Old Nov 01, 2012, 01:36 PM
RCFLYBOY1 is offline
Find More Posts by RCFLYBOY1
CERTIFIED CRASH ARTIST
RCFLYBOY1's Avatar
United States, MD, Baltimore
Joined Mar 2011
I use a hollow core door with a ceiling tile turned upside down and mounted at four corners can easily pin work to it and you can stand it up in a corner when not in use.I have even left parts pinned to it when stored.
Jim
RCFLYBOY1 is offline Find More Posts by RCFLYBOY1
Old Nov 08, 2012, 11:29 AM
shaunkocher is offline
Find More Posts by shaunkocher
Canada, ON, Waterloo
Joined Jan 2011
use a glass table if you spill glue on it you can just run your knife across the table and it will peel right up
shaunkocher is offline Find More Posts by shaunkocher
Old Nov 08, 2012, 12:02 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
Glass will also ruin your knives, so be careful.
acetech09 is offline Find More Posts by acetech09
Old Nov 08, 2012, 01:37 PM
Free is online now
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
United States, CA, SF
Joined Jan 2012
I used a glass 1/8" sheet(~12x24") for a while.(did a lot of knife sharpening) It worked well.(as long as you don't push with your thumb really hard in the center while it's on you lap)
Free
Free is online now Find More Posts by Free
Old Dec 27, 2014, 06:12 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
building surface Tip SPRAY PAINT
Hi,
Been building for over 25 years. Balsa, foam, Coroplast and composites too.
A truly straight table is a must and is the base for whatever surface is actually built on. I use a recycled drafting table top and pin to ceiling tiles. But I never liked how these can fuzz up. So I use an entire $1.00 can of cheap spray paint on the reverse side AND edges. Use lots of light coats and don't wet it out anywhere.
I used to use a metal desk but after storing it for a few years when I was out of RC it got bent. I confess to having built a half of a wing with potato chip like quality.
ozmo01 is offline Find More Posts by ozmo01
Old Dec 28, 2014, 09:44 AM
sirpercy is offline
Find More Posts by sirpercy
sirpercy's Avatar
United States, IN, Noblesville
Joined Sep 2013
you can get many sizes of Masonite laminate shelves at Menards, etc. Because of the way they are made , most are very straight and level. I then hot glue an appropriate piece of ceiling tile to that. You can make about any size you want, and very portabe.
sirpercy is offline Find More Posts by sirpercy
Old Dec 29, 2014, 09:19 PM
RCNorthBC is offline
Find More Posts by RCNorthBC
Canada, BC, Smithers
Joined Oct 2012
Possibly the flattest, truest surface you will find is 3/4 inch float glass. It's poured on a pool of liquid mercury to keep it perfect during manufacture. Ask your local glass shop - they may have scrap pieces from a commercial window. Use weights or tape to hold components in place.
RCNorthBC is offline Find More Posts by RCNorthBC
Cool ///////Building my new work table\\\\\\\ Diceman89 The Builders Workshop 18 Sep 25, 2012 10:36 AM
Wanted Andrew Jesky Takes RC to a Higher Plane, Volume I, Foamies and Indoor Flight DVD tonyyng Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 14, 2012 10:01 AM
Discussion Foamie yak 55 indoor en exterior Nanous Mexico 1 Jul 24, 2012 09:14 PM
Discussion My Indoor and Micro wings for some club fun for indoor newbies Knife Liddle Scratchbuilt Indoor and Micro Models 2 Apr 02, 2012 12:37 AM
For Sale Indoor/outdoor fun foamys lectroglide Aircraft - Electric - Airplanes (FS/W) 6 Feb 25, 2012 05:21 PM
