Old Oct 14, 2012, 06:51 PM
ritchie_laird is offline
Find More Posts by ritchie_laird
ritchie_laird's Avatar
Australia, VIC, Craigieburn
Joined Jul 2012
Originally Posted by brontide View Post
In parallel the batteries become a 8ah 3s battery and in serial they are a 4ah 6s. Normally I have been using the balanced or regular charge at 4ah.
so if you are trying to charge in parallel, how are you putting in both the balance leads into the charger? and how does the charger know what battery needs more charge?
ritchie_laird is offline Find More Posts by ritchie_laird
Old Oct 14, 2012, 07:23 PM
brontide is offline
Find More Posts by brontide
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
You just make a 1:x lead. You generally only parallel charge when the batteries are similar voltage levels and at that point the lowest voltage will pull more charge. This is not dissimilar to the fact when you put a charge into a 3 cell battery all the cells generally end up charged equally.
brontide is offline Find More Posts by brontide
Old Oct 14, 2012, 07:59 PM
Joined Jul 2012
the logic of the charger and the balance plug that goes to each of the cells separately handles that. I personally would not charge that way, I have seen to many things destroyed from lipo's being charged unattended or being charged wrong. to me its like saying a nicad charger charges voltage and current so that should be fine for lipo's, BANG!
to late to change your mind when it happens.
so I prefer to charge the recommended way to be safe.
Old Oct 14, 2012, 08:10 PM
brontide is offline
Joined Sep 2012
http://www.hobbyking.com/hobbyking/s...dProduct=14852
http://www.hobbyking.com/hobbyking/s..._6S_w_XT60.htm
This is not uncommon practice, just looking from clarification.
Old Oct 14, 2012, 08:15 PM
Joined Jul 2012
it may not be uncommon practice but look no further than the manufactures recommended safe practice. if it does the wrong thing it can be as quick as this video.
LiPo and Car fire (1 min 7 sec)
Old Oct 14, 2012, 08:20 PM
Joined Jul 2012
the second link I would agree with as the balance charger will charge the cells separately, 6 cell charge to 2*3 cell handles that but not paralleled together.
Old Oct 15, 2012, 09:15 AM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Batteries.
Is 10v a good alarm voltage for a 3s lipo pack?
How often can I quick charge without damaging my pack?
How often should I be doing a balancing charge?
If I have 2 4ah 3s batteries and a 6a charger I can charge in parallel and charge 2 in 150% of the time or using a serial rig to charge both packs as a 6s.
I prefer to time my flights and try to land with about 10-15% capacity left in the Lipo. I guess 10v would be a good voltage for a Lipo alarm though.
Lipos should only be charged at the recommended charge rate and it's dangerous to charge them too fast. I have some that can be charged at 5C, but I usually charge at 1C 1in every 5 charges and it seems to keep my packs healthy.
I would charge them in series using an adapter that converts a 6s balance port into 2 x 3s balance ports. Charging in series like this is much more likely to result in a fire if there's a problem, so be extra vigilant when charging.
I'm sure you're already aware of how dangerous Lipos can be, but it's worth mentioning again that you shouldn't ever leave them unattended when charging and charge them away from anything flammable and once charged store them in a Lipo safe bag or similar.
lovegroove is offline Find More Posts by lovegroove
Old Oct 15, 2012, 04:43 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I've just added a new page about multicopter safety. If this stops one person from getting injured then I consider it a success.
http://drone-pilot.blogspot.fr/2012/...er-safety.html
Old Oct 15, 2012, 05:08 PM
brontide is offline
Joined Sep 2012
don't rush out to fly... Every time you spool up, even if you never even take off there are risks.
If it doesn't behave as expected, don't throttle up to see if more power will help without first rechecking everything.
Whenever wiring up something new, always confirm there is no short.
Deburr metal frames. The last thing you need is an aluminum frame piercing a lipo or shorting a wire.
A large field is good for a start, but before any more range is attempted always range check the equipment.
Old Oct 15, 2012, 05:12 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I used to have range check on my pre-flight, but haven't found a good way of doing a range check with a multicopter.
Old Oct 15, 2012, 05:14 PM
brontide is offline
Joined Sep 2012
Tie down, spool up to spinning and have someone drive away with the Tx?
With the KK board you could also have someone keep running the disarm stick movement while you move the multi away until it stops disarming.
Old Oct 15, 2012, 05:19 PM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I fly on my own most of the time, so no use for me. I decided that doing a range check was actually more dangerous than not doing one.
Old Oct 16, 2012, 04:04 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
I need some more ideas for articles. What would you like to see?
Old Oct 16, 2012, 05:08 AM
Joined Jul 2012
hi lovegroove, I have given up on the hk controller and bought a Rabbit with gps, and sonics ect. been in a flying unit and I have seen it perform. so if this dont work nothing will (for me that is).
awaiting arrival, should be next week.
Old Oct 16, 2012, 05:52 AM
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
Why not enter my halloween competition and then you can win a controller. Your copter doesn't have to be flying to be able to win!!!!
Discussion Do you know what airplane is this and who made it? mashca Vintage & Old-Timer Designs 11 Sep 13, 2012 11:43 PM
Discussion Do you know what airplane is this and who made it? mashca The Builders Workshop 5 Sep 11, 2012 07:05 PM
Question How do you know what part is bad? j2591 Micro Helis 5 Aug 13, 2012 07:39 PM
Discussion Do you know what this is? jaizon Thermal 3 Jul 22, 2012 02:09 PM
Wanted do you know what plane this is ? streetbikegod4 Aircraft - Electric - Airplanes (FS/W) 5 Mar 18, 2012 08:41 AM
