Old Sep 30, 2012, 02:55 PM
dgonano is offline
Find More Posts by dgonano
Joined Sep 2012
My first Quadcopter!!!! - Build list
alright so this is my first Quadcopter build and its for an individual project for uni to help me learn about all this stuff Ive been doing a heap of reading and research and talking to people and this is what I've come up with:
The idea is i have $500 to build a quadcopter that can fly around locally but also so that it can be expended to an FPV system in the future so that it can go on some more adventurous missions
Frame: $95 with postage
http://www.foxtechfpv.com/atg-l600-x...ame-p-555.html
a nice decent frame (i think) to hold everything made of carbon fibre. shouldn't break in my learning stage if I'm careful
Flight controller: $63
http://www.rctimer.com/index.php?gOo...wt&goodsid=765
CRIUS AIO PRO V1.1 due to its low cost. I'll run MegaPirate because i like the Arducopter interface (still a little confused on how to get the firmware on there through arduino but hopefully you guys can guide me a bit )
GPS: $26
http://www.rctimer.com/index.php?gOo...wt&goodsid=763
From reading forums i believe this one works but i have to reconfigure it with this:
http://www.rctimer.com/index.php?gOo...wt&goodsid=684
using this guide:
http://fpvcentral.net/2012/07/crius-...ltiwii-part-1/
Remote control and receiver: $53
http://www.hobbyking.com/hobbyking/s...idProduct=8992
I looks to be good for its price but i have seen some stuff saying its not that good :/ what do you guys think? i want the 8 channels so i can do all the control etc haha
Motors: $50 ish total
http://www.hobbyking.com/hobbyking/s...dProduct=12922
I used that eCalc site do put some numbers in and play around with it and this configuration seams to give pretty good battery life and throttle control
Props: $8 ish
http://www.hobbyking.com/hobbyking/s...dProduct=22446
http://www.hobbyking.com/hobbyking/s...dProduct=22447
CW and CCW pair, again the 1045 seamed to work well in eCalc
ESC: $50
http://www.hobbyking.com/hobbyking/s...idProduct=2164
30A ESC's, i gather the plush (whatever that means :P maybe you guys can tell me haha ) is good haha
ESC prgramming card: $6
http://www.hobbyking.com/hobbyking/s...1060&aff=99809
Do i actually need this? im supposed to be learning stuff so i though i may as well get it for the pice and play around haha
Battery: $32
http://www.hobbyking.com/hobbyking/s...dProduct=17241
4000mah nano-tech LiPo for HK, nothing to special i guess
Battery Charger: $18
http://www.hobbyking.com/hobbyking/s...0968&aff=99809
what do you guys think of this? pretty standard i guess?
LiPo alarm: $2
http://www.hobbyking.com/hobbyking/s...dProduct=22749
dont want to damage it
So thats the main stuff i guess, the following bits i want to make sure will work with it in the future. I gather they can from what ive read
PS: i get more funding for this so cost here isnt an issue at the moment
OSD: $65
https://store.diydrones.com/Ardupilo...-apmminosd.htm
nice OSD configurable in the arducopter program once ive loaded megapirate
Camera: $130
GoPro Hero
Vido transmitter and receiver: unknown
So yeah.... what do you guys think? will everything work together etc? any comments welcome
Dion
dgonano is offline Find More Posts by dgonano
Old Sep 30, 2012, 04:21 PM
dgonano is offline
Joined Sep 2012
also i know a lot of you will be thinking i should start smaller but its a project that i get graded on so it kinda has to be a bit ambitious otherwise... well no grade i guess :/ i.e.. i cant just buy a small one like Walkera Ladybird and fly it around for a bit haha but if you really think i will totally crash and just destroy it please tell me too haha RC experience includes cars (no help there) and those 3 channel RC heli's which are easy to fly... so yeah not much experience
Dion
Old Sep 30, 2012, 04:34 PM
HansAuf is offline
Find More Posts by HansAuf
Pass me some zip-ties!
HansAuf's Avatar
United States, FL, Gainesville
Joined Nov 2006
For your first quad I highly suggest skipping the Multiwii or MegapirateNG code based boards. While I am a huge fan of them, the learning curve is steeper than most people care to deal with. Spring the extra $$$ and pick up a DJI Naza. You'll spend more time flying and less time tuning, which after all is why you are building this to start with. I use and have used about every controller out there and whether you are a beginner or even fly aggressive, the Naza really cant be beat for an all-around great flight controller. If you are hell bent on still using the CRIUS AIO PRO, then read, read, and re-read the associated thread. If you want to read some general multiroto suggestion, take a look at something I posted under my blog section. http://www.rcgroups.com/forums/showthread.php?t=1725752 Hope it helps in some way and good luck!
HansAuf is offline Find More Posts by HansAuf
Old Sep 30, 2012, 04:42 PM
2400RDR is online now
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
Skip the GPS for a while- they are hard to set up, and you really need to learn to fly first.Or buy it and save it for later.
The el-cheapo HK v2.1 board at about $15.00 is a really decent board, and it would be good to learn on- extremely simple to set up, and since it has gyros only, you'll actually learn how to fly rather than having the board fly for you. I learned on a Copter Control board (the Grail) and then started flying the HK boards some lately- I'm impressed with them.
The Turnigy 9x radio is highly respected and inexpensive if you can find one.
