Old Oct 09, 2012, 04:13 AM
Hajen is offline
Find More Posts by Hajen
Joined Oct 2012
I am atm flying small multicopters to learn! And planning on flying more with them! And then Step it up!
But, quad or hexa? And what size is do you recommend ? Budget is around 5-6k!
Hajen is offline Find More Posts by Hajen
Old Oct 09, 2012, 10:08 AM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I'd get something with motor redundancy if it's to lift a big heavy camera. Either Y6, X8 or Octo. Why not get in touch with Tony at http://www.rc-drones.com and see what he recommends for you.
You can have a look at a current build he is doing for a customer here: http://www.rcgroups.com/forums/showthread.php?t=1744389
lovegroove is offline Find More Posts by lovegroove
Old Oct 09, 2012, 10:23 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I'm feeling a bit under the weather at the moment, so haven't been able to write as many articles as I would have liked. I have just published a new one about multicopter lighting though and I'll carry on editing it to add more detail as I start feeling better again, as well as a step by step video for adding lighting.
http://drone-pilot.blogspot.fr/2012/...lticopter.html
Old Oct 09, 2012, 11:49 AM
azamc is offline
Find More Posts by azamc
United Kingdom, London
Joined Oct 2012
hi newbie here..
how do i choose the right motor? theres soooo many options out there....
azamc is offline Find More Posts by azamc
Old Oct 09, 2012, 01:29 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Originally Posted by azamc View Post
hi newbie here..
What are you planning on building, how much is it going to weigh and what load do you expect to carry?
Old Oct 09, 2012, 01:38 PM
metap0Pe is offline
Find More Posts by metap0Pe
Joined Oct 2012
I have the same motor question.
Am planning to build a quad now for camera platform (no acrobatics) on a X525 frame (600mm between motors) and later on advance to a self build HEX frame.
Will these motors be good? I have bought 9" and 11" props for them to test out.
http://www.hobbyking.com/hobbyking/s...idProduct=6247
metap0Pe is offline Find More Posts by metap0Pe
Old Oct 09, 2012, 01:51 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I know that the DT750 motors are cheap, but I'm not a big fan. Just about the best budget motors that you can get for multicopters are the Sunnysky x2212-980KV. It's a little bit more money for a lot more motor. http://www.ebay.co.uk/itm/SUNNYSKY-X...item3a75d8158a
Other motors that I've used for a few builds which I also like for 10-11" props is the 2830-14 from RCTimer. http://www.rctimer.com/index.php?gOo...3&productname= but I would recommend the prop adapter to these http://www.rctimer.com/index.php?gOo...5&productname=
Old Oct 09, 2012, 01:55 PM
metap0Pe is offline
Joined Oct 2012
Well,
The plan is to get some "beginner" motors, as i dont think i can start out pro, and never crash, and then later on upgrade to better ones. So as long as the ordered ones wont go full retard on me and burn the house and cat down, I am satisfied
Old Oct 09, 2012, 02:12 PM
cwg25 is offline
Find More Posts by cwg25
You Enjoy Myself
United States, NC, New Bern
Joined Jul 2012
What are some recommendations you can make for camera gimbals using a GoPro Hero2 and attached to a DJI F450 for less than $500 complete/assembled?
I'm looking at the X468. Anything in particular you can say about this or something similar? What about the photohigher stuff?
I want to buy something already built, easily attachable to my quad, and something that is easily setup and tuned in NAZA Assistant.
I also don't want any props or arm parts showing in my video. What can be done to get rid of this? I realize when panning you may see some part of the quad in the video. But I'd like to set the camera at a point with no quad part in the fame, is this a typical feature with the type of gimbals I'm interested in?
cwg25 is offline Find More Posts by cwg25
Old Oct 09, 2012, 02:31 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
The reason that I haven't updated the gimbal part of the mid-range copter article is because it's really hard to find a high quality gimbal that doesn't cost an arm and a leg.
What complicates things with the F450 frame is that you don't just need a gimbal, but you need a landing gear as well. At the moment, it does look like the X468 might just be the best choice for what you need as it's specifically designed for the F450, so you won't have any mounting issues at least.
