Old Oct 16, 2012, 04:43 PM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I've started on the FPV article but am a bit worried that it's going to be too boring. There's a lot of information to try and get across and it takes a bit of explaining. Maybe I should just put a link to the 'How to be successful' thread in the FPV forum and then just get straight to a quick tutorial on a basic setup. What do you guys think?
Maybe I should post what I have so far so that I can get some feedback?
http://drone-pilot.blogspot.fr/
lovegroove is offline Find More Posts by lovegroove
Old Oct 16, 2012, 04:58 PM
Mic603 is offline
Find More Posts by Mic603
Joined Oct 2012
Copter configurations
Can someone explain the differences / pro and cons to the different copter configurations.
I see the following configuration, why would you choose one style over the other?
Tricopter
Quadcopter
Hexcopter
H-copter
Spidercopter
Mic603 is offline Find More Posts by Mic603
Old Oct 16, 2012, 05:05 PM
isaacintheclouds is offline
Find More Posts by isaacintheclouds
Nevermind...
isaacintheclouds's Avatar
United States, CA, Carnelian Bay
Joined May 2011
Originally Posted by lovegroove View Post
Good luck getting several hundred yards into a dense forest on 5.8GHz! Maybe with a really really high gain helical antenna pointing directly at the copter and a skew planar on the video tx, but even then that would be tricky.
5.8GHz isn't bad, the record is over 20Km using only a 200mW video transmitter. The thing with quads is that they are great for flying in and around objects, and of all the frequencies we use for FPV, 5.8GHz is the worst for this.
I use 5.8GHz (200mW) on one of my copters, with a pair of circularly polarized antennas and it's good for over 500m, but I have video drop-outs as close as 60m if I fly behind something.
My personal best long range is 4km with a 2.4ghz system. 1000mw Vtx with IBcrazys cloverleaf rhcp antenna, 11dbi helical rhcp Vrx antenna , and a dragonlink uhf control upgrade on an old futaba radio. Flying out was all good but when I turned around the image got pretty grainy for a little while until I got about 1km closer, then it cleared up. I was fairly high up but being over a forest probably cut my range down since pine trees absorb radio signals, (or so I have heard).
isaacintheclouds is offline Find More Posts by isaacintheclouds
Old Oct 16, 2012, 05:12 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Tricopter
Quadcopter
Hexcopter
H-copter
Spidercopter
Tricopter has 3 motors, so cheaper to build, good for FPV because of the Y shape
Quadcopter - h-copter and spider copter are just variations of a quadcopter that try to optimize it for carrying a camera without the props/frame being in view.
Hexacopter - more lifting capacity and a bit of motor redundancy in case one motor fails.
Octocopter - Even more lifting capacity and multiple motor redundancy.
Of course there are more variations like Y6, X8 quad+, quadx, Hexa+ and HexaX.
There isn't one configuration that is better than all others as they each have benefits depending on your needs. If you're just getting into multicopters then it's probably best to start with a simple quadcopter and go from there.
Old Oct 16, 2012, 05:17 PM
Nevermind...
Joined May 2011
Tricopter
Quadcopter
Hexcopter
H-copter
Spidercopter
IMHO, alot of it is personal preference. The spiders advantage is that the camera doesnt get the props in the picture and I imagine that the sunlight wont cause the shadow lines in the video and pics as much. In my experience, hexacopters are somewhat more stable than quad. Also, certain flight controllers like the DJI wookong-m can fly a hexa with one motor down. It spins the heli around the stopped motor and enables a controlled soft crash so the copter and equipment arent destroyed. Im not sure what the advantage to h or tri copters is aside from redundancy in the case of a Y6 or X8 configuration- if one motor fails it can maintain flight, (depending upon the weight, motor size etc.), but Im sure more resons will get posted... Cheers!
I started out with a Gaui quad and have been working my way up from there. I am currently working on getting my f550 hexa upgraded to heavy lift for an AG550 gimbal and a Sony NEX5N camera!
Old Oct 17, 2012, 12:53 AM
bigstatik is offline
Find More Posts by bigstatik
T-28 abuser
bigstatik's Avatar
United States, NY, New Paltz
Joined May 2009
I see a lot of F450s with cameras mounted at the front of the top plate.
I tried this and even with the battery mounted as far back as possible the CG is still WAY to the front. How are people balancing them, or are they just flying them with the forward CG and letting whatever FC they are using deal with it?
Thanks.
bigstatik is offline Find More Posts by bigstatik
Old Oct 17, 2012, 05:32 AM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
Maybe smaller camera or bigger battery?
brontide is offline Find More Posts by brontide
Old Oct 17, 2012, 05:58 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Thanks.
A well tuned flight controller will allow you to fly with an off balance CofG, but it's not ideal as you'll be running those motors harder all the time and it may cause control problems at high throttle values. With the RC receiver mounted on the opposite side and with the battery mounted as far back as possible it is possible to get a reasonably well balanced 450 with the GoPro mounted on the front.
Old Oct 17, 2012, 06:13 AM
alainphoto is offline
Find More Posts by alainphoto
Japan, Tokyo, Chiyoda
Joined Oct 2010
Good idea, go for it
Another article idea : how do open up a motor, what to check, how to repair it ?
alainphoto is offline Find More Posts by alainphoto
Old Oct 17, 2012, 07:09 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Apart from changing a worn bearing, I rarely go there and wouldn't want to risk a dodgy motor on my copter and would prefer to change the motor.
Old Oct 17, 2012, 12:06 PM
brontide is offline
Joined Sep 2012
But still..
How to identify a bad motor.
How to identify a bent shaft.
How to identify worn bearings.
Signs that a motor is failing.
Also maybe some basic flowcharts for flying problems
My multi tips to the right
Can't hover
Turns to the left
Links to good training "stick videos".
Old Oct 17, 2012, 12:09 PM
AcroFPV is offline
Find More Posts by AcroFPV
we dont NEED roads!
AcroFPV's Avatar
United States, CA, Rocklin
Joined Aug 2012
This will depend on what motor you are using. The only "serviceable" part inside a motor would be to replace the bearings. Unless you are a pro and want to re-wind a motor.
AcroFPV is offline Find More Posts by AcroFPV
Old Oct 17, 2012, 12:58 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Originally Posted by brontide View Post
But still..
Can't hover
Turns to the left
I'm busy working on the FPV articles, but I'll think about it when I've finished those. Maybe I can get a motor fetishist to be a guest writer and do an article for me, because I've never even considered re-winding a motor (probably because I don't own any really expensive motors). The only things I;ve ever replaced are worn bearings and bent/broken shafts and even then, it's hardly worth the effort.
Old Oct 17, 2012, 02:42 PM
T-28 abuser
bigstatik's Avatar
Joined May 2009
Thanks, I am using a Canon SD870is. It's atleast twice as heavy as a go pro.
Maybe I need to mount it closer to the center.
Old Oct 17, 2012, 02:43 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Why not extend the landing legs on your F450 frame and mount your camera underneath?
Discussion Do you know what airplane is this and who made it? mashca Vintage & Old-Timer Designs 11 Sep 13, 2012 11:43 PM
Discussion Do you know what airplane is this and who made it? mashca The Builders Workshop 5 Sep 11, 2012 07:05 PM
Question How do you know what part is bad? j2591 Micro Helis 5 Aug 13, 2012 07:39 PM
Discussion Do you know what this is? jaizon Thermal 3 Jul 22, 2012 02:09 PM
Wanted do you know what plane this is ? streetbikegod4 Aircraft - Electric - Airplanes (FS/W) 5 Mar 18, 2012 08:41 AM
