Old Sep 30, 2012, 10:55 PM
uspsjuan is offline
Find More Posts by uspsjuan
mailman
United States, TX, La Marque
Joined Aug 2012
norvel .074 break in
I have run 3 tanks of 25% nitro through this engine and although it seems to be running fine, i just can't seem to get it to get above 12500 RPM. manuel says i should get close to 17000 running a 7x3. i am running a 6x3. Any advice would be helpful. thanks
uspsjuan is offline Find More Posts by uspsjuan
Old Oct 01, 2012, 12:28 AM
surfer_kris is offline
Find More Posts by surfer_kris
surfer_kris's Avatar
Sweden
It sounds like something is seriously wrong. Check for head leaks or a bent conrod etc.
surfer_kris is offline Find More Posts by surfer_kris
Old Oct 01, 2012, 11:33 AM
uspsjuan is offline
mailman
Joined Aug 2012
new engine. was thinking about removing one of the head shims, or seeing if i can find some 30% nitro fuel.?
Old Oct 01, 2012, 12:41 PM
GliderJim is offline
Find More Posts by GliderJim
GliderJim's Avatar
Michigan, USA
Joined Jul 2006
You certainly don't need more nitro - something else is wrong. Did you start it with an electric starter? You could've bent the rod that way. Remove the back and take a look.
GliderJim is offline Find More Posts by GliderJim
Old Oct 01, 2012, 01:20 PM
Sweden
The engine will do +17000rpm on a 7x3, with three head shims and 10% nitro, if anything the nitro level might be too high...
Make sure that you use at least 20% oil, all castor.
Old Oct 01, 2012, 04:25 PM
uspsjuan is offline
mailman
Joined Aug 2012
using Hobbico 1/2 A fuel, 25% nitro. a major pain to take the engine out of the airframe to open up the back to check for a bent con rod. I will try another tank or two of fuel to see if things improve. will keep you posted
Old Oct 01, 2012, 06:09 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
Erm I'm thinking that you would need a.. quart.. of Fuel run through it,
Before believing that it's Broken in.
Bare is offline Find More Posts by Bare
Old Oct 01, 2012, 09:50 PM
GliderJim's Avatar
Michigan, USA
Joined Jul 2006
Anyone ever figure out what percentage oil is in the Hobbico 1/2a fuel?
Old Oct 02, 2012, 07:40 AM
uspsjuan is offline
mailman
Joined Aug 2012
The bottle does not say what oil the oil content is. I just know that the wing is an oily messn after i run a tank of fuel. l
Old Oct 02, 2012, 08:51 AM
Sweden
Tower says 18% of a special Klotz oil...
You can always add a little bit of castor to be on the safe side, the amount of oil on the wing doesn't tell anything...
Old Oct 03, 2012, 07:44 AM
OkiThumper is offline
Find More Posts by OkiThumper
Closed Account
Joined Feb 2006
It may be something as simple as needing additional run time.
OkiThumper is offline Find More Posts by OkiThumper
Old Oct 03, 2012, 10:46 AM
Dave Campbell is offline
Find More Posts by Dave Campbell
United States, MI, Commerce Charter Township
Joined Dec 2000
These engines are notorious for being both very tight at TDC and wearing like iron during break in. This is bad because the first runs ideally need the cylinder warmed with a hot air gun before cranking to prevent crank damage. Even after 2 seasons of flying, mine will still lock solid at TDC because the pinch is still that tight..... I am turning an APC 6.3-4 at about 16,500 on 30%, which is about 1k short of what the guys on RCU say I should get when the engine is worn in. Apparently, the .074's just decide to 'wake up' one day and make good power, but I haven't seen it yet. I have like, 9, of these engines and am hoping that they don't all go this long to being run in.... All that said, I am very happy with the power and performance of the one I am flying.
12k tells me something is wrong with your motor. I'd suspect a bent rod, an air leak, or a tight fit on the crankshaft fit.
Dave Campbell is offline Find More Posts by Dave Campbell
Old Oct 03, 2012, 11:48 AM
Closed Account
Joined Feb 2006
As you say, it is possible for hidden damage or correctable defect along the way. The tightness issue sort of reminds me of the old days, where one would run their piston / sleeve lapped motors, running rich (then called "4-cycle") accumulating at least 1/2 hour run time prior to flying. Otherwise, one could not maintain full speed by leaning out the needle.
If no damage or leak, perhaps the solution is to fly, running slightly rich, accumulate some time on it then recheck RPM?
Also, another possibility is if the OP lives at an elevation greater than 2,000 feet (610 m), there is a corresponding loss in horsepower, due to the thinner atmosphere. At for example, 4,300 feet (1 310 m), the air pressure is about 12.5 psia (0.85 atm) versus 14.7 (1 atm) at sea level. At 6,500 feet (1 981 m), it is 11.5 psia (0.78 atm). Change in elevation air pressure in atmospheres (atm) is proportional to the power produced. Figuratively speaking, figure on about a 15% power loss at 4,300 feet, a 22% power loss at 6,500 feet, and etc.
Therefore, the RPM at elevation will be naturally less than at sea level. If this is the case, then a 3,000 to 4,000 drop in RPM may be considered normal. This is why flyers at elevation will normally replace an engine with one the next size up. (Example, .061 for a .049, a .30 for a .25, a .46 or .50 for a .40, etc.)
The other option that sometimes works is to substitute the largest diameter prop permissible by the engine manufacturer. Propeller performance is much more noticeable at elevation than at sea level.
Old Oct 03, 2012, 02:33 PM
gkamysz is offline
Find More Posts by gkamysz
Dieselized User
gkamysz's Avatar
Chicagoland
Joined Feb 2000
Elevation has nothing to do with engine RPM on a given prop. As elevation increases the air density decreases both the engine and prop work with the reduced density. Engine power output does drop, but so does the required torque to drive the prop. The result is virtually no change in RPM with air density.
I suspect a bent rod. The engine will have to come out sooner or later. 12kRPM on a 6x3 is less than 50% the power it should make. This indicates a problem be fixed not additional break-in time.
Greg
gkamysz is offline Find More Posts by gkamysz
Old Oct 03, 2012, 03:26 PM
Sweden
You might have to much nitro in the fuel, mine does +17000rpm on that prop and 10% nitro. Check the number of shims and optimize for top top revs, staying on the side of slightly too low compression.
Another thing to look for is the throttle barrel, it is important that it lines up with the carburator bore at full throttle. It can be off sideways, as it rotates on it's threads, or it might not open fully if you have the throttle stop screw still installed (just remove it, it is not needed).
A cox babe bee will do more that 12000rpm on a 6x3, there is certainly something seriously wrong...
Take off the engine from the plane and run it in on bench before you put it in a plane.
Discussion Fuel for Norvel 074 wilevi93 1/2A Planes 17 Apr 28, 2012 07:05 AM
Sold Norvell big mig .074 rc engine Spaceshuttle1 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Mar 06, 2012 12:37 PM
For Sale NIB Norvel .074 with wrench Greyout Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 04, 2012 09:47 AM
Cool Norvel .074 in HOB Spacewalker John_R_C 1/2A Planes 2 Nov 13, 2003 11:34 AM
