Old Oct 10, 2012, 03:22 PM
FatN00b is offline
Find More Posts by FatN00b
Joined Oct 2012
Originally Posted by lovegroove View Post
That would be one monster article to try and write.
Yea... Kind of figured as much...
Thanks for your time and effort on these questions... People like you spending your free time helping us n00bs is what opens this hobby to so many.
But these have been my biggest questions
Which Motors?
Which Props?
Which ESCs?
Which Batteries?
The frame seems to be kind of a Non-issue... It seems to be limited only by your imagination and wallet.
FatN00b is offline Find More Posts by FatN00b
Old Oct 10, 2012, 03:37 PM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
If you're a total noob, then have a look at my beginner copter article on my blog where I recommend a few motors, props, ESCs and batteries.
http://drone-pilot.blogspot.fr/2012/...at-to-buy.html
lovegroove is offline Find More Posts by lovegroove
Old Oct 10, 2012, 09:54 PM
zacker is offline
Find More Posts by zacker
Master Prop Buster!
zacker's Avatar
United States, CT, Oxford
Joined Oct 2012
You can't go wrong with the Turnigy 9x transmitter. It's got more functions than you can shake a stick at and you can even upgrade the firmware. So many people that fly multicopters are using these: http://www.hobbyking.com/hobbyking/s...976&aff=114030
I don't see any mention of the flight controller, but obviously you will need one of those. This is a really good one for beginners: http://www.hobbyking.com/hobbyking/s...723&aff=114030
The Turnigy 3s 2200mAh lipo should be great for your setup and give you plenty of flight time, buy lots of these: http://www.hobbyking.com/hobbyking/s...636&aff=114030
The RCTimer ESCs that come pre-flashed with the SimonK firmware are great, you'll need 3 of these: http://www.rctimer.com/index.php?gOo...9&productname=
You will also need some sort of power distribution board and a few other bits and pieces like a servo to control the tail motor.
Check out my beginner article on my blog or get back to me here if you have more questions.
was this meant for me? if so, thanks alot... if not, thanks alot anayway....lol do the radios come with the servos ? also,if i use a multiwii board, do i still need the flight control board you suggest?
thanks so much.... i have no clue in this stuff.
zacker is offline Find More Posts by zacker
Old Oct 10, 2012, 10:03 PM
zacker is offline
Master Prop Buster!
zacker's Avatar
Joined Oct 2012
hey lovegroove, what is a better radio to get? theTurnigy 9X 9Ch Transmitter w/ Module ? or the same one without the module? ]wouldnt i need the module?
Old Oct 10, 2012, 10:26 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
You need the module.
They do not come with servo's.
AcroFPV is offline Find More Posts by AcroFPV
Old Oct 11, 2012, 12:52 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
As subara already said, you need a module and no, the transmitter doesn't come with servos.
If you buy it without a module, then I highly recommend purchasing the FrSky module and matching FrSky receiver.
Old Oct 11, 2012, 08:49 AM
rubenskubc is offline
Find More Posts by rubenskubc
United Kingdom, England, London
Joined Oct 2012
That's great! Thanks a lot for your answers! I'll then wait for my kit... and see what I can do. I suspected about the gimbal stabilization not performed by the HK v3.0, but it's fine... I can do something later about that, priority is still the quad flying good first.
rubenskubc is offline Find More Posts by rubenskubc
Old Oct 11, 2012, 10:06 AM
FatN00b is offline
Joined Oct 2012
Thanks... That seems perfect. Those motors are alot cheaper than what I was thinking about going with.
Old Oct 12, 2012, 06:00 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Just a quick update on what's going on with my blog: http://drone-pilot.blogspot.fr/
I think I might have bitten off more than I can chew trying to do an article about the regulations regarding multicopters and UAVs around the world. It seems that there is new legislation coming in all the time, so by the time I finish it, it might not be true anymore. Hoping to at least get something finished this weekend.
The weather here in the French Alps has turned bad, so I'm going to have difficulty getting out to do some of the flying videos that I had planned. I went out yesterday to do a video on the spidercopter, but I had an issue with one of the motor mounts coming loose, so that video will have to go in my out takes and bloopers video.
On more positive news, it looks like I will be starting a new contract next week, so should have more funds to put towards some new projects. I'm going to order up all the bits that I recommended for the beginner and mid-range quads and do a step by step build guide for them. and am thinking up competition ideas for giving them away.
