Old Sep 30, 2012, 10:20 AM
DudeInMyrtleBch is offline
Find More Posts by DudeInMyrtleBch
United States, SC, Myrtle Beach
Joined Jun 2011
Question
Just got a new Gens Ace 6s 5300mah 60c pack... High internal resistance?
I just received a new 6s 5300mah 60c pack from hobbypartz.com. I put it on my icharger to read the internal resistance, and got the following readings per cell (in mohms)
5 3 9
5 4 2
This is before the initial charge. It's sitting at storage voltage as of right now - and all the cells are exactly 3.84 volts.
According to everything I've read, these IR numbers are quite high. The application that I'm using this battery for is going to really, really stress it.
DudeInMyrtleBch is offline Find More Posts by DudeInMyrtleBch
Old Sep 30, 2012, 10:28 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
At what temperature was the pack when you measured it? What specific model iCharger do you have?
Has the pack been lightly cycled a few times? Internal resistance improves after a few cycles.
If the pack was over 70F and it has been cycled a few times, then yes, it's likely a suspect pack, especially if you have used your iCharger to test other packs and they measured much lower.
BTW, what specific brand and model is the lipoly? This would be helpful to others who are in the market. That kind of poor performance and variability puts it on the 'avoid' list. (edit: Nevermind on this question. I see that it's in the thread title)
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Sep 30, 2012, 10:29 AM
wingster is online now
Find More Posts by wingster
Massachussets
Joined Nov 2005
I have four of the Gens Ace 5300 30C 5s. As read on a PL8 at 68F the cell IR reads about 2 mohm. They may have been a little higher when new.
I'd try one charge/discharge cycle, if you don't get substantial improvement I'd return them
wingster is online now Find More Posts by wingster
Old Sep 30, 2012, 10:32 AM
papabatman is offline
Find More Posts by papabatman
Shut up and fly
papabatman's Avatar
United States, CO, Dacono
Joined Jun 2008
question so does his reading make it a 11 true c rated pack
papabatman is offline Find More Posts by papabatman
Old Sep 30, 2012, 02:15 PM
Joined Jun 2011
I literally pulled it out of the box, installed an EC5, and plugged it into my icharger - a 206b.
I did notice that I get mostly different readings - within 1mohm - every time I test it. For example, the cell with the ir of 9 will read 8 occasionally, etc...
And, I didn't charge it at all, I just tested the IR.
I'll hook up some of my other packs when I get home, and let you know what they say. I expected to see a pack IR of 8-12. Not 28-30, lol.
I keep my house at 71, so the pack was somewhere close to that.
EDIT: I'm also going to check the firmware version on my icharger... might be old... stranger things have happened..
Old Sep 30, 2012, 04:40 PM
785boats is online now
Find More Posts by 785boats
RELAX. You'll live longer
785boats's Avatar
Brisbane- Australia
Joined Jul 2007
I've always thought that the most accurate reading of IR is when the pack is fully charged.
Those numbers will drop when the measurements are taken when it is charged.
And as stated by mrforsyth the numbers should drop after a few cycles.
785boats is online now Find More Posts by 785boats
Old Sep 30, 2012, 05:38 PM
Joined Jun 2011
I just got home. I've plugged the GA lipo in and am doing an initial charge at 1c. I took another measurement, and got different results - again.
The battery temp was 73 degrees.
The IR from the balance plug read
5 3 7
5 4 2
So, a total pack IR of 26 mohms
If I unplug the balance plug, and do a pack IR measurement with just the EC5 plugged in, I get between 35-38 mohms.
FWIW, the icharger is running the latest firmware.
Old Sep 30, 2012, 06:01 PM
Wayne Giles is online now
Find More Posts by Wayne Giles
Rugby, UK
Joined Feb 2007
5 3 7
5 4 2
The difference between the 26 and 35 milliohms is the addition of the connector and leads. It is surprising how much these will add as they Palso include the intercell connections in the pack.
The i charger only has a resolution of 1 milliohm which limits its value in measuring large cells, ie cells with low IR values of which 1 is a significant %.
Assuming the instrument is perfectly accurate, then a reading of 3 milliohms only tells you that it is between 2.5 and 3.5 at best. Include a small reading error and this expands to between 2 and 4 milliohms.
Wayne
Wayne Giles is online now Find More Posts by Wayne Giles
Old Sep 30, 2012, 06:56 PM
Joined Jun 2011
Ok, So the charge is complete. It now reads:
2 1 4
3 1 0
It gets the same readings fairly consistently.
