Old Jan 26, 2013, 01:41 PM
boardman is offline
Find More Posts by boardman
shredding the skies
boardman's Avatar
Wet Coast Canada
Joined May 2005
Originally Posted by Lenny7118 View Post
I'm new and going to start to build my 450 size quad and the frame isn't one of those DJI Power Distribution Frames.
I'm also going to install a WK-M Autopilot system.
Anyone have pics of their build! ( 450 )
Here is a great idea called the Power Spider
power spider (13 min 59 sec)
boardman is offline Find More Posts by boardman
Old Feb 08, 2013, 07:13 PM
edk83 is offline
Find More Posts by edk83
United Kingdom, Belper
Joined Jan 2011
What happens if I mount my kk2 not quite center on my quad? Say 1cm towards the rear but center on the horizonal? I need to fit my camera under the dome so may have to move the fc back a tiny bit. Will this cock anything up ?
edk83 is offline Find More Posts by edk83
Old Feb 08, 2013, 07:18 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
No, not at all. The FC need not be centered at all. Pointing straight and mostly level are far more important.
brontide is offline Find More Posts by brontide
Old Feb 08, 2013, 11:26 PM
Fastmetal is offline
Find More Posts by Fastmetal
Fastmetal's Avatar
United States, MO
Joined Dec 2012
Set-up Problem: KK2/V8FR-II, FrSKY Rx
S.O.S.
My Quad is ready for me to take it out and do a 10g landing, but I am stuck and would very much appreciate some help.
1. KK2 to Rx, can't figure out how to connect servo connectors and I have searched high and low.When I connect the KK2 to Rx with the first servo conn., I get a red flashing light in the LED on the Rx. When I connect the next servo conn. to the Rx, my KK2 shuts down and goes blank. That can't be good so I unplugged the battery....luckily no smoke.
Can anyone recommend any ideas on the set?
-KK2 1.5 firmware loaded
-ESC preflashed
2. Have a Turnigy 9XR and need a good resource on all the controllers functions.
Thanks in advance for any help and to the gentleman that shows the patience of Job and dedication to a great sport.
Fastmetal
Fastmetal is offline Find More Posts by Fastmetal
Old Feb 09, 2013, 02:22 AM
russers is offline
Find More Posts by russers
United States, CA, San Carlos
Joined Oct 2009
Starting upper left on your KK-2 Board
1 Aileron
2 Elevator
3 Throttle
4 Rudder
5 Aux.
Match this to your Rx and your good to go.......
The black or negative wire goes to the outside of the board.
russers is offline Find More Posts by russers
Old Feb 09, 2013, 08:20 AM
brontide is offline
Joined Sep 2012
Originally Posted by Fastmetal View Post
S.O.S.
Whoa!!! Look at the side of the Rx unit. You should see -, +, and ^ meaning negative, positive, and signal respectively. On the kk2 each row is negative, positive, and signal respectively from the outside and top down should attach to your Rx in sequence with top being channel 1, ....
If you are doing this correctly the Rx should stay on. If you are doing all this correctly and the light still goes out then you may have a short somewhere.
Old Feb 10, 2013, 02:45 AM
EZGoin is offline
Find More Posts by EZGoin
Joined Dec 2012
Prop Spacing
What effect does prop spacing have?
Building my own frame, what distance between props should I maintain?
Is 1/4" enough spacing from tip to tip?
EZGoin is offline Find More Posts by EZGoin
Old Feb 10, 2013, 06:02 AM
brontide is offline
Joined Sep 2012
There is no standard for tip to tip distance. I have built quads with 1/2 blade width all the way down to 1" overlap ( motors in different height positions ). All depends on the needs of the quad. Going too small might be a stability problem in two cases, if your ESCs are not fast enough to respond or if you end up creating more wake than needed.
For simplicity reasons a small distance of separation is probably a best idea.
