Old Oct 18, 2012, 05:23 PM
7AC is offline
7AC
Find More Posts by 7AC
7AC
7AC's Avatar
Central Indiana
Joined Oct 2006
Motor links
LG, OK the first is the Hobby King DT 750 I have 3 of these but all have quite a few hours on them, it is here: http://www.hobbyking.com/hobbyking/s...ner_750kv.html
The second is the GForce 35/30 I have one of these, it is here: GForce 35/30 http://www.valuehobby.com/power-syst...less-motor.htm
Third is the Hobby King 28/30, I have one of these, it is here:/http://www.hobbyking.com/hobbyking/store/__12921__D2830_11_1000kv_Brushless_Motor.html
Finally I have 3 HK35/36's they are here:http://www.hobbyking.com/hobbyking/s...ner_Motor.html
Thanks for your help!
7AC is offline Find More Posts by 7AC
Old Oct 18, 2012, 05:33 PM
7AC is offline
7AC
7AC
7AC's Avatar
Central Indiana
Joined Oct 2006
GForce 35/30 motor
Just checked the links in the foregoing, that G Force motor is here:http://www.valuehobby.com/power-syst...30-1100kv.html
Old Oct 18, 2012, 05:40 PM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I've had a look at all of the specs and none of them seem very well suited to for use on the 450 frame. Most of the motors would be better spinning an 11" or 12" prop which is too big for the 450 frame and the other is just way too big for 450 copter.
If you're going to buy new motors, then these from rctimer work really nice on the 450 frame spinning 10" props on a 3s lipo. http://www.rctimer.com/index.php?gOo...3&productname= I would expect to get 8-10 minutes of flying time using a 3s 2200mAh lipo.
lovegroove is offline Find More Posts by lovegroove
Old Oct 18, 2012, 09:38 PM
7AC is offline
7AC
7AC
7AC's Avatar
Central Indiana
Joined Oct 2006
28/30's
Thanks LG, I will give those a try.:
Old Oct 19, 2012, 03:38 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
They're nice motors and you won't be disappointed. Make sure you buy a couple of spare shafts though, because that's the one bit of them that is slightly fragile and can sometimes break in a heavy crash.
http://drone-pilot.blogspot.fr/
Old Oct 19, 2012, 09:23 AM
alainphoto is offline
Find More Posts by alainphoto
Japan, Tokyo, Chiyoda
Joined Oct 2010
I liked your first FPV article, I think it is good.
You may want to add the links to "How to be successful in FPV" and the "Top 10 things I wish I'd paid attention to when getting started in FPV" that is another good read.
Now what is really needed is a shopping list adapted to different needs and budget. The hardware changes a lot, new cams with better blacklight, better antennas, new googles, and things are compatible with each other etc ...
For example I want to add FPV to a DSLR octo with a 2.4 GHz Tx to shoot things in short distance, so I figured out I'd better take a 5.8GHz system with a cloverleaf type antenna and some googles, but I am far from having the full list of all I need with a reasonable budget. This is where shopping lists adapted to different needs and up-to-date with the new/proven products would be very helpful
Alain
alainphoto is offline Find More Posts by alainphoto
Old Oct 19, 2012, 09:36 AM
tedpretty is offline
Find More Posts by tedpretty
Joined Sep 2012
AP On Stock F550 motors, esc's, etc...?
Quick question...is a DJI F550 with stock parts strong enough to carry a go pro camera?
Will I need to go to 4s from 3s batteries?
Will I have to go to 10" props from 8"?
tedpretty is offline Find More Posts by tedpretty
Old Oct 19, 2012, 09:54 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Yes, it will easily carry a GoPro.
The other 2 questions I can't answer unless I know what ESCs and motors you're using. They may not be able to take a 4s Lipo. Usually when you go up in voltage, you go down in prop size, so moving from 3s to 4s you would probably go down an inch or 2 in prop size.
Old Oct 19, 2012, 09:56 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Alain
I'm working on that article! The first part is nearly finished and may be published tonight, but I'm moving from France to England tomorrow, so it will probably be the end of next week before I've finished my series of FPV articles.
