Old Dec 08, 2012, 06:22 PM
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Hope your going to put a scale prop on her after all this, the pup one should be near on the right diameter, they are the ones designed by Leo, and build up Into beautiful props, and fly well if the power system is picked to suit them. It would be a shame to have a horrible plastic prop hanging off the front of this!
http://www.vintagemodelcompany.com/category/propellors/
Craig
trumps is offline Find More Posts by trumps
Old Dec 09, 2012, 08:08 AM
Seven Swabians
Shnokey's Avatar
United States, MA, Holliston
Joined May 2004
what a cool site - I was unaware that there was a "prop" company that made them, I was going to re-shape a "regular" wood prop - but I may pick one of these - Expensive to send to the US though - with shipping - it's almost a $60 U.S. for 1 prop - - - -
Shnokey is offline Find More Posts by Shnokey
Old Dec 09, 2012, 11:52 AM
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Those props are so light that shipping two props in the same package would probably cost the same as one prop. So order two props and you automatically cut the shipping cost per prop in half. Or you can order three and save even more.
Marvelous build. Putting so much scale detail in such a small airplane is an art that you seem to have mastered.
Larry
Lnagel is offline Find More Posts by Lnagel
Old Dec 09, 2012, 01:40 PM
Seven Swabians
Shnokey's Avatar
Joined May 2004
You must know my wife – That’s her shopping Philosophy – Hey, I used a 20% coupon on this $200 coat – Look at the money I saved you….
Old Dec 09, 2012, 01:54 PM
Melbourne, Australia
Joined Mar 2009
Craig
I'm just glad that somebody is making these again.
Thanks for the link Craig.
Hugh
Oh, and very inspiring build. Clever idea with the engine.
MerlinV is offline Find More Posts by MerlinV
Old Dec 09, 2012, 02:57 PM
What's 3D?
trumps's Avatar
Joined Feb 2008
Wow, didn't realise how pricey they are thesedays, Leo used to do them about £6.00 in the 11" size, oh well times change, I hope he is getting some return on the effort he put in designing them! I have been running an 11.4 x 11.6 mahogany one one my pup for the last 3 years and couldn't be happier with it, very strong which is handy with the models tendency to nose over. And looks the part, especially as it is only spinning at about 3000rpm on my setup.
Craig
Old Dec 09, 2012, 05:10 PM
Nelson, B.C.
Joined Jun 2008
Beautiful work shnok, especially the instrument panel.
Kim
chumbly is offline Find More Posts by chumbly
Old Dec 09, 2012, 05:25 PM
Seven Swabians
Shnokey's Avatar
Joined May 2004
Thanks! - Added the cheek cowls today - used light ply as the inner formers instead of the balsa ones - it adds to the "bow" effect of the cowl, and keeps the area open for the radio equipment - added a "fake" gas tank behind the seat so when I sheet the upper fuselage front, I can make a hole for the fuel filler and main gas tank filler and you will see the aluminum and copper tape. - More to follow
Old Dec 09, 2012, 05:26 PM
Seven Swabians
Shnokey's Avatar
Joined May 2004
The rear tank former
Old Dec 09, 2012, 05:48 PM
Heads up...
RMCCOR7737's Avatar
United States, VA, Stafford
Joined Jun 2009
I wish I could do details like that. Fantastic work! Now if you can just find a little pilot to fly it for you...
RMCCOR7737 is offline Find More Posts by RMCCOR7737
Old Dec 09, 2012, 06:31 PM
This is a fine fiddly business
Robert R's Avatar
United States, WA, Marysville
Joined May 2009
Quite outstanding!
Robert
Robert R is online now Find More Posts by Robert R
Old Dec 11, 2012, 08:16 AM
Seven Swabians
Shnokey's Avatar
Joined May 2004
Now I know why they called it a "Camel" - - - Added and rough sanded all of the cowl and front sheeting, seems like most of the cockpit work I did is now hidden - go figure - finishing the wings with scale bracing and such, I still have to finish the wing attachment points on the fuselage, final sanding and primer base coat - then add all of the details to the fuselage, we are getting there....
Old Dec 17, 2012, 07:06 PM
Seven Swabians
Shnokey's Avatar
Joined May 2004
finishing up before covering - all of the exits for the control cables are complete - scale locations with small plastic tubing used for "steel cables" to guide the thread -
Old Dec 23, 2012, 07:28 PM
Seven Swabians
Shnokey's Avatar
Joined May 2004
Finished all of the fuselage and wing attachments, wire routing and control surface controls, and completed the tail skid and shock cord - I spent the last few days finishing the motor, and it’s looks factory new – we will take care of that when we weather everything – Ready for covering and primer coat for the fuselage – then it’s time for the details – from inspection covers to nuts and bolts – goal is to have it complete by 2013 - +/- 10 days or so This Mayan "end of the world" thing threw me off a little - Guess I have to deliver now -
Old Dec 31, 2012, 10:10 AM
Seven Swabians
Shnokey's Avatar
Joined May 2004
Messing around over the holiday week – I finished the fuselage, cowl, rigging and I have to cover the bottom of the lower wing before Install the aileron servos. I wanted to try a new (to me) way of adding rib-stitching to the ribs without having to paint and seal it. Normally, I would make the rib tapes using a method I learned here – where you cut grooves in a board, (1/4 inch in this case) put down a sheet of covering and add the thread cross-wise on the board, and glue it or Dope the thread down. Then cut the tapes out and glue or Dope over the rib on TOP of the covering, then seal the tape down with clear paint, dope or other sealant. I did not want to add the weight of coats of sealer over CoverLite, as that is already sealed and ready to go. So what I did was make the CoverLite “sheet” of rib tapes with three coats of tinted shellac. This makes it look like antique wood. Then I glued the rib tapes right on to the ribs before covering, and then I covered the wing with CoverLite. The texture and darker color come through the top covering, without any sealing or tape issues. Looks like it works for what I wanted it for. With a 1/9 scale model, heavy and thick rib tapes (IMO) make it look too toy like – this will add the essence of texture without too much “over modeling” - again – in the eye of the beholder.
Discussion Hanger 9 Sopwith Camel AndyCross Glow to Electric Conversions 92 Dec 04, 2012 05:34 PM
Sold Hangar 9 Sopwith Camel FLYBOB54 Aircraft - Electric - Airplanes (FS/W) 7 May 05, 2012 08:02 PM
Build Log AerodromeRC 1:9 Scale Sopwith Snipe Proto Build vonJaerschky Scale Electric Planes 145 Jul 10, 2009 08:28 AM
Build Log New AerodromeRC 1/9 Sopwith Camel sleonard Scale Electric Planes 15 Sep 14, 2006 05:22 PM
Discussion AerodromeRC 1:9th scale Sopwith Camel Bengtson Scale Electric Planes 3 Feb 20, 2006 02:09 AM
