Old Sep 30, 2012, 04:55 PM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Foam for cores ? Also tip template placement for washout?
I have this foam, but am not sure what type of foam it is, or if it's suitable for cores.
It was used for insulating roofs.
If useable, wings will have balsa L.E's and T.E., flaps/ailerons, fully sheeted, and 3/4oz glass. CF spars.
TIA
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Sep 30, 2012, 05:00 PM
Ward Hagaman is online now
Find More Posts by Ward Hagaman
Ward Hagaman's Avatar
San Diego
Joined Mar 2003
It looks like plain beaded foam. Perfect for a balsa sheeted wing.
Ward Hagaman is online now Find More Posts by Ward Hagaman
Old Sep 30, 2012, 05:15 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
It looks a lot more like an extruded (rather than plain expanded) foam, something like Dow Roofmate. It's probably what's commonly called Blue foam (or Pink foam, same stuff, different manufacturer). If so it will be quite a bit heavier than ordinary beaded foam though also somewhat stronger.
It will certainly work well for fully sheeted wings but it's more typically used for unsheeted wings and parts like turtle decks etc. often directly glassed. For the use you want just watch the overall weight.
Steve
slipstick is offline Find More Posts by slipstick
Old Sep 30, 2012, 08:30 PM
Joined Dec 2008
Well it's not beaded foam, although it does resemble it. and it's not polystyrene( like the blue or pink) foams. Much stonger then the beaded, and fairly light. It's not as dense as the Dow or Owens-Ccorning foams.
I got a few of these for free awhile back, and they have a taper to them, from 4" to 3.5" in 4'x4' squares. I just weighed a piece I cut 2'x4' and it weighed 2.1lb.
I figured that is 1152sqin, and my wing panel comes out to be approx 412sqin.
This is for an F-86, so you know what the wing panel shape is. Root cord is 18" tip cord is 9" panel length is 28" Max thickness of root cord is about 1.75"
So if you figure out what each panel wil use, it's very small amount out of each piece. Should not weigh to much at all, for the core, that is.
Old Sep 30, 2012, 08:55 PM
Mooney_Driver is offline
Find More Posts by Mooney_Driver
Mooney_Driver's Avatar
United States, WA, Benton City
Joined Mar 2004
Which F86 model is it?
Mooney_Driver is offline Find More Posts by Mooney_Driver
Old Sep 30, 2012, 09:05 PM
Joined Dec 2008
Have been using measurements from this one.
North American F-86F-30-NA "Sabre"
S/N 52-4978 Long , 6-3 wing.
http://www.rcgroups.com/forums/showp...&postcount=173
Old Oct 02, 2012, 10:07 PM
RWCLOUD is offline
Find More Posts by RWCLOUD
RWCLOUD's Avatar
Fresno CA
Joined Jul 2006
In the second picture, there are a lot of white specks. Those looks like "beads" to me! Having cut a lot of Styrofoam these last 30 years, it sure looks like white beaded styro to me.
One thing that I got reminded of recently is that most foams come in different weights. That nice light styro will crumble very easily! Then you take the foam that Omaha steaks are sold in and it's very difficult to get to beads to come off.
Home Depot sells a white beaded foam that makes excellent wing cores and weighs about 2 pounds per cubic foot. But it can be hard at times to find.
I'm not sure as to why, but sometimes building contractors will have sheets custom made with a taper to it for walk in freezers. At least that is what one local supplier told me. He gave me a couple of sheets that were left over from an order that he had. Sure made nice wings!!
Blue Skies...........................Tim
RWCLOUD is offline Find More Posts by RWCLOUD
Old Oct 04, 2012, 10:16 AM
Joined Dec 2008
RWCLOUD, It looks pretty ragged because I cut it with a hand saw! Actually, they are not beads, but close up look more like "cells". I got this foam from a roofing contractor. They had cut there own tapers at one time, and I guess now they just buy it that way now. I never pass up anything thats free, if I think I can use it!!
Old Oct 04, 2012, 08:06 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Just so you know, there's different densities of polystyrene foam (beaded foam).
Obviously you want to have the lightest foam you can find if you're doing sheeted cores.
I know that where I buy my foam from you can buy in "H" grade (heavy), M grade (medium), L grade (light), and SL (superlight). Superlight is around 1lb/ft3 I think.
In my experience, insualtion grade foam is usually H.
Curare is offline Find More Posts by Curare
Old Oct 04, 2012, 08:35 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
The question
Yes-that is the correct foam for a sheeted wing.
epoxyearl is offline Find More Posts by epoxyearl
Old Oct 04, 2012, 08:45 PM
Curare is offline
KE your cub.
Curare's Avatar
Joined Jun 2005
Ahh, sorry I may have misunderstood when "cores" were mentioned.
Old Oct 06, 2012, 05:21 AM
Joined Dec 2008
Templates and washout
Thanks guys I will give this foam a try. The wings will be sheeted and glassed.
A couple other quick questions. Templates?? I have seen it done two different ways.
1.Separate upper and lower airfoil templates-female
2. single airfoil shaped template-male. Is one more accurate than the other?
Washout--I realize that on build up wings, you would block up the tip of the T.E.
But when cutting foam cores that doesn't seem to practical. My thought was to draw center line threw root and tip of core blank, then center L.E of tip airfoil and raise T.E of tip airfoil the amount of degrees I need for desired washout.
Will this work out the same? I have cut cores but a long time ago, and I don't believe they had any washout.
Thanks for your help.
Old Oct 06, 2012, 05:34 AM
epoxyearl's Avatar
Joined Oct 2011
preferences.
I prefer a single male template,as smooth as possible on the edges..
A little washout never hurts.
Ha-be sure to reverse the image when cutting the second one.
Old Oct 06, 2012, 05:44 AM
Joined Dec 2008
tip template placement?
Would some one please explain the proper way to locate the tip template on a foam core for washout.
I see how this is done in a built up wing-- http://www.rcgroups.com/forums/showp...0&postcount=18
So how do you go about placing the tip template on a foam core, for lets say 2 washout?
Old Oct 06, 2012, 03:13 PM
epoxyearl's Avatar
Joined Oct 2011
I draw a centerline on the foam core,and attach the center rib to the core with a couple of long nails through it's center line.
Using a protractor at the tip,draw a center line at 2 degrees,and locate the tip rib there.
I don't always use a degree # though,I just make sure the trailing edge is a bit higher than the leading edge,when the wing is flat on the table.
An accurate measurement to duplicate that on the opposite wing is imperative...
Of course,be sure the templates are securely fastened for cutting.
Discussion Making a foam cored wing using 2-part rigid polyurethane foam in the mould. AvB Composites Fabrication 272 Nov 10, 2014 11:58 PM
Discussion Resources for Foam-Core Vac Bagging acetech09 Composites Fabrication 10 Sep 16, 2012 01:07 PM
Discussion Foam Wing Cores MWCores Control Line 0 Jun 27, 2012 11:15 AM
Question where to buy blue core foam Staudacher600 Electric Motor Design and Construction 4 Jun 20, 2012 11:27 PM
Help! Looking for Blue Core Foam / San Gabriel, Pasadena Calif. 91775 MrPansat2005 Foamy EDFs 2 Jun 17, 2012 08:48 PM
