Old Nov 20, 2012, 07:11 AM
Bill Glover's Avatar
Bracknell, Berks, UK
Joined Nov 2000
Originally Posted by Soul Reaver View Post
Are there no problems with thos wires without plastic? Are they insulated?
They would be lacquered - like motor windings.
Bill Glover is offline Find More Posts by Bill Glover
Old Nov 20, 2012, 07:13 AM
Joined Nov 2000
Originally Posted by mikefromgermany View Post
Don't be afraid of the Gamepad-TX - it is really better than it looks.
And of course you can remove the dummy antenna to make it even more compact.
Old Nov 20, 2012, 07:14 AM
Joined Jan 2012
I'm asking because I bought these for v929 http://www.banggood.com/Wholesale-4-...r-p-51434.html and they have same wires.
Thanks.
You can also use Kynar wire : http://stores.ebay.com/AngelSix/_i.html?_nkw=kynar
I always use it on my micro hybrids.
mystman is offline Find More Posts by mystman
Old Nov 20, 2012, 07:17 AM
Joined Jul 2012
Thanks. Everyday I learn something new
On BG website it looks like those leds can be plugged directly to battery without adding any resistor. This is really good.
Soul Reaver is offline Find More Posts by Soul Reaver
Old Nov 20, 2012, 07:23 AM
topgearuk's Avatar
United Kingdom, London
Joined Dec 2003
I don't believe the antenna is a dummy as you can clearly see a cable running up the inside on mine!
topgearuk is offline Find More Posts by topgearuk
Old Nov 20, 2012, 07:25 AM
Joined Nov 2000
Open the back of the TX and you will see the wire ends flush with the base of the antenna. It's not connected to anything - purely cosmetic.
Old Nov 20, 2012, 07:26 AM
topgearuk's Avatar
Joined Dec 2003
Got me there! lol Haven't taken the back off, just could see the cable! As you were
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
T,
They apparently used a real antenna and then clipped the wire at the base. The antenna is not connected to the Tx at all. The Tx fcb has the printed antenna on the board itself. You can twist and pull out the antenna and you will see what we mean
See antenna printed on the fcb at the upper right next to the LCD in this photo:
...and this one with the antenna twisted and pulled out of the Tx:
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Nov 20, 2012, 07:28 AM
Joined Nov 2000
Yup I replaced mine with a blanking grommet
Old Nov 20, 2012, 07:35 AM
topgearuk's Avatar
Joined Dec 2003
I can tell you the range is around 500-600 (icle dot in the sky!) feet straight up! Stand in an empty field and claim as high as you can, it will go out of range start to fall and as soon as it's in range again it will level out and keep flying!
Old Nov 20, 2012, 07:44 AM
Joined Feb 2007
T,
Yes it will recover if high enough and out of range. The range is actually only about 150 feet LOS tested at its absolute best though This 9cm diameter micro would not even be visible to the naked eye at 500-600ft
Yea I know we men have this measuring problem
Cheers,
Jim
Old Nov 20, 2012, 11:46 AM
Former IAF pilot. Retired
kosem's Avatar
France, IdF, Paris
Joined Apr 2012
Crash kit for indoor flying in a tiny living-room!
A piece of foam, cable ties and some strong double sided tape.
Added weight: 1.2g.
kosem is offline Find More Posts by kosem
Old Nov 20, 2012, 12:00 PM
Step 1: Tear it apart
MassiveOverkill's Avatar
United States, FL, Melbourne
Joined Feb 2011
Added weight: 1.2g.
Nice zip-tie guards They kind of make the X4 look like a water bug.
MassiveOverkill is offline Find More Posts by MassiveOverkill
Old Nov 20, 2012, 12:18 PM
topgearuk's Avatar
Joined Dec 2003
Originally Posted by jesolins View Post
T,
Cheers,
Jim
Yes I agree about 150 feet side to side, but I reckon I was about 8-10 average tree heights up before it lost range, I was almost right above the TX, as I said a little dot in the sky! Maybe yours is smaller then mine!
Old Nov 20, 2012, 12:39 PM
Joined Nov 2012
nice! Im a newbie here and I just joined.In modelzone you get it real cheap.How much was yours?and will the thing do flips?
Aryan Gangurde is offline Find More Posts by Aryan Gangurde
Discussion Hubsan x4 6axis scousethief Mini Multirotors 290 May 18, 2013 12:54 AM
Discussion The Hubsan X4 youxif Multirotor Talk 46 Mar 24, 2013 12:20 AM
Discussion Hubsan X4 Mini Quad dc9guy Mini Multirotors 32 Feb 04, 2013 10:14 PM
Discussion Hitec X4-80 eighty 4 port chager review search Timewarp Batteries and Chargers 4 Jun 22, 2012 04:20 PM
