Old Sep 30, 2012, 05:22 PM
FlyDude is offline
Find More Posts by FlyDude
I still get nervous on final
FlyDude's Avatar
Richmond, VA
Joined Mar 2007
Servo Life On 6 Volts
Does running a digital mini servo like the HS-5245MG on 6 volts contribute to premature failure? Or, are they rated for continuous 6 volt operation?
Thanks in advance,
BUD...
FlyDude is offline Find More Posts by FlyDude
Old Sep 30, 2012, 06:11 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Or, are they rated for continuous 6 volt operation? Thanks in advance, BUD
They are rated for continuous 6 volt operation, bearing in mind that the higher the voltage,
the higher the speed produced which in turns results in more heat, together with faster
wear and tear on gear train.
. Servo - Operating Voltage Range - (Hitec) .
includes usage with NiMH, Lipol & A123 batteries
MG servo gear trains wear out faster than nylon or karbonite gears but life can be extended:
. Servo - FAQ : Metal Gear Servos - DIY Repair & Extend MG Servo Gear Life
. Digital Servo - Burnout. Cause & Prevention
Much more information on servos is available under sub sections:
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ".
"Servo - Digital & Brushless Servo, Programmers and Software"
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
Alan T.
A.T. is offline Find More Posts by A.T.
Old Sep 30, 2012, 06:32 PM
FlyDude is offline
FlyDude's Avatar
Richmond, VA
Joined Mar 2007
Thanks for the quick reply Alan. I'll study the links you posted.
BUD...
Sold 6.0 volt regulators, and 2 Adjustable Servo reverses/controllers, Switches RSTEARMAN Aircraft - General - Radio Equipment (FS/W) 1 Sep 25, 2012 11:25 PM
Help! LiFe 6.6V max Volt? Strussen Batteries and Chargers 1 Jun 14, 2012 03:40 AM
Question Charging Life battery on Turnigy Accucell-6 scharlach Batteries and Chargers 4 Apr 28, 2012 03:52 AM
Discussion Problems running digi servos on 6 volt. cliffhanger Slope 5 Apr 23, 2009 06:21 PM
Help! HS 81 Servo on 6 Volt dangerous? John Kim Hitec/Multiplex USA 3 Feb 23, 2007 01:35 PM
