Old Sep 30, 2012, 03:50 AM
jppom is offline
Find More Posts by jppom
Mr Happy
United States, AL, Montgomery
Joined Jul 2011
Build Log
Footy Half Pint Too
This is a captioned picture build log for a Half Pint Too Footy designed by Bill Hagerup. The styrene hull is inexpensive and comes from Craig Huzway at Breaking Wind Boats (.com). Details kept to a minimum, because I didn't plan on doing a log, but questions welcomed. Use the design PDF as a starting point and check this log for supplemental details.
Balsa, bass wood, a few ice cream sticks, brass rod and tube, carbon tube, 30 min epoxy and filler were the materials used to complete the hull.
I tend to build heavy to Grandson proof, so lighten anywhere you can. My finished boat, ready to sail with AAA batteries was about 120g over the designers recommended 350g.
Added pictures of radio casette and fitting in measurement box.
jppom is offline Find More Posts by jppom
Old Oct 18, 2012, 03:31 AM
jppom is offline
Mr Happy
Joined Jul 2011
B Sail Finished
Finally got the CLR and CE problems worked out for the mid-range high aspect sail.
Narrow hull heels quickly; high CE on sail moves aft quickly; gets aft of CLR; boat stalls out and then starts sailing backwards. Adjusted the mast bend from ~90 degrees to two 45s and moved sail forward about one inch, which solved the problem.
Old Oct 18, 2012, 03:42 AM
gpzy is offline
Find More Posts by gpzy
FROM THE MIND OF A MADMAN
gpzy's Avatar
Joined Apr 2007
Thanks for posting the build. Got to love the Footy class sailboats!!!
gpzy is offline Find More Posts by gpzy
Old Dec 08, 2012, 09:04 PM
xmod57 is offline
Find More Posts by xmod57
United States, AZ, Phoenix
Joined Sep 2010
Is there room to keep servos under the deck? I am looking at ordering one of these.. Thanks..
xmod57 is offline Find More Posts by xmod57
Old Dec 09, 2012, 02:18 AM
jppom is offline
Mr Happy
Joined Jul 2011
Yes, but tight fit in the narrow hull for the servo arm sweep. I choose the external electronics to make a cassette interchangeable between all of the footys I have built.
Old Dec 09, 2012, 05:46 PM
gio06226 is offline
Find More Posts by gio06226
Joined Apr 2007
To be class legal shouldn't the rudder be able "of the full motion used while racing, without being restricted by any part of the measurement box"?
gio06226 is offline Find More Posts by gio06226
Old Dec 10, 2012, 03:31 AM
jppom is offline
Mr Happy
Joined Jul 2011
My rudder has about 20 degrees of movement when in the box. If I were to race it, I would have to make an original design rudder to give about 30-35 degrees. I modify most of my building to have interchangeable parts; ie rudders, keels with different ballast weights, sails ABC in sloop and Unirig, and electronics cassettes, but as I said, I don't race anyone but my own boats here in Montgomery.
Old Dec 12, 2012, 01:44 PM
marter1229 is offline
Find More Posts by marter1229
marter1229's Avatar
United States, ID, CDA
Joined Aug 2005
Great looking boat1
I need one.
Terry
marter1229 is offline Find More Posts by marter1229
Discussion Polycrylic for $3.50 a half pint reacher10 Hot Online Deals 0 Mar 22, 2009 07:06 PM
dumas half-pint and sk-daddle jr. Kloud Dock Talk 4 Dec 02, 2008 12:24 PM
Cool Half Footy pitviper51 Sailboats 17 Jul 19, 2006 10:10 PM
Half Pint Conversion J Bergsmith Parkflyers 6 Feb 16, 2002 05:27 PM
