Old Feb 06, 2013, 04:02 PM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Originally Posted by midelic View Post
I see you have different blades.You mixed original blades with others.....??...Is it working?
The picture makes more sense in proper context:
http://www.rcgroups.com/forums/showthread.php?t=1821591
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Latest blog entry: MassiveRC ZMR PDB
Old Feb 06, 2013, 04:31 PM
tonyroot729 is offline
Find More Posts by tonyroot729
United Kingdom, Wickford
Joined Feb 2013
Thanks for the info on the motors, all makes sense now, i will order a bunch from bg . . . what are the rubber feet you ordered? i did add some cut up sponge for a few flights but i did not do a great job of sticking them on so if there is something ready made???
thanks again.
tony.
tonyroot729 is offline Find More Posts by tonyroot729
Old Feb 06, 2013, 06:37 PM
djdavies83 is offline
Find More Posts by djdavies83
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
Haha you guys seen this?
http://www.rcgroups.com/forums/showthread.php?t=1826273
djdavies83 is offline Find More Posts by djdavies83
Old Feb 06, 2013, 07:38 PM
Ayodhya is offline
Find More Posts by Ayodhya
WRX STI V - EJ22 - 35.3 PSI
Ayodhya's Avatar
Malaysia, Selangor, Puchong
Joined Nov 2012
Hey MO,
Just wanna clarifY, so to prevent the motor cap at the bottom from popping off should the plastic cap of the motor at the bottom be glued to the bottom of the motor arm on the frame?
Ayo
Ps there's a black piece on the outside of your arm..err what's that ?
Ayodhya is offline Find More Posts by Ayodhya
Old Feb 06, 2013, 07:47 PM
Joined Feb 2011
Hey Ayodhya,
We were talking about securing the rubber bumpers to the quad, so I suggested gluing them on. The rubber bumpers could possibly help in preventing the motor caps from popping off, but the verdict isn't out on that benefit yet.
Those are zip-tie prop guards........see my blog on making prop guards (not the prop-motor guards, just prop protectors)
Site Sponsor
Old Feb 06, 2013, 08:07 PM
Ayodhya is offline
Ayodhya's Avatar
Joined Nov 2012
Hey Ayodhya,
Oh ok lol, seems like i misread Ooops!
I've been using your straw mod since day one, Gotta hand it to you, its a life saver! Cheers for that!
Will try super glue on the cracks.. I've noticed that the most prone to cracks area are the bottom of the feet.. Happens even when I push in the motor too deep into the holder...
Qsn anyone have a Clue about the ds4u fpv version.. Even if it does come out , I doubt I'll buy from them but I'm sure others will sell it too, so is this fpv version done just by them if it indeed ever comes out or will it be available anywhere. If i can find what cam setup they use on this supposed fpv version of the x4... I can just fashion my own bottom hull with the extra space to accommodate camera using CAD software like solidworks and just 3d print it so you can just snap the bottom piece of the hull to the existing original top hull using the screws on the same connecting point as original...
Ayo
Old Feb 06, 2013, 08:24 PM
jackpm is offline
Find More Posts by jackpm
Bosons not included
jackpm's Avatar
Joined Dec 2012
How to prevent foot cracking
Take a look at the picture. You will never worry about cracking the feet again.
Earplugs.....
jackpm is offline Find More Posts by jackpm
Old Feb 06, 2013, 08:50 PM
Ayodhya is offline
Ayodhya's Avatar
Joined Nov 2012
Earplugs.....
Thanks but I did the Adhesive based rubber tabs which were for me easier, you'll find it in jims mega index. I was referring to fractures not from impact but from pushing the motor in too deep
Old Feb 06, 2013, 10:31 PM
GhostMaster is offline
Find More Posts by GhostMaster
Portugal
Joined Feb 2012
I got a rebranded Heliguy Viper today, great little machine, it rocks, very stable and powerful.
Already done the ET mod and motor mod.
