Old Sep 30, 2012, 12:24 PM
texs24 is offline
Find More Posts by texs24
Joined Sep 2011
Dynam Peaks Biplane Prop Flew Off
I was recently flying my Dynam Peaks biplane and mid-flight the prop and spinner flew off. Luckily, I was able to land the plane but it was a hard landing. The gear ripped out of the foam. The back of the gear tore into the bottom part of the wings and the metal landing bar was warped. I checked the spinner and I could not have tightened the nut up anymore than I did. There were grooves in the motor shaft from where the spinner flew off. Has anyone else experienced this problem. I was not doing any 3D flying - just normal flight.
texs24 is offline Find More Posts by texs24
Old Oct 01, 2012, 04:34 PM
RaidenCharlie is offline
Find More Posts by RaidenCharlie
HobbypartZ Support
Joined Jul 2011
Did you balance the prop? The props isn't coming balanced from the factory and it's highly recommend to balance the props on all of the new Dynam planes.
-Charlie
RaidenCharlie is offline Find More Posts by RaidenCharlie
Old Oct 15, 2012, 05:23 PM
texs24 is offline
Joined Sep 2011
Charlie,
Thanks for your quick reponse. I bought a prop balancer and will see if it helps. It can't hurt!
Discussion [LOST] My Dynam Hawk Sky Flew Away from Me rcmaverick Electric Plane Talk 8 Aug 25, 2012 10:47 PM
Wanted Dynam peaks biplane beercandan11 Aircraft - Electric - Airplanes (FS/W) 3 Jul 10, 2012 10:07 AM
Question DYNAM SU-26 and DYNAM PITTS/PEAKS ? pc_pilot Nitro Planes 3 Mar 29, 2012 09:32 PM
