Old Sep 30, 2012, 08:47 AM
Anjan Babu
Joined Dec 2011
Motor-ESC connectors?
what sort of connectors, can I use for hooking up my motor to the ESC, besides the usual bullet connectors?
My motor draws about 30amps on a 7x6 prop, so the connectors must be capable of handling atleast 30A.
Anjan Babu is offline Find More Posts by Anjan Babu
Old Sep 30, 2012, 09:17 AM
muncheyboy
Joined May 2011
conectors
i just got back from wallmart with a new soldering iron. i sat down & was just about to look around & ask. i forgot to look for diffrent conectors, if i see any thing ill let you know, . larry...
muncheyboy is offline Find More Posts by muncheyboy
Old Sep 30, 2012, 09:48 AM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
Joined Aug 2009
3.5mm bullet connectors are pretty standard in that current range. They can be found pretty much anywhere that sells motors and ESCs. Males go on the motor, females on the ESC. Solder 'em on, cover with heatshrink. Done.
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Sep 30, 2012, 09:51 AM
Jack
USA, ME, Ellsworth
Joined May 2008
There are many choices, here is just one listing:
http://www.headsuprc.com/servlet/the...ORS/Categories
For a 30A rated motor I would use 3.5mm bullets on the ESC (sockets) to motor (bullets) connections. I like the 3.5mm bullets as a good all around size for motors bigger than 40 grams or so up to over 100 grams. That way I can mix and match my ESCs and motors as much as I want or need to.
For the battery I am a Dean's Ultra person. Or the T-plug cones. On the clones I like the ones with the "X" pattern molded into them as they are easier to get a grip on.
Others will prefer XT60, EC3, APP, or whatever they got started with on batteries. It makes sense to have the same connector on most of your batteries. And the socket or female should be on the battery and the male on the ESC so that you do not have exposed contacts with voltage on them.
Jack
jackerbes is offline Find More Posts by jackerbes
Old Sep 30, 2012, 10:01 AM
peterangus's Avatar
Blackpool, Great Britain (UK)
Joined Dec 2003
Three small blobs of solder per motor is all that is required.
Lighter, neater, quicker, universal, more reliable.
peterangus is offline Find More Posts by peterangus
Old Sep 30, 2012, 09:04 PM
muncheyboy
Joined May 2011
conectors
thanks for the in put, i never knew about heads up. iam in myrtle beach, thats just down the road from me = 2-3 day delevery !
Old Oct 01, 2012, 08:02 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Great people to deal with, Jeff is a flyer and understands our needs.
Jack
Old Oct 11, 2012, 06:05 AM
LawnDartMike's Avatar
United States, OR, Salem
Joined Jan 2012
What would be the amp limit on the 3.5mm connector? I have a 60 amp esc with 4mm on it but will only be running around 45 amps through it. I hate to buy the 4mm when I have a bunch of 3.5mm laying around.
LawnDartMike is offline Find More Posts by LawnDartMike
Old Oct 11, 2012, 06:17 AM
Jack
USA, ME, Ellsworth
Joined May 2008
The 60A rating is the max amount of current the motor will be allowed draw safely, on the motor leads that would be divided into three equal smaller and intermittent loads.
I would not hesitate to try the 3.5mm connectors even if I were going to hit the 60A peak momentarily and occasionally. I'd give a five to ten second full throttle static test run and feel the connectors by hand. And unless they were hot I'd consider it to be fine.
Jack
Free titan 12t 550 motor esc and deans connector MIKEYOUR Free Items 1 Sep 13, 2012 02:40 PM
Discussion Motor/ESC Connector jcase Power Systems 5 Jul 26, 2012 11:35 AM
Help! Uh, ESC motor-connectors? Rakrul Multirotor Talk 9 Jul 10, 2012 06:47 PM
Question What size bullet motor / esc connectors? DanWard Power Systems 3 Apr 13, 2012 06:49 AM
Question Connectors Bat - ESC Connectors ESC - Motor? panzerd18 Power Systems 5 Mar 06, 2006 11:14 AM
