Old Sep 30, 2012, 12:58 PM
itsme2 is online now
Find More Posts by itsme2
United States, TN, Maryville
Joined Mar 2011
Corrosion X Or Corrosion Block - Is One Better Than The Other?
Is there a difference or preference for either one of these products when it comes to effectiveness regarding electrical/electronics in R/C water planes?
Thank you!
itsme2 is online now Find More Posts by itsme2
Old Oct 06, 2012, 03:45 PM
Joined Mar 2011
bump.
Old Oct 06, 2012, 04:06 PM
kingsflyer is online now
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
I've used CorrosionX for over three years now without a failure. CorrosionX has a 40,000 volt dielectric property and will not degrade printed circuit boards or their components. This is very important for our 2.4 gHz receivers that can be effected by very low voltage leaks across the lands of the printed circuit boards.
I've never tried Corrosion Block so I can't give you a comparison. However, the Corrosion Block site does not address any electrical properties of the product, or if it is safe for electrical printed circuit boards or components.
McD
kingsflyer is online now Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Oct 06, 2012, 04:22 PM
jimsp is offline
Find More Posts by jimsp
jimsp's Avatar
Sayre,PA
Joined Sep 2002
I ran some tests with Corrision Block to see if it would protect a brushless ESC from water being sprayed on it. It didn't work as the motor began to stutter so I quickly unplugged the battery. At the time I didn't have any CorrisionX on hand so I don't know if it would have passed the same test.
jimsp is offline Find More Posts by jimsp
Old Oct 06, 2012, 08:55 PM
jimsp is offline
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Here's where I reported my results on the Corrision Block test.
http://www.wattflyer.com/forums/show...99&postcount=4
Discussion hpi sprint 2 drifts better one way than other.. help! JdmJohnny210 On-road Cars 8 Aug 15, 2012 08:59 PM
Sold one of the best indor helis the v911 (similar or better than trex100 and solopro) jaas75 Aircraft - Electric - Helis (FS/W) 3 Jun 22, 2012 09:13 AM
Discussion Zippy Flightmax or Turnigy 4s 5000mah. Is one better than the other. jasper7821 Batteries and Chargers 19 May 05, 2012 09:31 PM
Discussion Why is ezosd better than others? goldsworthy FPV Talk 17 Apr 29, 2012 04:11 PM
