Old Sep 30, 2012, 04:03 PM
rotomatt is offline
Find More Posts by rotomatt
United States, CT, Hartford
Joined Aug 2010
Help!
phoenix ice2 throttle curve
I'm running an phoenix ice2 160 with fixed end points on a large edf 12khz switching and low timing. throttle response through castle link set to 6, throttle curve in transmitter is linear but response from esc is very top heavy?. Meaning a little stick movement = a lot of change in esc output in the upper ranges 70% and greater on transmitter stick? Any way to make esc react in a linear curve? Thank You for any help you can give me
rotomatt is offline Find More Posts by rotomatt
Old Oct 09, 2012, 12:20 PM
wingster is offline
Find More Posts by wingster
Massachussets
Joined Nov 2005
Adjust your transmitter throttle curve. Steep at low throttle and shallow near high throttle.
wingster is offline Find More Posts by wingster
Old Oct 10, 2012, 07:15 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
It’s not the ESC it’s the way that electric motors make power.
I recommend starting with 0, 40, 65, 85, 100 for normal flight mode and 100, 95, 85, 95, 100 for 3D. You will need to tune the curves until you get the response that you want.
A better alternative is to use the Set RPM governor mode.
RC Man is online now Find More Posts by RC Man
Old Oct 10, 2012, 10:09 PM
3Dmuse is offline
Find More Posts by 3Dmuse
Ontario, Canada
Joined Sep 2009
CC controllers don't have a linear response to input throttle on purpose so that not all output power is concentrated at the top of the stick movement. It seems you are getting the opposite results to what Castle intended for their controllers:
http://www.rcgroups.com/forums/showp...54&postcount=5
http://www.rcgroups.com/forums/showp...41&postcount=9
Did you calibrate the end points?
3Dmuse is offline Find More Posts by 3Dmuse
Old Oct 11, 2012, 04:55 AM
United States
Joined Feb 2001
Have you tried the pitch and throttle curves in your helicopter manual? That should give you a fairly linear response.
Old Oct 17, 2012, 08:02 PM
rotomatt is offline
Joined Aug 2010
Thank You for replies, first RC Man EDF not heli and yes I have played with throttle curve.Now Its similar to what wingster had suggested, better but not right yet I cant make low end to steep I need small power changes to manage decent rate when landing . Barzaun interesting links 2nd one explains a lot and yes end points are fixed for both low and high stick ( arming and full power) I will keep plugging away at it till I get the right feel
Question Scale pitch/throttle curve help. Diesel6401 Electric Heli Talk 5 Aug 25, 2012 08:20 AM
Help! blade 400 throttle curves Joshheli Mini Helis 6 Jul 09, 2012 09:49 PM
Question sport flying pitch and throttle curves for b400 Joshheli Mini Helis 1 Jul 09, 2012 05:52 AM
Discussion DX6i & MQX throttle curve CraigVMN Multirotor Talk 2 Jun 24, 2012 01:12 PM
Phoenix 45, gov mode and throttle curve habazot Castle Creations 12 Oct 29, 2003 03:54 PM
