Thanks Jason,
You may want to put a dab of Elmers glue or rubber cement on the rubber bumpers so the'll adhere to the motors and have less tendency to fall off. Your cracked motor mount.............were yours cracked as a result of crashing or did yours come that way out of the box? |
Latest blog entry: Making a Super Sized Frankenquad
Jason, hot glue is fine so long as you use it sparingly (it's heavy and adds weight) and don't get any strands in your props.......or at least remove them if you do. I hot glue around the motors to frame in order to try and reduce vibrations as well.
Ayodha, super glue should work just fine. MHM, what country are you from? Thanks. |
I added the same connector as main flight lipo & charge from my USB udiRC charger. |
Joined Feb 2013
I am in canada to��
Wow am I glad I found this forum. Tons of nice people and tons of info. I come from surface RC and have about 9 RTR trucks and cars. I bought a TRX QR-1 a month back or so, this was my first time flying anything I trashed it in 2 packs lol. Sent it away got it fixed as I wasn't comfortable soldering on such small stuff. After tons of reading I realized I got ripped off and bought a clone for twice as much. I got it back from TRX and lasted another 2 packs until I just threw it in the garbage and ordered a Syma X1. Wow is it ever fun and addicting. I've beat it up real good and still no issues. About 40 packs in it now. Getting better flying around now, but a total noob compared to the vids you guys have up. After using this syma I was wanting something faster and more responsive and smaller. I read tons of your reviews. Thanks to Massive RC and a few others a lot of your posts helped me decide. On order: Hubsan x4 w/ spare motors and mini cp landing gear V202 scorpion Ladybird v2 V939 6 turnigy nanotech lipos Can't wait to get them and fly them. When I get into a hobby I usually go all out lol. I see from reading that the possibilities are endless and there's tons of options and accessories. For now I will stick to these and just have fun with them and improve my flying skills. Most likely give my syma x1 to my son. Next in my sights is a ladybird v1 and ill use th devo 4 that comes with the v2. And also looking at the rc eye one, but confused with it as there are different models out there? |
Switzerland
Joined Sep 2008
Thank but it seems backorder since age... You are not efraid to burn your lipos with this chrager (too many amps) ?? |
Joined Feb 2013
Hi guys, fixing motors . . i have killed a few of these motors now and have swapped out my last spare so i got to wondering if there is a simple way to fix the motors when the bottom pops off? I will put in another order for spares and i was thinking maybe a dab of super glue would stop them breaking on hard "landings" but if i could bring back the four dead motors i have it would be a good idea. also, the difference between CW and CCW . . is that simply the wiring the other way round? Please forgive if this has been covered in the 161 previous pages but a search was not really my friend ...
I was worried about using hot glue on the rubber feet thinking it might get caught up in the wires and make disassembly very difficult; the wires might get pulled out. Thoughts? Seems like rubber cement would be best, but I'll try Elmers glue since I have that on hand. Quote:
I also thought about using CA on the motors, but never did. Ever since I installed the rubber feet I haven't broken a motor...even after some hard landings on asphalt. These little motors have finger brushes. CW and CCW motors have the brushes aligned such that the armature spins toward the end of the extending fingers. If you have a motor open you can see what I'm talking about. Reversing the wiring will cause it to spin the opposite direction, but the armature will be turning in an un-ideal way against the brushes. It'll work, but the motors won't last as long. Be careful, no matter what you do. I ended up breaking off 1 wire while trying to repair a motor. ![]() I have 2 full sets of 4 motors coming in from BG, but I got impatient and went to my LHS and picked up an arm+motor for an 1-SQ. I only needed 1 motor to get back in the air. It was $10, but the itch needed scratching, so I jumped on it, and since I had just received the rubber feet I was even more anxious to get back in the air to try them out. |
![]() If you only glue areas on each side of hte motor wires, you should be OK. |
| Thread Tools | |
| Discussion Hubsan x4 6axis | scousethief | Mini Multirotors | 290 | May 18, 2013 12:54 AM |
| Discussion The Hubsan X4 | youxif | Multirotor Talk | 46 | Mar 24, 2013 12:20 AM |
| Discussion Hubsan X4 Mini Quad | dc9guy | Mini Multirotors | 32 | Feb 04, 2013 10:14 PM |
| Discussion Hitec X4-80 eighty 4 port chager review search | Timewarp | Batteries and Chargers | 4 | Jun 22, 2012 04:20 PM |