Old Feb 10, 2013, 12:18 PM
EZGoin is offline
Joined Dec 2012
Wire Ties
I have built a quad with 1/2" poplar and drilled two holes for mounting the motor with screws. I am guessing that it wouldn't take much of an impact to torque the motor and split the wood. I would think wire ties would be better because they would just break, but I am afraid that they might break mid-air under stress.
I'd like to get some experienced input on this before I go and destroy my quad!
Old Feb 10, 2013, 12:38 PM
livinlife is offline
Find More Posts by livinlife
United States, KY, Bowling Green
Joined Aug 2012
If you just drilled 3mm holes then no worries. The motor can't stress the arm enough to damage it at the mount during flight. Damage will come from crash impact and it usually damages the arm where it mounts to the frame. You would much rather it split the wood during a crash then mess up your motor. That is the good thing about a wood arm that small.
livinlife is offline Find More Posts by livinlife
Old Feb 10, 2013, 01:11 PM
Cyberdactyl is offline
Find More Posts by Cyberdactyl
Misfit Multirotor Monkey
Cyberdactyl's Avatar
United States, NC, Garner
Joined Mar 2011
My contention is to not violate a wood boom if possible. Wood is an awesome material for a first time scratch build. It's dirt cheap, so a beginner will/should have less concern when he crashes. And you WILL crash.
Below is my first quad and it flies well. As a matter of fact, I just shot some video this morning since the weather was close to perfect.
And I agree with nylon ties, They are forgiving in a crash, they will stretch or break before the motor mount, and possibly before bending a shaft. I also designed my main frame to pinch the the boom instead of drilling through. I also kept as much mass as possible close to the center to allow for quicker axial movement.
Cyberdactyl is offline Find More Posts by Cyberdactyl
Old Feb 10, 2013, 01:27 PM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I like the two-tone wood effect. I haven't built a wooden frame/arm quad yet, but I might head down to my local DIY shop and see what they have and maybe experiment with a few ideas.
I'm stuck in the doldrums at the moment with working away from home and I only have my little Hubsan X4 to play with. I can't wait to get home and start building again. I've got a mountain of stuff waiting for me that I've purchased over the last couple of months and loads of building and testing to do.
http://drone-pilot.blogspot.co.uk/
lovegroove is offline Find More Posts by lovegroove
Old Feb 13, 2013, 04:20 AM
edk83 is offline
Joined Jan 2011
Thats lucky, it fits with about 2mm clearence!
Next thing I need to do is remove the two pins for the voltage buzzer on my kk2. Can I just desolder and pull these out? I will then solder the wires of the buzzer to the bottom of the board. The issue is that my camera hits these pins when I unscrew it from the mount.
Also does it matter which way the buzzer is connected to the pins?
Old Feb 13, 2013, 05:54 AM
Shehwar is offline
Find More Posts by Shehwar
If it flies then it will crash
Joined Aug 2012
Hi,
this is my first build.
will this motor work for a quad with AUW of 1kg ?? i can see it provides required amount of thrust. is it a good option to take ??
http://www.hobbyking.com/hobbyking/s...idProduct=5354
Shehwar is offline Find More Posts by Shehwar
Old Feb 13, 2013, 08:11 AM
Joined Mar 2011
I would say this is a tad under powered for a quad passing two pounds.
Discussion Do you know what airplane is this and who made it? mashca Vintage & Old-Timer Designs 11 Sep 13, 2012 11:43 PM
Discussion Do you know what airplane is this and who made it? mashca The Builders Workshop 5 Sep 11, 2012 07:05 PM
Question How do you know what part is bad? j2591 Micro Helis 5 Aug 13, 2012 07:39 PM
Discussion Do you know what this is? jaizon Thermal 3 Jul 22, 2012 02:09 PM
Wanted do you know what plane this is ? streetbikegod4 Aircraft - Electric - Airplanes (FS/W) 5 Mar 18, 2012 08:41 AM
