This thread is privately moderated by rockhound1218, who may elect to delete unwanted replies.
Old Sep 30, 2012, 07:23 PM
rockhound1218 is offline
Find More Posts by rockhound1218
rockhound1218's Avatar
United States, CT, Meriden
Joined Feb 2010
Some Pics
rockhound1218 is offline Find More Posts by rockhound1218
Old Oct 27, 2012, 01:05 AM
Tsavah is offline
Find More Posts by Tsavah
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Nice Wheels
Looks interesting. Will you be adding some more information about the process, tools, and materials? Thanks.
Tsavah is offline Find More Posts by Tsavah
Latest blog entry: Center of Gravity - Airplanes
Old Oct 31, 2012, 03:42 PM
Joined Feb 2010
Wheel Making 2"
Sure I did not see your post or I would have responded sooner.
The wheels were made Using PVC pipe then grooved the rim for the tire.
Wrapping paper around the PVC rim gave the exact circumference, then divided into equal sections for the spoke holes
The hubs were made from brass tube and washers
Spokes - Heavy Carpet Thread Ca soaked
Tires were made using round window weatherstripping abit over sized for that scale, so I tried some "craft foam sheets" and laminated them and sliced off a strip and glued it to form the tires.
If you have any Questions I will try to answer them
Old Oct 31, 2012, 03:53 PM
Joined Feb 2010
The foam craft sheet tire was spun and sanded , taking the square corners off.
Cheep ! and they look OK too
Old Oct 31, 2012, 04:02 PM
Joined Feb 2010
Painted and dirtied up a little.
I should have used Grey craft foam for the scale tyres. Next time.
This Plane was just a test for a larger Nieuport 12 I am Building.
Some "issues" were found along the way saving me alot of time.
Old Nov 05, 2012, 04:31 AM
Tsavah is offline
Watt Waster
Tsavah's Avatar
Joined Oct 2010
Nice Tires and Wheels
Nice work. I haven't gotten back into the WW1 aircraft yet, so at the moment I am just collecting information for later. Seen a few show and tell, but the key seems to be using a jig to keep things centered.
Old Nov 05, 2012, 07:02 AM
Joined Feb 2010
Yes you are correct,
Without using an accurate means to hold the central hub, a concentric wheel will not happen.
The "pins and shims" method did not produce acceptable results....a more stable jig was required.
The more stable the tighter the spokes can be laced.
I spun the jig using MDF board on my lathe. and was able to spoke both sides of the wheel without removing it from the fixture. Even using the "better jig" keeping even tension on the spokes was critical. Plucking each spoke evens out the tension before locking in position with CA or Epoxy.
A few years back I stress tested up to 30lbs on a pair of 3" wheels. I used guitar strings for the spokes. I guess it's the "side load" that causes most failures. I haven't figured a way to accurately measure side force loads. But that style of wheel worked well on a 2lb. Plane.
Luckily most WW1 Planes had the shrouds covering the wheels so the spoked effect can be faked.
Discussion So the Nina and the Pinta were in town recently, how about some pics? bgnome Dock Talk 4 Jun 04, 2012 12:05 AM
Gallery Some nice large-scale navy models..PICS Steve Bad Dock Talk 1 Jun 02, 2012 03:35 AM
Discussion I rewound the c05 but need some help on the results. PiCS mescalinedream Electric Motor Design and Construction 7 Apr 26, 2012 04:53 PM
Help! A few pics, a video and some questions :) Denominator Multirotor Talk 14 Apr 02, 2012 04:18 PM
Discussion Some farm pics the Old School way.. P-51 fan Aerial Photography 4 Mar 31, 2012 05:03 PM