I measured several other batteries I had handy:
2x Turnigy 4s hard case 5000mah 20c:
Battery 1 - 10 cycles on it: 2 0 1 0
Battery 2 - 12 cycles on it : 1 1 0 1
Turnigy 5s 5000mah 30c - Countless cycles on it - several dozen at least:
2.2 1 0 3
The only question that I have now is -- is this new battery going to get better after several cycles? Anyone have an opinion?
This just wasn't the performance I was expecting out of a >$100 pack. Maybe I should have snagged a 6s 40c Turnigy...
Old Sep 30, 2012, 08:10 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
It should get better after several cycles.
And you have seen what one cycle did.
You changed the plug so you are stuck with the battery now.
A good way to handle new packs is to measure the voltage, cycle several times with an adapter instead of cutting the original plug, measure the IR and run a load test.
All this before you modify the pack so if things look bad you can return it.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old Sep 30, 2012, 09:22 PM
Joined Jun 2011
I didn't change the plug -- it didn't come with one.
Old Oct 01, 2012, 08:41 AM
ror1 is online now
Find More Posts by ror1
FPV'r
ror1's Avatar
Canada, ON, Carleton Place
Joined May 2011
"This just wasn't the performance I was expecting out of a >$100 pack. Maybe I should have snagged a 6s 40c Turnigy... "
no LiPo is worth that...buy from HK only..
The most expensive 3S2200 ($44) I bought is the worst battery I have because it has blown up like a ballon after 1 year. It was bought state side...never again...total ripoff...and they will not replace without returning it...returning will cost the price of several HK battery..
I have had several things refunded at HK and all I had to do was send them pictures..
ror1 is online now Find More Posts by ror1
Old Oct 01, 2012, 08:54 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
2 1 4
3 1 0
2.2 1 0 3
My suggestion:
email the vendor explaining the problem. Request permission to try the pack in the application you are going to use it in and see how it works with the understanding that if it doesn't perform he will replace it.
hoppy is offline Find More Posts by hoppy
Old Oct 01, 2012, 12:53 PM
FlyHighSelllow is offline
Find More Posts by FlyHighSelllow
Champagne Supernova
FlyHighSelllow's Avatar
United States, FL, Orlando
Joined Jul 2010
Thats why I dont buy Gens anymore or rarely from Hobby Partz etc.
FlyHighSelllow is offline Find More Posts by FlyHighSelllow
Old Oct 01, 2012, 02:20 PM
Harry D is offline
Find More Posts by Harry D
TLAR Aviation
Harry D's Avatar
Canada, AB, Edmonton
I have a Gens Ace 3S 5500 which I bought in the summer of 2011. Not sure if that has the same cells as yours, but the info below may help.
At the time, I did some fairly careful testing to see (just out of interest) the effects on IR of things like initial cycling, state of charge, etc.
My pack showed cell IRs around 1.8 milliohms at 19C (Wayne's meter), giving a FOM of about 1.2.
I'm only using this pack as a source battery for a portable micro lipo charger, so I don't really care about the actual C value (and which is why it has such a small connector!). But if I did need a higher C, I would rate that pack as pretty good.
If anybody's interested, I've attached the results sheet I made up at the time and would be interested to hear any comments on what I found.
Basically, I didn't find that IR dropped after a couple of initial cycles, contrary to conventional wisdom (maybe it's pack-specific).
Also, I did find a fairly consistent (but not huge - about 25%) variation of measured IR with state of charge. Lower indicated IR at full charge than when discharged (not unexpected, really). Again, opposite to what I've read elsewhere.
I believe my methodology and equipment was reasonably good, but feel free to pick it apart.
(If I've gone too far off topic, please say so and I'll edit accordingly).
Harry D is offline Find More Posts by Harry D
Sold GENS ACE 5300mah 5S1P 18.5V 30C Lipo battery pack ripping Aircraft - Electric - Batteries & Chargers (FS/W) 1 Sep 24, 2012 06:02 AM
Sold 2 Great Condition Gens Ace 6S 30C 5300Mah Li-Pos helinut4ever Aircraft - Electric - Batteries & Chargers (FS/W) 1 May 27, 2012 05:58 PM
For Sale GENS ACE 5300mah 2S1P 7.4V 30C LiPo RC Battery Pack livinma1 Aircraft - Electric - Batteries & Chargers (FS/W) 1 Apr 30, 2012 09:15 AM
Sold SOLD - (2) GENS ACE 5300mah 6S1P 22.2V 30C LiPo RC Battery Pack KingJoe Aircraft - Electric - Batteries & Chargers (FS/W) 2 Apr 28, 2012 09:25 AM
Sold 4 x Gens Ace 6s 5300mAh 30C Packs (New) jholen Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jul 12, 2011 06:15 PM