The bad weather means that I should have enough time to finish my All-in-One FPV ground station, finish off my Halloween copter and start writing my article about cameras for AP/AV use. I've also got a Top Secret project that I'm working on that I don't think I've seen done with a multicopter before and should make for an epic video.
So, lots of stuff in the pipeline and I just need to beat this cold that I've been suffering from for the past 2 weeks and I'll be back to it and churning out more articles.
Old Oct 12, 2012, 06:24 AM
metap0Pe is offline
Find More Posts by metap0Pe
Joined Oct 2012
congratz on 2400 posts:P
I have a few questions:
Will it give me trouble having the motors raised from the frame like on this frame?
http://tosed.dk/billeder/flying_stuff/hex.jpg
Why can i purchase a KK2.0 flight controller board for 30$ when a NAZA will set me back almost 20 times that? What is the difference? (quality ofc, but why the HUGE gap?)
What is the diference between the x and + settings on a quad and hex copter? Is is just that the props sits in a x instead of a +? This would make sense, but i want to be sure:P
Thanks for your time!
metap0Pe is offline Find More Posts by metap0Pe
Old Oct 12, 2012, 07:19 AM
cwg25 is offline
Find More Posts by cwg25
You Enjoy Myself
United States, NC, New Bern
Joined Jul 2012
Random FPV question.
Are most or all FPV cams an additional small camera attached to an MR...or do people use their GoPros and other cameras to simultaneously record video AND transmit fpv video to goggles/screen?
I notice some FPV setups use different frequencies. If I have a 2.4 ghz tx, I need to get an FPV setup with a different frequency, right?
Can you explain a little more about this and other FPV basics? Thanks.
cwg25 is offline Find More Posts by cwg25
Old Oct 12, 2012, 07:45 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Might have better luck reading the first few posts from the thread below and then asking there.
http://www.rcgroups.com/forums/showthread.php?t=1355327
brontide is offline Find More Posts by brontide
Old Oct 12, 2012, 07:59 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Having the props raised like that won't cause any problems, there's already quite a few frames with a design like that.
The NAZA is more expensive because it offers more features. You can upgrade it to have GPS, which will allow it to hold position or even return to home if you have a failsafe.
The difference between x and + is just to do with which direction is forward. This picture should make it more clear:
Old Oct 12, 2012, 08:23 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
You can use the GoPro as your primary FPV camera, but for a few reasons people tend to use a separate CCTV style camera for FPV. The reason for that is that there is a very slight lag in the output from the gopro and most goggles and screens have 4:3 aspect ration, so you get black bars top and bottom in your goggles/screen. The other benefit of the CCTV style cameras is that they tend to have better light handling ability (if you get the right one) and you can choose a lens with a more narrow field of view which makes it much easier to fly in close proximity to objects.
If you're using 2.4GHz for control, then you can't use 2.4GHz for video. That means that you will have to use 900,1.3 or 5.8. A lot of people are using 5.8GHz on multicopters because the antennas are nice and small and it works well with 2.4GHz control.
The major downside to 5.8GHz video is that you really need to maintain direct line of sight or you start to get video drop-outs, even at quite short distances.
1.3GHz is pretty good for penetration, so great if you occasionally go behind a tree or other objects, but the antennas are a bit bigger and more difficult to put on a copter (if you're using a skew-planar antenna like most people these days). The other problem with 1.3GHz is that the second harmonic step on top of the 2.4GHZ for control, so you have to use a low pass filter and try to get as much separation as possible between the video tx and control rx.
Of course you could fly on good old 72MHz and use 2.4GHz for video, or get yourself a long range UHF system.
Old Oct 12, 2012, 11:16 AM
Joined Oct 2012
Tip.. as a primary 1080p camera for a quad, I'd rather use a Drift camera, as it's cheaper, the shape is so much easier to deal than a GoPro... also includes the LCD and remote for free
Discussion Do you know what airplane is this and who made it? mashca Vintage & Old-Timer Designs 11 Sep 13, 2012 11:43 PM
Discussion Do you know what airplane is this and who made it? mashca The Builders Workshop 5 Sep 11, 2012 07:05 PM
Question How do you know what part is bad? j2591 Micro Helis 5 Aug 13, 2012 07:39 PM
Discussion Do you know what this is? jaizon Thermal 3 Jul 22, 2012 02:09 PM
Wanted do you know what plane this is ? streetbikegod4 Aircraft - Electric - Airplanes (FS/W) 5 Mar 18, 2012 08:41 AM