Old Oct 09, 2012, 02:56 PM
cwg25 is offline
You Enjoy Myself
Joined Jul 2012
I do have landing gear that allows for 6 inches of clearance under the quad. Is this enough for the X468? Does the X468 come with its own landing gear?
I went to your blog to read more about gimbals, but it took a long time to load and I gave up. You should get your own dedicated domain and website.
Old Oct 09, 2012, 03:36 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Have you seen this gimbal? It actually seems to do quite a good job considering the price http://www.aeroxcraft.com/index.php?...&products_id=5
You might need to extend your landing gear a bit though.
If you can afford it, then you can't go wrong with the photohigher gimbal and it will be better if you upgrade your frame in the future. The problem is that to fit it you need to find an extended landing gear for your F450. There's plenty of them about though, so shouldn't be too difficult finding a suitable landing gear.
Old Oct 09, 2012, 04:06 PM
djrocketodd is offline
Find More Posts by djrocketodd
Joined Oct 2012
I want to know whats the best way to pick motors and batteries, I assume 900kv is 900rpm per volt, so a 7v battery spins slower then an 11v battery.
So to pick motors if I have criteria such as a 550 frame, quad x, want to lift total 3000g, (copter and slr,) how do i choose which battery and what Kv motors and what size props...
djrocketodd is offline Find More Posts by djrocketodd
Old Oct 09, 2012, 05:08 PM
Joined Oct 2012
This question is about charging Lipos, I have a 3s 2200mah, 35-70c, what amperage should i do a balance charge at, my charger is selectable from 0.1 to 6A.
Old Oct 09, 2012, 08:24 PM
isaacintheclouds is offline
Find More Posts by isaacintheclouds
Nevermind...
isaacintheclouds's Avatar
United States, CA, Carnelian Bay
Joined May 2011
I saw someone asking about prop sizes. I learned a lesson today about precisely this. I have a 550 quad I was experimenting with prop sizes on. It has a NAZA FC, and Avroto 2814 motors. I originally had some APS slow flyer 10x4.5 props on it and it did pretty well. I am building a heavy lift hexa that will soon ave a Sony nex5n on an AG550 gimbal hanging from it. Since I live at 600ft.(Tahoe), I figured I should do some prop tests on my quad to help me decide which ones I want to put on the Hexa. Heres how it went. I changed out the quads APC 10x4.5s with some Graupner 10x5" props. As it turns out the Graupners dont produce as much lift and needed higher RPMs to achieve flight. The higher RPMs turned out to be too high for the Avroto motors. When I would rotate the craft, or climb quickly, some of the motors would overspeed causing them to oscillate, causing the craft to wobble, then the NAZA compounded the wobble trying to compensate for it, which resulted in the crash in the first 30sec. of this video. (I got lucky and only broke a few props, and sliced up the E-ZUP tent canopy that it crashed into)
props size experiment (1 min 26 sec)
What did I learn? A prop of a certain size and pitch from one manufacturer likely doesnt produce the same lift of a prop of the same or similar size/pitch from a different manufacturer. Also, if you overspeed your motors there may be high speed oscillations of the motor as a result, causing a crash. I figure this may help anyone wondering about prop sizes. I am going a bit bigger with mine from now on flying generally at or above 6000". Hope this helps anyone pondering prop sizes!
isaacintheclouds is offline Find More Posts by isaacintheclouds
Discussion Do you know what airplane is this and who made it? mashca Vintage & Old-Timer Designs 11 Sep 13, 2012 11:43 PM
Discussion Do you know what airplane is this and who made it? mashca The Builders Workshop 5 Sep 11, 2012 07:05 PM
Question How do you know what part is bad? j2591 Micro Helis 5 Aug 13, 2012 07:39 PM
Discussion Do you know what this is? jaizon Thermal 3 Jul 22, 2012 02:09 PM
Wanted do you know what plane this is ? streetbikegod4 Aircraft - Electric - Airplanes (FS/W) 5 Mar 18, 2012 08:41 AM
