Old Feb 06, 2013, 11:24 AM
phillip57 is offline
Find More Posts by phillip57
S/E Michigan
Joined Jun 2010
Though I hate to judge before all the facts are in, (remember general Turgidson?)
this is truly an outstanding build.
I'm a hack,
Phil
phillip57 is offline Find More Posts by phillip57
Old Feb 06, 2013, 11:57 AM
Shnokey is offline
Find More Posts by Shnokey
Closed Account
Joined May 2004
Favorite character was Slim Pickens as Major T. J. (King) Kong, the B-52 Stratofortress bomber's commander and pilot - Riding the bomb!!! -
Shnokey is offline Find More Posts by Shnokey
Old Feb 06, 2013, 12:06 PM
S/E Michigan
Joined Jun 2010
Yeeeee Hawwwww!!!
Old Feb 06, 2013, 05:43 PM
RMCCOR7737 is offline
Find More Posts by RMCCOR7737
Heads up...
RMCCOR7737's Avatar
United States, VA, Stafford
Joined Jun 2009
Trivia Question - How many props (when complete?)
4?
RMCCOR7737 is offline Find More Posts by RMCCOR7737
Old Feb 06, 2013, 06:36 PM
Paul Bonati is offline
Find More Posts by Paul Bonati
Paul Bonati's Avatar
Buenos Aires, Argentina
Joined Aug 2007
4 propellers.
Paul.
Paul Bonati is offline Find More Posts by Paul Bonati
Old Feb 07, 2013, 05:29 AM
Shnokey is offline
Closed Account
Joined May 2004
4 it is - Sanding and prepping today - Pictures to follow - Great distraction from painting...
Old Feb 07, 2013, 10:49 AM
ulpilotrmh is offline
Find More Posts by ulpilotrmh
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
7?
Russ
ulpilotrmh is offline Find More Posts by ulpilotrmh
Old Feb 07, 2013, 10:51 AM
ulpilotrmh
ulpilotrmh's Avatar
USA, FL, Tavares
Joined Sep 2010
Originally Posted by ulpilotrmh View Post
7?
Russ
Nutz. Shoulda looked at the last page before I guessed.
Russ
Old Feb 07, 2013, 10:55 AM
Shnokey is offline
Closed Account
Joined May 2004
Old Feb 08, 2013, 10:41 AM
joeyfly is offline
Find More Posts by joeyfly
United States, NV, Sparks
Joined Feb 2013
Awesome detail Man.
joeyfly is offline Find More Posts by joeyfly
Old Feb 08, 2013, 01:09 PM
Shnokey is offline
Closed Account
Joined May 2004
As Nemo dumps 30+ inches of snow in my backyard, I used thick CA and glued the first prop together using a homemade jig. The jig uses small nails that get glued right to the prop, then removed later – the series of images are from stacking the prop, rough sanding, medium sanding and 10 (yes 10) coats of thin CA to soak into the wood and seal all the pores and small imperfections in the wood, and to add strength. The last pictures still need a 400 wet sand, a 600 wet sand and brass prop tips before being balanced and coated with 2 coats of satin poly (maybe gloss if it looks right) - the two blades were measured with a micrometer for thickness and chord. Best I can do – I’ll set up a motor and battery to test them in the stand before I use them – If you have never made a prop before – it has to be on your bucket list.
Shnokey is offline
Closed Account
Joined May 2004
One more pic
Old Feb 08, 2013, 09:21 PM
Lnagel is online now
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Very nice. Looks like you did a proper job.
Larry
Lnagel is online now Find More Posts by Lnagel
Old Feb 09, 2013, 07:14 AM
Shnokey is offline
Closed Account
Joined May 2004
Thanks!!! - That means a lot to me - - - - Three more to go -
Old Feb 09, 2013, 07:53 AM
Jecull is offline
Find More Posts by Jecull
Jecull's Avatar
Joined Apr 2009
Beautiful work Jon. I'll try out those tricks on the Mercedes prop I have.
Jecull is offline Find More Posts by Jecull
Discussion Hanger 9 Sopwith Camel AndyCross Glow to Electric Conversions 92 Dec 04, 2012 05:34 PM
Sold Hangar 9 Sopwith Camel FLYBOB54 Aircraft - Electric - Airplanes (FS/W) 7 May 05, 2012 08:02 PM
Build Log AerodromeRC 1:9 Scale Sopwith Snipe Proto Build Wolpertinger Scale Kit/Scratch Built 145 Jul 10, 2009 08:28 AM
Build Log New AerodromeRC 1/9 Sopwith Camel sleonard Scale Kit/Scratch Built 15 Sep 14, 2006 05:22 PM
Discussion AerodromeRC 1:9th scale Sopwith Camel AerodromeRC Scale Kit/Scratch Built 3 Feb 20, 2006 02:09 AM
