Old Sep 30, 2012, 01:44 PM
jhicks is offline
Find More Posts by jhicks
jhicks's Avatar
United States, TX, Odessa
Joined Jan 2005
Building table for precise indoor foamies??
Hey guys,
When i moved from Ohio to Texas I lost my building table. I was curious what you guys are using to build your indoor pattern planes on.
Im trying to find something. Really would like just a light board I can pickup and move.
What are you guys using?
Jamie Hicks
jhicks is offline Find More Posts by jhicks
Old Sep 30, 2012, 04:33 PM
acetech09 is offline
Find More Posts by acetech09
I think I'm inverted. Maybe.
acetech09's Avatar
United States, CA, Pacifica
Joined Apr 2012
I do most of my builds on a sacrificial 3/4" OC pink foam insulation sheet. You can get a huge-ass sheet of it for about $18 at home depot, and that cuts down into 2 good-size boards. It doesn't get damaged too easily, glues normally peel right off the plastic film, and you don't damage your knife when you cut through what you're cutting. Really handy.
acetech09 is offline Find More Posts by acetech09
Old Sep 30, 2012, 11:45 PM
Not Free is offline
Find More Posts by Not Free
Foamies for life! #f3p
Not Free's Avatar
United States, CA, SF
Joined Sep 2011
I use a cork board, a wood desk, and a wood floor
I do NOT recommend either of these options
Not Free
Not Free is offline Find More Posts by Not Free
Old Oct 01, 2012, 02:27 AM
mammuth is offline
Find More Posts by mammuth
WWII combat fan
mammuth's Avatar
Huddersfield
Joined Jul 2008
Just stay away from any brand new table you just bought for your living room - I think you can see were I'm going with it .....
mammuth is offline Find More Posts by mammuth
Old Oct 01, 2012, 09:43 AM
ChrisBowker is offline
Find More Posts by ChrisBowker
RC Bum 4 Hire
ChrisBowker's Avatar
United States, NM, Albuquerque
Joined May 2004
I think you'll have difficulties finding something portable and true. I bought an old pool table off craigslist, pulled the slate off it and built a new frame from 3/4" birch ply to hold two of the pieces end to end, it made a 32x98" table, perfect for most RC building needs...but its about 300-400 lbs put together so not very portable.
If you need a lighter weight solution you might try looking for a solid core door, I use to build on one when I was a kid, worked fine for a lot of years.
Chris
ChrisBowker is offline Find More Posts by ChrisBowker
Old Oct 01, 2012, 04:13 PM
Boogie3D is online now
Find More Posts by Boogie3D
United States, FL, Daytona Beach
Joined Sep 2005
I just use a MDF 40x40" (1mx1m) 1 inch thick board placed on normal table. It is very true after 4 years of being used and when you just finish building planes you put the board between a wardrobe and wall
Boogie3D is online now Find More Posts by Boogie3D
Old Oct 01, 2012, 10:04 PM
tware is offline
Find More Posts by tware
tware's Avatar
Little Rock, AR
Joined Nov 2005
not really a master builder here, but I really like this stainless steel table I got at Sams Club. It's a prep table on wheels. It has a very thick top, not prone to warp or bend. the bottom shelf is wire. most of all, I can wheel it around, which as been convenient (moving it out of the way).
oh, found the link. I've purchased these for tech benches at work too, they have always been under $100 in store, regardless what the website says.
http://www.samsclub.com/sams/work-ta...p-49/145625.ip
tware is offline Find More Posts by tware
Old Oct 01, 2012, 10:07 PM
tware is offline
tware's Avatar
Little Rock, AR
Joined Nov 2005
Also worth mentioning, CA doesn't readily bond to it. When CA leaks through the joint I'm gluing, I can always slide it free without damage to the foam. often its hardly stuck at all. And I can clean the table with acetone when it gets really messy. Only downside is working with electronics and batteries on a steel table, but that's not really a big deal.
Old Oct 01, 2012, 10:08 PM
Batmanwpg is offline
Find More Posts by Batmanwpg
Boar? I'm a Thermal Pig!
