Old Sep 30, 2012, 05:12 PM
sherlockshah is online now
Find More Posts by sherlockshah
Joined Feb 2006
very important to have seperate BEC, look at this mess :(
Nitroplanes F-18 upgraded with 100mm edf on fire (0 min 37 sec)
sherlockshah is online now Find More Posts by sherlockshah
Old Sep 30, 2012, 05:16 PM
Joined Feb 2006
i had about 70 flights on this jet, it was good times
I guess indian style RIP burned! ESC caught on fire, very nice and fast set up. 100mm edf 4 blade fan with 2150kv tacon motor. 6s very fast and powerful. NOt sure what happend but Im glad I had an external bec so i was able to land it.
LESSON FOR ANY NEWBIES HERE, ALWAYS HAVE SEPERATE BEC SO INCASE YOU HAVE A FAILURE YOU CAN STILL CONTROL THE PLANE!!!
Old Sep 30, 2012, 05:17 PM
fh64_lucky is offline
Find More Posts by fh64_lucky
Ginger or MaryAnn ??
fh64_lucky's Avatar
United States, TX, Garland
Joined May 2005
nvmnd....
fh64_lucky is offline Find More Posts by fh64_lucky
Old Sep 30, 2012, 05:21 PM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
here we go...
St. Martin is offline Find More Posts by St. Martin
Old Sep 30, 2012, 05:34 PM
Chris True is offline
Find More Posts by Chris True
St. Mary, Maryland, United States
Joined Dec 1996
Do you have a blog or something where you post these priceless nuggets?
Chris True is offline Find More Posts by Chris True
Old Sep 30, 2012, 06:38 PM
Boogie_ is offline
Find More Posts by Boogie_
killed another thread
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
...I'm going to Hell...
Boogie_ is offline Find More Posts by Boogie_
Old Sep 30, 2012, 09:46 PM
hole digger is offline
Find More Posts by hole digger
hole digger
hole digger's Avatar
USA, CA, Los Angeles
Joined Aug 2002
He's back!!!!!
hole digger is offline Find More Posts by hole digger
Old Sep 30, 2012, 09:55 PM
Mike Warren is offline
Find More Posts by Mike Warren
BOHICA!
Mike Warren's Avatar
Joined Dec 2010
Need anyone say more?
Mike Warren is offline Find More Posts by Mike Warren
Old Sep 30, 2012, 10:10 PM
gazza2003au is offline
Find More Posts by gazza2003au
gazza2003au's Avatar
Sydney, Australia
Joined Jul 2003
Originally Posted by sherlockshah View Post
hey mate sad to see that video did u do a couple full throttle to LVC bench test runs? it could have saved your model
gazza2003au is offline Find More Posts by gazza2003au
Old Sep 30, 2012, 10:17 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
I haven't seen someone burn through this much money in my entire life. Pun intended!
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Sep 30, 2012, 10:39 PM
racer1 is offline
Find More Posts by racer1
5kW Club
racer1's Avatar
United States, AZ, Tucson
Joined Feb 2007
Thomas the Tank Engine type trains crash head-on in Slow Motion (0 min 27 sec)
racer1 is offline Find More Posts by racer1
Old Oct 01, 2012, 12:27 AM
Joined Feb 2006
I had over 70 flights on it
Not sure what happen. but equipment fails, my point of this thread is to say that if you are running high power set up its best to use a separate BEC so incase there is a failure you can still control the plane.
Old Oct 01, 2012, 12:30 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
it wasnt the paint that caught on fire. was probably the electrical equipment in the esc, along with the lipos. the foam will start on fire before the paint.
screw BEC's. use a seperate rx pack.
corsair nut is online now Find More Posts by corsair nut
Old Oct 01, 2012, 03:02 AM
CRCJA is offline
Find More Posts by CRCJA
wannabe Jet guy
CRCJA's Avatar
Green Valley, AZ
Joined Aug 2004
Quote
That should be a good quote, at 20 seconds into the video "Something Caught on Fire" BEC, extra RX pack, when something like that goes, there is nothing to save you, it will burn.
Ralph
CRCJA is offline Find More Posts by CRCJA
Old Oct 01, 2012, 06:36 AM
PikeStaff is offline
Find More Posts by PikeStaff
Gorilla Glue Expert
PikeStaff's Avatar
United States, PA, Doylestown
Joined Sep 2010
.................fascinating. Yep, caught on fire, all right.
PikeStaff is offline Find More Posts by PikeStaff
Discussion I think you all better have a look at this... Ebay 450sz & 500sz Kits under $25.... rhampton Electric Heli Talk 113 Jun 16, 2012 01:04 PM
Discussion Have a look at this Big Nuts 181 Giant Scale Airplanes 3 May 28, 2012 04:26 PM
Discussion have a look at this!! Big Nuts 181 Fuel Warbirds 1 May 25, 2012 10:36 AM