You need to buy way more props than you list- you'll break a lot while you're learning
Get HK F30 ESCs rather than the Plush- the F30s can be flashed, which you may want to do later, and are good ESCs. You don't have to flash, but if you do, you'll notice that the quad flies better.
You can get by with smaller, cheaper batterires. If you're making a quad, a 2650mah will be fine, or even a 2200. Don't worry about long flight times right of the bat- 6 or 8 minutes will be enough while you're learning.
Just my opinions, of course.
Rick
2400RDR is online now Find More Posts by 2400RDR
Old Sep 30, 2012, 04:48 PM
dgonano is offline
Joined Sep 2012
hi, as much as i would like something nice like the naza to begin with i just can not fit it in my budget
its learning so i guess i'll just have to tough it out and hope i can get it working yeah?
what about the component? do they all work together do you think??
and i will take a read of that link you posted
Old Sep 30, 2012, 05:16 PM
dgonano is offline
Joined Sep 2012
2400RDR,
yeah i wasn't planning of using the GPS straight away, id just buy it and configure it later once i have the rest working haha
haha yeah those props are are a set of 4 each so 4 CW and 4 CCW but maybe i'll buy even more haha
you give a valid point with the $15 controller, i might get one as well as the CRIUS. start on the HK one and then learn to set up the other one once i can fly a bit
could you link me for the F30's? i searched HK but couldn't find what you mean, sorry
Dion
Old Sep 30, 2012, 06:44 PM
Joined Feb 2009
Originally Posted by dgonano View Post
2400RDR,
Dion
http://www.hobbyking.com/hobbyking/s...C_3A_UBEC.html
These are all the rage right now if you plan to flash them with SimonK firmware. Fairly inexpensive too. If you can't get these, I've had good luck with RCTimer housebrand ESCs, and they are selling some of them pre-flashed as well.
Old Sep 30, 2012, 08:10 PM
dgonano is offline
Joined Sep 2012
oh i see.. i though the plush ones were haha im not sure how to program it at the moment so i should i just get this one then?:
http://www.rctimer.com/index.php?gOo...9&productname=
Dion
Old Sep 30, 2012, 10:31 PM
dgonano is offline
Joined Sep 2012
well... i guess im ready to order the parts then??? any reason not to?
EDIT: alright so I'm supposed to be putting in my purchase order requests tomorrow and would really like it if one of you guys could say that everything should work or not haha just for a little bit of confidence in this stuff which i really dont know what im doing yet :P
so its the list above but with the RCtimer ESC (that have SimonK on them) and i'll also get the KK2.1 board (and USBasp) to start flying with before i set up the CRIUS one. all sounds good?
Old Oct 02, 2012, 10:43 AM
vineet_p is offline
Find More Posts by vineet_p
vineet_p's Avatar
India, Telangana, Hyderabad
Joined Aug 2011
Originally Posted by HansAuf View Post
For your first quad I highly suggest skipping the Multiwii or MegapirateNG code based boards...............
Ignore this baseless statement, go your way and buy the AIO pro. The fun lies in tuning and flying, not just flyin! And Best of Luck.
vineet_p is offline Find More Posts by vineet_p
Old Oct 02, 2012, 10:58 AM
dgonano is offline
Joined Sep 2012
yeah im getting the CRIUS one, plus a HK one to start with to help me learn to fly too :P
Old Oct 02, 2012, 11:19 AM
vineet_p is offline
vineet_p's Avatar
Joined Aug 2011
Nice... Are you going to flash your ESCs with simonK? If you don't know what it means, go to this thread and this one
Old Oct 02, 2012, 11:21 AM
dgonano is offline
Joined Sep 2012
the ones im getting of RCtimer are preflashed with simonK
Putting the purchase order in in an hour for it all kinda excited, hopefully it all works together :P
Old Oct 02, 2012, 07:01 PM
tedpretty is offline
Find More Posts by tedpretty
Joined Sep 2012
DJI F550 What batteries, Charger, & Power Supply?
I'm sick of wating for backordered parts...it has been three weeks and I just want to fly. My assembly on the F550 is almost complete (with NAZA+GPS) and I'm willing to order from another store.
First off, I'm learning to fly. Eventually I want to put a camera on this thing. My dream is to get a much more professional system in the future and start an AP business of some kind.
Here is what is backordered (this was upon recommentation from the shop):
1-Hitec X4 80 watt per port charger
2- 5000mAh 22.2 60C battery
no power source ordered
The total for the charger and the battery is around $500 (without power source)...I'm not really worried about the money as I am more worried about getting what I need.
Any suggestions what to buy an what on-line store?
tedpretty is offline Find More Posts by tedpretty
Old Oct 02, 2012, 07:12 PM
dgonano is offline
Joined Sep 2012
Would it have been to hard to start another thread?
Build Log My first time budget build Quadcopter momofx Multirotor Talk 18 Oct 03, 2012 06:17 PM
Yippee! Finished building my first ever quadcopter! ($450) nis4nitro Multirotor Talk 9 Aug 30, 2012 08:53 PM
Discussion Building my first Quadcopter felipeds Multirotor Talk 11 Aug 06, 2012 03:44 PM
Build Log My First Quad Build, Parts List CH33ZEBURG3R Multirotor Talk 14 Jul 12, 2012 10:54 AM
