribs that ribs 2 & 3 attach to, and neither of them had any glue on them connecting to the main spars. There is an aluminum joiner that slides in the box the spars and plywood make, and that joiner presses against the spars, and forced them away from the ribs during flight. The spars separated from the center rib and the wing snapped off at the fuse. All I have left of the right wing is the center rib, the portion where the bolt hold down is and the balsa sheeting that was against the fuse. the rest of it is still in the field somewhere.
Old Oct 03, 2012, 12:34 PM
Joined May 2012
Well AC, that also told me why you also had a covering problem too. The older SIG ARFs were very poorley made and pretty much junk. In one post I was told they are now making the 120 kit again? Not real sure about that yet, I think it was you that told me.
Anyway, the last 4* kit I built while teaching kit building took us 6 days to build. It was a completely stock build too and my student was 70 years old and we spent 6 or 7 days building it, full 6 to 7 hour days though. I know how much you liked that plane so you may want to look into the kit and see if you can get the 120 and build your own so it doesn't fall apart on you. A couple weeks at your board and you will have a plane you can trust.
Just a thought???
I just picked up one of the ignitions for the DLE from HK. It was a group order and it only cost me $30.00 even with my share on the shipping. I wanted a new ignition for my Brison, I did have to install a new plug cap for it but I was lucky enough to have had the correct size cap on hand in my shop. For some reason it had an extra cap but it was the same size as the one that was already on the ignition?? Both for the CM-6?? Karol had sent me three caps of different sizes so I have a few on hand.
Gene
Old Oct 03, 2012, 12:49 PM
acdii is offline
acdii's Avatar
Joined May 2011
Hi GB, no Sig isnt coming out with a new 4* ARF anytime soon, but they are looking for a manufacturer for them. I emailed SIG this morning and did get a reply. They will replace the arf with a kit and covering, so I can build one to replace this one. I just need to dig up the receipt for it and send it and my address for them to ship it to me.
On the ARF, I did post that an ARF was coming out soon, and it was the Ultimate I think. It was a Hanger 9 ARF.
Old Oct 03, 2012, 01:24 PM
Joined May 2012
So, it's a fact, SIG is cutting the 120 size kit again? I'm amazed they will replace the ARF at all for you. These new owners are really doing a good job! I will have to look on there site and see what they have to offer these days. I'm back logged on building so won't be buying any new kits but I would like to see what SIG now has to offer.
Old Oct 03, 2012, 02:15 PM
acdii is offline
acdii's Avatar
Joined May 2011
No the ARF not the kit, they are still producing the kit. The ARF for the 4* they are looking for someone to manufacture them, but the kits are still being made at the US location.
Old Oct 03, 2012, 02:20 PM
Gray Beard II is offline
Find More Posts by Gray Beard II
Joined Oct 2012
Covering in one piece to cover/fill the hinge gap is easy but you have to try it a few times. Because Ultra shrinks easier/better then Mono it's easier to do. I lay down the main color first and iron down the covering onto the TE of the wing in these photos to do the ailerons. I then slice the covering at the ailerons edges, then I pull the control down and do inside the gap then just pull it over the control surface and iron the covering down. I do it to both sides, It seals the hinge gap and and also makes clean up easier after a day of flying. I do it to all the control surfaces except the rudder. On the sides of the wing and aileron you may see the fillets of covering that I butt up to so there is no exposed wood.
With an ARF I just seal the gaps on the bottom. You just pull the control to the deflection so when sealed it will move freely up and down, Not a big thinker.
Gray Beard II is offline Find More Posts by Gray Beard II
Old Oct 03, 2012, 06:27 PM
Maine
Joined Jul 2009
Thank Gray beard I will give it a shot.
Sold GP/EP Revolver Sport Aerobatic 70" ARF Alorek Aircraft - Fuel - Airplanes (FS/W) 0 Sep 11, 2012 04:11 PM
Discussion crashed Revolver .46-.70 GP/EP Sport Aerobatic ARF indydrt33 Electric Plane Talk 1 Jul 31, 2012 01:58 PM
Sold or Trade Great Planes Revolver Sport Aerobatic GP/EP ARF 70" LPU donho1 Aircraft - Fuel - Airplanes (FS/W) 2 Apr 20, 2012 09:38 AM
Sold or Trade Great Planes Revolver Sport Aerobatic GP/EP ARF 70" LPU donho1 Aircraft - Electric - Airplanes (FS/W) 0 Apr 17, 2012 01:54 PM
Discussion GP Revolver 70 engine choice garrettt04s Electric Plane Talk 3 Apr 07, 2012 12:47 AM
