Old Oct 01, 2012, 12:13 AM
sobellamc is offline
Find More Posts by sobellamc
Joined Sep 2012
Great Planes Sukhoi Su-31 25%
Hello everyone, I'm new to the sport and I now have the bug and can't stop buying planes. I need help though. I just had this SU-31 built and want to know if the recevier and transmitter are adequate for this plane. I have a spectrum DX7-S with the AR8000 receiver. The servos are JR8611. Dual servos on both tail surfaces. If I eventually fly this plane 3D will it be too much for the recevier to handle. Please forgive me if I did not give enough details. Please advise.
sobellamc is offline Find More Posts by sobellamc
Old Oct 01, 2012, 08:21 AM
Lumpy05 is offline
Find More Posts by Lumpy05
Lumpy05's Avatar
United States, IN, Bloomington
Joined Jan 2012
The receiver should be great, its one of Spektrums best and is their "high speed" variety. The servos should also be good, digital and high torque.
I just flew my new to me 25% Extra this weekend with DX8 and AR8000 with Hitec digital high torque servos. One other thing to mention I used a 6.6v LiFE A123 receiver pack, the higher voltage and high discharge capability of the pack worked great. The plane was super responsive although I havent tried any real 3D yet.
Lumpy05 is offline Find More Posts by Lumpy05
Old Oct 01, 2012, 09:47 AM
Joined Sep 2012
Thanks for the info. I was told that the receiver probably couldn't handle the load if too much was going on at once. I'm running a 6 volt 4500 for it. Is a 4.8 ok for the ignition module. I have a DA-50. I read that a 4.8 and 6.0 work fine for this engine
Old Oct 02, 2012, 12:34 PM
Gray Beard is offline
Find More Posts by Gray Beard
Joined May 2012
The 4.8 on the ignition is fine, the ignition is designed for either or. If an ignition battery poops out on you the worst thing that happens is you have a dead stick landing.
Really, the worst thing for me if one goes out and I don't know it is my arm gets tired trying to start it!! Doesn't take me too long to figure out I have a bad pack though. I can't keep flipping like I used to.
Gray Beard is offline Find More Posts by Gray Beard
Old Oct 02, 2012, 09:20 PM
Joined Sep 2012
Thanks for the info. I have one more question. I have the drill guide for the prop. Does this require a drill press or does the guide keep it straight enough?
Old Oct 03, 2012, 11:12 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
drill press is not necessary, but I would use one (or have someone with one to drill those holes). A prop that isn't drilled correctly can make installing the bolts difficult.
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ 112" Beaver
Sold Great Planes SU-31 25% (ARF) hobbyfun100 Aircraft - Fuel - Airplanes (FS/W) 2 Aug 07, 2012 12:46 PM
Sold Great Planes SU-31 25% (ARF) hobbyfun100 Aircraft - Fuel - Airplanes (FS/W) 0 Jul 29, 2012 01:53 AM
For Sale 25% Great Planes Sukhoi 31 Blakez Aircraft - Fuel - Airplanes (FS/W) 4 Jun 30, 2012 09:56 AM
Discussion Great Planes 25% Sukhoi SU-31 WindGap 3D Flying 0 Nov 06, 2011 07:31 PM
Found Hangar 9 1/3 Sukhoi or Great Planes Sukhoi Su-31 Performance Series GP/EP ARF muskis2 Aircraft - Fuel - Airplanes (FS/W) 0 Oct 03, 2009 01:27 PM