Batmanwpg's Avatar
Winnipeg, Canada
Joined Aug 2004
Probably not what your looking for but I use an old heavy metal business desk. The top is very flat and has metal under the plastic skin top. This allows me to use magnets to hold parts in place when building. This is very helpful when building foamies. The magnets are from damaged brushless motors not worthy of repair. You can get a lot of magnets from just one motor and plenty strong enough to hold parts in place.
Batmanwpg is offline Find More Posts by Batmanwpg
Old Oct 02, 2012, 07:04 AM
xtremeRCpilot is online now
Find More Posts by xtremeRCpilot
xtremeRCpilot's Avatar
Cleveland, Ohio
Joined Sep 2006
I use a piece of 1/2" plate glass about 30" x 48" and it is about as true of a surface as you will find. I robbed it off an old table topper we had and just use a razor to remove any CA from the surface. Im sure you could find one a little bigger but I have built up to 36" wing span foamies on mine. You could also wrap it in cardboard if you need to transport it to hobby venues
Cheers
John
xtremeRCpilot is online now Find More Posts by xtremeRCpilot
Old Oct 02, 2012, 03:10 PM
Hubb is offline
Find More Posts by Hubb
Late
Hubb's Avatar
Lebanon, OH
Joined Oct 2003
I use a piece of 3/4" Lexan approx 2' x 4' (about the size of a ceiling tile)
Hubb is offline Find More Posts by Hubb
Old Oct 04, 2012, 12:12 PM
crossup is offline
Find More Posts by crossup
Senior to who? Member
crossup's Avatar
Annapolis, Maryland USA
Joined Feb 2001
I use two pieces of 1"x 18"x 48" laminated(real wood, not pressboard etc) counter top(Homedepot).
Then I clamp the two pieces side by side with a 3mm gap using two 36" pieces of 2" steel angle iron(also HD) and large C-clamps.
That gives me a slot to hang the fuselage halves thru. Once the foam is all glued I do the CF bracing on the bottom on the wing and tail and fuselage while the top hangs down thru the slot.
To keep from gluing things to the board, I use Towerhobby building table film...nothing sticks to that stuff and a 25' roll is pretty cheap.
Oh and I use a HD 'Workmate' clone portable carpentry table to set the above assemblly on.
The clamps hold the split table above the Workmate table and gives me plenty of depth for tall fuselage to hang down(the Workmate frequently isn't deep enough by itself, if the fuse isnt too long of deep you can just use the workmate by itself but you will have a lot of overhang of the wings so I use my split table for every build.
crossup is offline Find More Posts by crossup
Old Oct 04, 2012, 03:09 PM
Free is offline
Find More Posts by Free
"Free" in Christ! #F3P
Free's Avatar
Joined Jan 2012
Right now I am using a big sheet of 1/4" plastic.
Free
Free is offline Find More Posts by Free
Old Oct 08, 2012, 02:18 PM
hpapilot is offline
Find More Posts by hpapilot
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
3/4" thick fiberglass skin, nomex core honeycomb panel... pretty darn hard to beat that. Kinda hard to find though...
hpapilot is offline Find More Posts by hpapilot
Old Oct 08, 2012, 05:35 PM
jhicks is offline
jhicks's Avatar
Joined Jan 2005
yes i know rj.
Cool ///////Building my new work table\\\\\\\ Diceman89 The Builders Workshop 18 Sep 25, 2012 10:36 AM
Wanted Andrew Jesky Takes RC to a Higher Plane, Volume I, Foamies and Indoor Flight DVD tonyyng Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 14, 2012 10:01 AM
Discussion Foamie yak 55 indoor en exterior Nanous Mexico 1 Jul 24, 2012 09:14 PM
Discussion My Indoor and Micro wings for some club fun for indoor newbies Knife Liddle Scratchbuilt Indoor and Micro Models 2 Apr 02, 2012 12:37 AM
For Sale Indoor/outdoor fun foamys lectroglide Aircraft - Electric - Airplanes (FS/W) 6 Feb 25, 2012 05:21 PM
