Old Oct 06, 2012, 05:02 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
sorry the link I posted is fixed. Just so I have this straight, my foam is 3" thick, so the center line is at 1.5", from LE to TE.
This is where i am confussed, you say: "attach the center rib to the core" then
" Using a protractor at the tip,draw a center line at 2 degrees,and locate the tip rib there."
Nor sure what you mean by center rib? Just have root and tip templates. In the link I posted, it does show the twist, but also shows LE below center line.
Sorry, just one of those days the old brain isn't working too well
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Oct 06, 2012, 05:53 PM
epoxyearl is offline
Find More Posts by epoxyearl
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
Center rib =root rib.-my bad.
One more time...lol Draw a center line on each rib,front to back.(root,and tip)
At the root end of the core,fasten the template securely on the 1-1/2 in core centerline.
You're right-the leading edge should be at the same height at the center and tip. So the leading edge of the template will be at the 1-1/2 " line of the foam.
On the tip,raise the trailing edge of the template the amount you want it washed out.
But wait-is this a tapered wing?-Then the tip template needs to be moved back to the top view leading edge.,still with the same washout.
epoxyearl is offline Find More Posts by epoxyearl
Latest blog entry: My "Take" on the AMA
Old Oct 06, 2012, 06:18 PM
Joined Dec 2008
This is exactly what I needed. I had thought this was correct, but just was not sure. thanks.
"So the leading edge of the template will be at the 1-1/2 " line of the foam.
On the tip,raise the trailing edge of the template the amount you want it washed out."
BTW this is for an F-86F . WS=65.65"
Old Oct 06, 2012, 06:21 PM
epoxyearl's Avatar
Joined Oct 2011
Okay-so you DO have a tapered wing...Are you comfortable with the top view description of the core layout?
Old Oct 06, 2012, 07:30 PM
Joined Dec 2008
I am game!! Always nice to learn new things. Might pick it up faster!
Discussion Making a foam cored wing using 2-part rigid polyurethane foam in the mould. AvB Composites Fabrication 272 Nov 11, 2014 12:58 AM
Discussion Resources for Foam-Core Vac Bagging acetech09 Composites Fabrication 10 Sep 16, 2012 02:07 PM
Discussion Foam Wing Cores MWCores Control Line 0 Jun 27, 2012 12:15 PM
Question where to buy blue core foam Staudacher600 Electric Motor Design and Construction 4 Jun 21, 2012 12:27 AM
Help! Looking for Blue Core Foam / San Gabriel, Pasadena Calif. 91775 MrPansat2005 Foamy EDFs 2 Jun 17, 2012 09:48 PM
