This thread is privately moderated by byxnplanes, who may elect to delete unwanted replies.
Old Sep 30, 2012, 09:59 PM
byxnplanes is offline
Find More Posts by byxnplanes
Victown SkyDonkey
byxnplanes's Avatar
Victoria, BC
Joined Jan 2010
Guanli PBY Catalina Build and Mods
I ordered Guanli Catalina from HobbyKing a month or so ago. I wanted something I could fly off of grass and also get my feet wet, so to speak. The Canadair was heavily back ordered, so I ordered this one instead; I've always liked Catalinas.
Progress will be slow, but I will update my mods as I plug along.
-Nose turret added
-Glassed the bottom
-Added faux-wheels to the side of the fuse in the appropriate places
-Reinforced wing-screw plate in the fuse with gorilla glue
-nacelle fire walls made to mate onto stock wooden stick mounts
byxnplanes is offline Find More Posts by byxnplanes
Old Nov 21, 2012, 10:53 PM
agedflier is offline
Find More Posts by agedflier
Australia, VIC, Bendigo
Joined Jan 2012
Hello there..Im thinking of buying one too..Can you tell me how and why you are changing the engine pods?? I also like your nose mods..I might just do the same and busy a wheel and 1/2 it to make it look more scale...Any more info on the finished project?
-Nose turret added
-Glassed the bottom
agedflier is offline Find More Posts by agedflier
Old Nov 24, 2012, 11:27 AM
Victown SkyDonkey
byxnplanes's Avatar
Victoria, BC
Joined Jan 2010
Hi agedflier,
The idea behind adding firewalls to the nacelles instead of going with the stock stick mounts was to stiffen up the whole area. As soon as I dry-fit all the stock parts together, I could tell the nacelle structure wouldn't be very strong. I could envision easily damaging the structure during transportation, as I plan on making the wing detachable to fit in my car. By attaching in the stick mount to the firewall and attaching the fire wall to the inner diameter of the nacelle foam, it will all be quite rigid, decreasing the motor vibration and adding support to the nacelle structure. Gorilla glue is the attachment method of choice, since it will expand into any little void and bond very securely once it's crept in there.
Note: if you want to attempt this mod, the most important part is aligning the stick mount and the firewall, square to the direction of the nacelle. I did this by tracing a ring on the inner diameter of each nacelle, where the firewall should line up. I added gorilla glue to base of the stick mount and the stick-firewall connection, then dry fit the nacelle pieces in place, making sure I kept the firewalls aligned with the traced ring in the nacelle, as the glue cured.
Not much progress in the last few weeks, as I am a mechanical engineering student and spend most of my time at that... The latest progress was getting the firewall/stick mount aligned and glued, and making channels under the wings for wiring to the nacelles and servos. I'm waiting for a sh*t load of wire from Hobby King so I can start planning the plumbing soon.
This guy's video is a good reference. He did a nicer job on his cockpit windows. And lots of other details that I probably won't get around to. Had I seen this before my build I would have used a few of his ideas... oh well.http://www.youtube.com/watch?v=TpanA...ure=plpp_video
If you haven't seen this build it's also a good reference. Orion Pax did a great job building MERLIN V16's catalina. http://www.rcgroups.com/forums/showthread.php?t=1120564
Cheers,
Neil
Old Nov 27, 2012, 07:37 PM
Joined Jan 2012
Hello byxnplanes..Thank you for your advice..That idea did come to me when I decided to electrify my Guillows DC-3 ....The Guillows "Cat" in the forum seems to be a big project but lots of clues there on "how to" Hope you like the DC-3 so far..
Old Nov 19, 2013, 04:00 PM
divemarc is offline
Find More Posts by divemarc
Germany, Berlin
Joined Jan 2012
Hi
Ordered one from the european warehouse, too.
Flies like a charme. Loads and loads of fun!
HK Catalina maiden (3 min 8 sec)
divemarc is offline Find More Posts by divemarc
Old Oct 06, 2014, 09:07 PM
garryk is offline
Find More Posts by garryk
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
I just did my maiden yesterday and the elevator servo is sticky. It won't center. It may be because of the way the linkage is routed. Anyone else have this trouble?
garryk is offline Find More Posts by garryk
Old May 11, 2015, 03:29 AM
Frits37 is offline
Find More Posts by Frits37
Joined May 2015
To the sticky long rods: I detached them, pulled them out of the tubes, greased them with WD40 and put them back in the tubes again. Spraying WD40 into the tubes didn't seem like a very good idea to me . They move much more easy now.
Frits37 is offline Find More Posts by Frits37
Old May 11, 2015, 04:07 AM
garryk is offline
Corsair Captain
Joined Oct 2010
It might be a good short term fix, but I have the same problem and did the same thing. Haven't flown it for months because there's been no water in the basin I fly it at. Love the plane, but will address the elevator fix when I have more time. Good luck with it. and happy landings.
Cool Guanli PBY Catalina amphibian wheel mod demondriver Electric Warbirds 2 Aug 19, 2011 12:15 AM
Discussion Guanli PBY Catalina fcollingwood Waterplanes 6 Jul 30, 2011 06:44 PM
Help! PBY Catalina (Guanli) Brushless Suggestions dmoench Electric Warbirds 4 Jun 19, 2009 01:25 AM
Help! Brushless setup for PBY Catalina (Guanli) dmoench Power Systems 2 Jun 19, 2009 01:22 AM
Video Guanli PBY Catalina colbourne Electric Plane Talk 9 Sep 04, 2008 10:03 AM
