Old Feb 19, 2013, 03:13 PM
Shnokey is offline
Find More Posts by Shnokey
Closed Account
Joined May 2004
Originally Posted by mtflyr View Post
Looks super but you're going to have to get some weathering on it, some oil, dirt and mud stains etc. when she's done
Pete
Oh Yes - It will look as if it flew a few missions in the mud! - This paint went on in the winter of 1917 and it was muddy, messy, dirty and just plain old wet - I'm going to have some fun with this....
Shnokey is offline Find More Posts by Shnokey
Old Feb 19, 2013, 03:15 PM
Shnokey is offline
Closed Account
Joined May 2004
Originally Posted by Huey N View Post
Shnokey....are you in the art/design business as well?
Great trick - I will use it in the future - I own a website design/programming company - so my "Art" is behind a keyboard - This balsa wood thing is just a hobby
Old Feb 20, 2013, 07:00 AM
Shnokey is offline
Closed Account
Joined May 2004
As a distraction from the painting, I started the guns I found a 3 view drawing online and scaled it to exactly 1/9 scale, so I had a 1:1 size plan to build to - I took some plastic sheet and scored it to replicate the cooling grooves on the machine gun jacket, and wrapped the plastic around brass tubes to get the right diameter (the brass will be removed later) and used aluminum tape for each end. I still have to add the cooling slots (you can see a few made with aluminum tape). But they are on the way -
Old Feb 20, 2013, 08:30 AM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
That's got to be the best home made modeling of the Vickers cooling jacket I've seen to date. Can't wait to see how you model the gun's breech. What thickness plastic did you use and how did you score the plastic?
Larry
Lnagel is offline Find More Posts by Lnagel
Old Feb 20, 2013, 09:55 AM
Shnokey is offline
Closed Account
Joined May 2004
I'l put something together over the weekend - Curse you VonJaerschky!!! - sending me a data file for the Vickers - Now I will HAVE to make it to exact model specs...
Old Feb 20, 2013, 11:09 AM
warhead_71 is offline
Find More Posts by warhead_71
Always Ready!
warhead_71's Avatar
Chicago, IL
Joined Dec 2006
With a "micro chisel" you can punch perfect little vents in your cooling jacket. Use a wood cutting board underneath the part so you don't damage the chisel. Or you can probably just use a flat-bladed micro screwdriver -- it might not punch all the way through but it will emboss it nicely.
warhead_71 is offline Find More Posts by warhead_71
Old Feb 21, 2013, 08:39 AM
Paul Bonati is offline
Find More Posts by Paul Bonati
Paul Bonati's Avatar
Buenos Aires, Argentina
Joined Aug 2007
Enjoying your build !!!!!
Paul.
Paul Bonati is offline Find More Posts by Paul Bonati
Old Feb 21, 2013, 09:28 AM
Shnokey is offline
Closed Account
Joined May 2004
NICE - I'm going to try that - Now that I have the pictures and files - I want to change the style anyway - perfect timing!!!!! - -
Old Feb 23, 2013, 08:43 AM
Shnokey is offline
Closed Account
Joined May 2004
Took warhead_71's advice - pulled the guns apart - and used a small screwdriver to make the louvers - MUCH better - The plastic is thin (paper thin) that I scribed with a watch band removal tool!!! - now back together and back to stencils and painting -
Old Feb 27, 2013, 08:49 AM
abadon is offline
Find More Posts by abadon
Joined Nov 2011
clerget dummy
Originally Posted by Shnokey View Post
OK - Some fun with a scale Clerget motor around the e-motor - I think the design will work - I made a mock-up and tried it - it still needs to be balanced and finished - but the concept works -
http://www.youtube.com/watch?v=cjoxGzPLxuo
Let me know what you think!! -
Hello,
I am new to this forum, but am in the process of building a Sopwith Snipe.
I am also fascinated by this design for a moving rotary engine.
Could you be kind enough to explain in greater detail the inner workings, maybe even some plans?
Kind Regards
Peter
abadon is offline Find More Posts by abadon
Old Feb 27, 2013, 09:27 AM
Shnokey is offline
Closed Account
Joined May 2004
Take a look here - Should give you enough info - let me know if you need any more..... http://www.aerodromerc.com/cgi-bin/y...=1347136643/90
Old Mar 03, 2013, 06:37 AM
Shnokey is offline
Closed Account
Joined May 2004
Mask and paint for the week - I think I went through 20 sheets of mask - a roll of tape and about 20 airbrush cleanings - I do better printing tissue than painting - Still learning - - all of it is basically done - now for the guns, cockpit trim and details, and final assembly -
Old Mar 03, 2013, 07:40 AM
rtibbs is online now
Find More Posts by rtibbs
rtibbetts
rtibbs's Avatar
Central Florida
Joined Mar 2008
Outstanding job on the masking Jon. May I ask what you used for paint?
Ron
Sorry, the painting ain't too shabby either
rtibbs is online now Find More Posts by rtibbs
Old Mar 03, 2013, 07:45 AM
Lnagel is offline
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Fantastic job on painting the markings. Masking and airbursh cleaning are a real pain, but the results are so much worth it. One note for future reference, British roundels normally do not have the white surround on the clear doped fabric. The white surround is used to improve contrast on the PC 10/12 colored fabric.
Larry
Old Mar 03, 2013, 08:06 AM
Shnokey is offline
Closed Account
Joined May 2004
Ron
Hi Ron - I used acrylic Plastic model paints (I used to use Poly's) but now they are model master paints. I get them at the local plastic model store - a ton of colors and not that expensive - easy to thin down a little and easy to clean up with water - once dry, they are pretty durable -
Discussion Hanger 9 Sopwith Camel AndyCross Glow to Electric Conversions 92 Dec 04, 2012 05:34 PM
Sold Hangar 9 Sopwith Camel FLYBOB54 Aircraft - Electric - Airplanes (FS/W) 7 May 05, 2012 08:02 PM
Build Log AerodromeRC 1:9 Scale Sopwith Snipe Proto Build Wolpertinger Scale Kit/Scratch Built 145 Jul 10, 2009 08:28 AM
Build Log New AerodromeRC 1/9 Sopwith Camel sleonard Scale Kit/Scratch Built 15 Sep 14, 2006 05:22 PM
Discussion AerodromeRC 1:9th scale Sopwith Camel AerodromeRC Scale Kit/Scratch Built 3 Feb 20, 2006 02:09 AM