GhostMaster is offline Find More Posts by GhostMaster
Reply With Quote  (Disabled)
Old Feb 06, 2013, 10:51 PM
AnthonysQuad is offline
Find More Posts by AnthonysQuad
Happy Holidays
AnthonysQuad's Avatar
Joined Jan 2013
I was thinking of heat shrinking around the motors and just wideing up the holes a little but havent went along with the idea.even better though would just replace that area of the frame with some sort of rubber that is molded the same.i think that would really solve alot of vibrations and damage and be worth the slight weight increase.just the area that holds the motors.can you make a mold for something like that on the 3d printer to do that?im talken about the area that is below the top circles.it really help.
AnthonysQuad is offline Find More Posts by AnthonysQuad
Old Feb 07, 2013, 04:35 AM
mikefromgermany is offline
Find More Posts by mikefromgermany
Not here to help stupids
mikefromgermany's Avatar
Germany, Berlin
Joined Jun 2012
Ayo
Why messing with it? Wait some time and order a FPV-Set for your Eye One.
-mike-
mikefromgermany is offline Find More Posts by mikefromgermany
Old Feb 07, 2013, 08:04 AM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
From my sources Amerang (the uk supplier of Hubsan) will first be releasing a Micro SD card recording version, then the FPV version, either way this will be sometime AFTER March, no idea where "disappointment"source4U go their idea of when they
will have them.
An eBay member (Nigel299) I trust will be stocking the FPV version once Amerang pull their figure out start supplying it, he stocks props and will soon have motors too, I'm still waiting on mine from china.
Old Feb 07, 2013, 07:15 PM
Happy Holidays
Joined Jan 2013
Cut a pen and soldered the wires to the led.sliped the led holder in with bulb.cut a little knocth on the side then added back led cover to macth front
Heres the overpriced leds from radio shack.5mm high brightness white led is what it says on the front.heres the back.
Last edited by AnthonysQuad; Feb 07, 2013 at 07:22 PM. Reason: [IMG]http://i1210.photobucket.com/albums/cc408/boulderopalhunter/IMG_20130207_190120.jpg[/IMG]
Old Feb 08, 2013, 10:52 AM
jason4207 is offline
Find More Posts by jason4207
Eye to the sky!
jason4207's Avatar
United States, NC, Concord
Joined Dec 2012
Well, my X4 is out of commission again. My buddy stopped by and I was showing it off. I took it outside to show him it's speed. The grass was wet, so I just stayed in the front yard instead of going to the back where there is a lot more room. I was zooming along and hit the brakes, but hit them too hard and did an inadvertent flip right into the side of my work van and then onto the concrete. 1 of my cracked motor mounts lost a piece of plastic and the bottom of that motor got busted out. My motor guards were not long enough for the Ladybird props. I was using U816 props and they were just right, but then I switched to the LB props which apparently don't go as far down the shaft. I should have made new guards.
The adjacent motor guard did it's job, but was destroyed in the wreck. Not sure where it flew off to.
Everything I need and plenty of spare parts to get all my aircraft back in the air is en route to me from BG. I ordered on 1/24, so I'm really hoping those parts come in today or tomorrow. My order from 1/14 came in less than 2 weeks, so I'm really hoping my latest order will be waiting for me when I get home. Fingers crossed!!!
In other news another friend of mine was so impressed with the X4 that he has placed an order. So, hopefully I'll have someone else to go flying with soon!
jason4207 is offline Find More Posts by jason4207
Old Feb 08, 2013, 04:32 PM
nostromo2106 is offline
Find More Posts by nostromo2106
Joined May 2010
A little Video
Hubsan X4.mp4 (3 min 30 sec)
Gruß Willy
nostromo2106 is offline Find More Posts by nostromo2106
Discussion The Hubsan X4 youxif Multirotor Talk 98 Nov 29, 2015 05:19 PM
Discussion Hubsan x4 6axis scousethief Mini Multirotors 301 May 13, 2015 09:31 AM
Discussion Hubsan X4 Mini Quad dc9guy Mini Multirotors 32 Feb 04, 2013 10:14 PM
Discussion Hitec X4-80 eighty 4 port chager review search Timewarp Batteries and Chargers 4 Jun 22, 2012 04:20 PM
