Old Sep 30, 2012, 06:02 PM
tigreflyer is offline
Find More Posts by tigreflyer
Joined Apr 2012
Norvel, NV AMD .049 CL engines your experience?
These look pretty good, and have a good reputation. But how do the stack up to a TD or a Killer Bee?
tigreflyer is offline Find More Posts by tigreflyer
Old Oct 01, 2012, 08:39 AM
OkiThumper is offline
Find More Posts by OkiThumper
Closed Account
Joined Feb 2006
They are better, IMO.
OkiThumper is offline Find More Posts by OkiThumper
Old Oct 01, 2012, 09:58 AM
dankar04 is offline
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Norvel's are fine engines. They run, no fuss and out class Cox engines.
dankar04 is offline Find More Posts by dankar04
Old Oct 01, 2012, 10:39 AM
gcb is offline
gcb
Find More Posts by gcb
gcb
Joined Sep 2008
In most cases that is true, but if you go .049 for .049 I think you may find that the TD leads on large props.
Many tend to compare the TD .049 to the Norvel .061's, and that is not a fair comparison.
OTOH, Norvels have mufflers and throttles.
I like both.
George
gcb is offline Find More Posts by gcb
Old Oct 01, 2012, 12:02 PM
Bare is offline
Find More Posts by Bare
Canada
Joined Nov 2000
As stated above Cox engines date from our childhood and are loved as such.
Norvels are finely made engines, in the style/design of a decent large Glo engine.
Easier starting , faster and smoother than any most any TD.. right out of the box.
The AMD version Norvel is seriously faster than any TD could ever be.. a bit harder to source and a bit higher priced though than the 'regular' Norvels.
You will not be dissapointed is the quick answer. .
Bare is offline Find More Posts by Bare
Old Oct 01, 2012, 12:08 PM
Closed Account
Joined Feb 2006
Just curious, but will the Tee Dee .049 turn a 7x3 prop? That might put it at an advantage with a larger airplane, where pulling power in climb is more important than speed.
.061 is 24% more displacement. I would expect a similar corresponding increase in horsepower and torque.
They do have versions with no throttles.
NVEngines.com Airplane Engines
I like both.
I compare engines to tools, there is proper place for all of them, depended on model size, weight, balance, power needed, etc. I especially like the reedies because they are easy to start, provide ample power for certain sport models, and some models just don't look right without them.
Last edited by OkiThumper; Oct 01, 2012 at 11:12 PM. Reason: Deleted stray signature
Old Oct 01, 2012, 08:40 PM
stuntflyr is offline
Find More Posts by stuntflyr
stuntflyr's Avatar
United States, AZ, Tucson
Joined Jun 2010
George has got it right, there!
A Dumas Lil Tiger with a Tee Dee with a Cox Gray 5x3 is pure nostalgic art.
My first Tee Dee was an 051 with the red case and a red plastic tank mount, it went on my red Lil Wizard. Perfection.
Conversely, a Consolidated Stuka with an OK Cub .074 with a Froom spinner and Grish Plasticote prop can really ease one's visual pain, too! a
Chris...
stuntflyr is offline Find More Posts by stuntflyr
Old Oct 02, 2012, 07:59 AM
Traian is online now
Find More Posts by Traian
Traian's Avatar
United States, GA, Roswell
Joined Mar 2008
I had a plane with NORVEL and it is a great litle motor (I won the first 1/2A NATS with a .049 Norvel). Cut the prop doun if it does not run good. They like smaller diameters and high revs. Also use 1/2A fuel.
Traian is online now Find More Posts by Traian
Old Oct 02, 2012, 08:10 AM
Closed Account
Joined Feb 2006
Inasmuch as the Tee Dees, AP's, ASP's and Norvels are great engines, I like the reedies. They like larger props (6x3, 6x4) and lower revs.
Old Oct 02, 2012, 10:01 AM
aspeed is offline
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
I think a Medallion might swing a bigger prop than most others too, for people that don't like the sweeter music. I think the Big Mig is made for lower revs than the real Norvels, but not as slow as the reedies and Medallion.
aspeed is offline Find More Posts by aspeed
Old Oct 03, 2012, 11:49 PM
Closed Account
Joined Feb 2006
I remember when Bill Winter was still alive, he was advocating that the manufacturers continue to make legacy baffle piston engines, because they were capable of spinning larger diameter propellers and were more fuel efficient than the Schneurles. He wondered why they didn't consider them as "High Torque Engines".
Old Oct 04, 2012, 07:20 PM
gcb is offline
gcb
gcb
Joined Sep 2008
Originally Posted by aspeed View Post
...I think the Big Mig is made for lower revs than the real Norvels, but not as slow as the reedies and Medallion.
Real Norvels?
NORVEL is an acronym for Northern Velocity. They imported both Big Mig and AME engines. There was another AME for combat called Zeus that was not handled by NORVEL AFAIK.
George
Old Oct 04, 2012, 08:59 PM
Joined Apr 2012
Dang Thump! Just when I figure a Norvel is my ticket, you post something like that! Must be that a TD or a Norvel or a hot rod reedie would be a great choice for a fine flying, light Baby Flite Streak.
Old Oct 04, 2012, 09:27 PM
aspeed is offline
Canada, ON, Cottam
Joined Jan 2012
I am keeping away from the reedies lately. I just have a couple of planes that would be overpowered with a TD or Norvel that I sometimes use. For the 2nd previous post- I have a Stels .049 that I got before the AME and Norvel stuff came out. It looks an awful lot like a Norvel except for the split rear exh. and 3 hold down bolts. I have suspicions that it may have been made in the same factory. I always thought the Zeuss was a 10 cc motor made in Russia (or the former Russia)
Old Oct 05, 2012, 10:39 AM
gcb is offline
gcb
gcb
Joined Sep 2008
I believe you are correct. Several engines of that era look quite similar. Here is the AME Zeus. It uses a standard plug, has no muffler, uses a fine needle, and has an .049 displacement:
George
For Sale Norvel engines 049 through 0.4, R/C or CL. Brandnew. Contact me for prices klondike17 Aircraft - Fuel - Engines and Accessories (FS/W) 6 Oct 15, 2010 08:05 PM
Wanted Cox .049 or cl engines wanted radman615 Aircraft - Fuel - Engines and Accessories (FS/W) 12 Apr 07, 2009 10:35 AM
Sold Norvel Engines - New & Used - C/L & R/C - .049 to .15 N925WB Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 19, 2006 10:10 AM
Engines: Super Tigre 90, Magnum Pro 45, Cox 049, Norvel V-Max 7 Hooters Driver Aircraft - Fuel - Airplanes (FS/W) 8 Dec 18, 2004 01:50 PM
Norvel .049 Big Mig parts engine for sale pokeypilot Aircraft - Fuel - Airplanes (FS/W) 0 Jun 17, 2002 06:07 PM
