Old Feb 16, 2013, 04:49 PM
fpsazerbaijan is offline
Find More Posts by fpsazerbaijan
FPV Noob
fpsazerbaijan's Avatar
United Kingdom, Scotland, Aberdeen
Joined Jun 2011
Anyone know if there's a multi-battery charging cable that fits the Hubsan connectors? Something like this:
Charging 6 lipos with the standard USB lead is a bit tedious
-Al
fpsazerbaijan is offline Find More Posts by fpsazerbaijan
Old Feb 16, 2013, 05:05 PM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
-Al
http://www.ebay.com/itm/Walkera-6s-C...item3f1dbf12d0 balanced adapter
http://www.ebay.com/itm/1-to-5-Charg...item3f1d87fa15
parallel adapter
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 16, 2013, 05:07 PM
Roblister is offline
Find More Posts by Roblister
North West UK
Joined Nov 2010
-Al
I think I would be happy enough to get hold of half a dozen of the connectors to make up my own leads. At the moment I have the original charging lead with the USB bit removed and two 3.5mm plugs fitted so I can charge the batteries on a decent charger.
Roblister is offline Find More Posts by Roblister
Old Feb 16, 2013, 05:12 PM
Germany, Berlin
Joined Jun 2012
http://www.ebay.com/itm/10-x-Losi-Mi...6&cmd=ViewItem
-mike-
Old Feb 16, 2013, 08:33 PM
Firepower is offline
Find More Posts by Firepower
Firepower
Firepower's Avatar
North Brisbane, Australia
Joined Mar 2010
I have a wl949 and it will hover basically in one spot but my Hubsan you lift it off and it drifts. I adjust the trims and still drifts a different way. I got it second hand so do not know what has happened to it.
It flies great in the back yard.
I guess the Hubsan you should be able to lift it up a couple of feet and it should hover in the one pl;ace.
Is that correct?
Firepower is offline Find More Posts by Firepower
Old Feb 16, 2013, 08:43 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Hi F,
Did you do the ET mod?
--Improving Hubsan X4 flight performance 101
Yes when it is setup properly and everything is in good shape it should eerily float in front you for at least 5-19 seconds.
You should also be able to do very fast yaw spins in place in expert mode set to 100% rates when you have the accelerometer properly calibrated.
Cheers,
Jim
Quadrocopter and Tricopter Info Mega Link Index
Is that correct?
jesolins is offline Find More Posts by jesolins
Old Feb 16, 2013, 10:11 PM
skipper1 is offline
Find More Posts by skipper1
United States, TX, Dallas
Joined Jan 2012
Once in a while someone asks how to get the props off. It can be challenging. I want to show you a tool I found at Harbor Freight today, I think it was in the plumbing section. It cost a whopping $1.49. On one end you can see the pry bar. Perfect for getting those pesky props off. On the other end (you can't see it) there is a slot to stick wire in to bend to the shape you want.
Just thought I'd share a cool, inexpensive tool.
I've never posted pictures before so I don't know if this will work.
[ATTACH][ATTACH][ATTACH]Name: IMG_1653.JPG
Description: [/ATTACH][/ATTACH][/ATTACH]
skipper1 is offline Find More Posts by skipper1
Old Feb 16, 2013, 10:47 PM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Read here: http://www.rcgroups.com/forums/showthread.php?t=1734145
FyreSG is offline Find More Posts by FyreSG
Old Feb 16, 2013, 11:18 PM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
There was a post on pinching motor and props pop right off. Worked fine for me when I put Ladybird props on X-4. Ordered a couple sets of props as I like the shape but from Bang good. It will be awhile. I like this little guy and flys very well. This one is indoor for me. Black color and size making outside flying a bad idea.
dankar04 is offline Find More Posts by dankar04
Old Feb 17, 2013, 01:03 AM
Firepower
Firepower's Avatar
Joined Mar 2010
Originally Posted by jesolins View Post
Hi F,
Cheers,
Jim
Thanks Jim - I'll keep working on it.
Old Feb 17, 2013, 05:33 AM
FPV Noob
Joined Jun 2011
Thanks for all the tips guys! This one seems to be the cheapest by far: http://www.banggood.com/Wholesale-2-...l-p-51545.html
But, as it's from BG, I'll strip back the heat shrink and check all the connections
So, do I just plug all the lipos into that and charge as a 5s?
Cheers for all your help!
-Al
Old Feb 17, 2013, 06:40 AM
jesolins is offline
Joined Feb 2007
Hi Gents,
I refined that post. Every one has one of these to take the tight props off, so no need to buy anything:
--Micro prop removal made easy using wire cutting pliers 101
That link and more can be found in the Mini and Micro Multicopter section of the Quadrocopter and Tricopter Info Mega Link Index
Cheers,
Jim
Old Feb 17, 2013, 10:06 AM
Germany, Berlin
Joined Jun 2012
-Al
Hi Al!
As this connector from banggood is a parallel charging adapter you have to charge the packs as 1S with totaled up cap.
Look at RCG for "parallel charge" - and follow the security rules if unsure how to handle it.
The ebay-link I posted earlier http://www.ebay.com/itm/1-to-5-Charg...item3f1d87fa15 is an even cheaper parallel adapter than banggoods.
Checking the connections is always a good idea - but not necessary to remove the wrap - a cheap DMM (digital MultiMeter) is more than enough.
If you shouldn't have one - buy it for a few bucks - it has not to be a Fluke etc.... It will come in very handy in this hobby.
-mike-
Old Feb 17, 2013, 12:39 PM
davidevo50 is offline
Find More Posts by davidevo50
Canada, QC, Montreal
Joined Feb 2007
-Al
http://www.banggood.com/Wholesale-Ba...r-p-51891.html
I have the feeling that this balancer harness would be more appropriate for the job...
And it's even cheaper than everything else but it charges only 3 lipos at a time...
davidevo50 is offline Find More Posts by davidevo50
Old Feb 17, 2013, 12:57 PM
Germany, Berlin
Joined Jun 2012
I prefer balanced charging anyway under every circumstances.
It is safer and better for the batts. (Thats just MY opinion for certain reasons - so I will not participate at another starting charge method war).
-mike-
Discussion The Hubsan X4 youxif Multirotor Talk 98 Nov 29, 2015 05:19 PM
Discussion Hubsan x4 6axis scousethief Mini Multirotors 301 May 13, 2015 09:31 AM
Discussion Hubsan X4 Mini Quad dc9guy Mini Multirotors 32 Feb 04, 2013 10:14 PM
Discussion Hitec X4-80 eighty 4 port chager review search Timewarp Batteries and Chargers 4 Jun 22, 2012 04:20 PM