Old Oct 19, 2012, 10:56 AM
Porthos23 is offline
Find More Posts by Porthos23
Joined Sep 2012
Originally Posted by lovegroove View Post
If you want to add LEDs then you need to check the LED specifications and then do a bit of mathematics. An LED has almost no internal resistance, so if you just hook it direct to a battery then the current will flow almost unimpeded and not only will you drain your battery quickly, but you will burn the LED.
This is why you have to look at the LED specifications for 2 key figures. You need to know the diode forward voltage (this is the voltage required to provide the forward bias to overcome the p-n junction) and the second is the diode forward current.
Once you have these 2 figures, you need to do some maths. A typical forward voltage would be 3.4v and typical forward current would be about 30mA. If you have a supply voltage of 4.2v (1s lipo) we subtract the forward voltage from the supply voltage (4.2-3.4) and then using ohm's law we divide that voltage by the forward current to work out what size resistor is required (0.8v/30mA 0r 0.8/0.030) which gives us the resistance that we need to put in series with the LED. In this case, the resistance = 26.666666, so we round up to a 27ohm resistor.
The power dissapated by the the resistor = I^2*R =24mW and in this case we would choose a 1/8W 27ohm resistor in series with the LED. The colour code for the LED is Red,Purple,Black.
Hope that helps.
LG
Thanks, that makes sense. A few more quick questions...
What if you wanted to power 2 3.4 v (30 mA) LEDs from the same source in series. Would the resistor change in this case, or is it just better to wire them in parallel with each LED getting a resistor?
Also, suppose you have a 3.4 v LED but your power source is 3.3 v... in this case I would guess I would not need a resistor but the LED may not be bright enough or light up at all if the voltage is too low?
Porthos23 is offline Find More Posts by Porthos23
Old Oct 19, 2012, 11:14 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Best to run them in parallel, each with its own resistor like in the picture. You can get LEDs with a lower forward voltage, so it's possible to power them from 3.3v. These ones for example have a forward voltage of 2.5v http://www.maplin.co.uk/multi-colour-led-613168
Unless it's an LED with a built in resistor, you should always use a current limiting resistor to power an LED.
edit Forgot to add this link to a calculator for calculating the require resistance: http://ledcalc.com
Old Oct 19, 2012, 11:29 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Slowly putting together my thoughts on my next build. Looking a a T6 style build. Any thoughts on the Turnigy 3020-1200 kV motors, ecalc seems to be giving me some very nice numbers and I'm sure I can beat my frame budget. Would be paired with 8x4.5SF props on a ~12-13" MTM distance frame ( triangle ). By the ecalc numbers it should be compact and powerful.
http://www.hobbyking.com/hobbyking/s...idproduct=9378
http://www.ecalc.ch/xcoptercalc_e.ht...h=4.5&blades=2
brontide is offline Find More Posts by brontide
Old Oct 19, 2012, 11:56 AM
Joined Sep 2012
When you balance graupner blades for the F550, what do you use to balance the blades...do you sand them or use polyurethane spray?
Old Oct 19, 2012, 01:02 PM
WhiteFox50 is offline
Find More Posts by WhiteFox50
United States, MA, Swansea
Joined Oct 2009
Small scrapbooking stickers or pieces of scotch tape work wonders for balancing props.
WhiteFox50 is offline Find More Posts by WhiteFox50
Old Oct 19, 2012, 03:31 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I usually sand the underside of the heavy blade, but all of my graupners have been just about perfect straight out of the bag.
Discussion Do you know what airplane is this and who made it? mashca Vintage & Old-Timer Designs 11 Sep 14, 2012 12:43 AM
Discussion Do you know what airplane is this and who made it? mashca The Builders Workshop 5 Sep 11, 2012 08:05 PM
Question How do you know what part is bad? j2591 Micro Helis 5 Aug 13, 2012 08:39 PM
Discussion Do you know what this is? jaizon Thermal 3 Jul 22, 2012 03:09 PM
Wanted do you know what plane this is ? streetbikegod4 Aircraft - Electric - Airplanes (FS/W) 5 Mar 18, 2012 09:41 AM
