Old Sep 29, 2012, 11:23 PM
prodriverex is offline
Find More Posts by prodriverex
The Engineer
prodriverex's Avatar
Singapore
Joined Dec 2009
How and what ESC settings do you put on yours?
Brakes, ON or OFF?
Switching Freq? 8 or 16kHz? My Turnigy Trust 55A has this but i never seen this in other ESC.
prodriverex is offline Find More Posts by prodriverex
Old Sep 30, 2012, 12:31 PM
Steveis is offline
Find More Posts by Steveis
AVR Dude
United Kingdom, England, Cnwll
Joined Jul 2011
Brake off
NiMH battery
16kHz
Start mode normal
Cut off soft
Steveis is offline Find More Posts by Steveis
Old Sep 30, 2012, 01:53 PM
NtiT is offline
Find More Posts by NtiT
Joined Sep 2012
I set my switching freq. to high (22-30) and it works well.
NtiT is offline Find More Posts by NtiT
Old Sep 30, 2012, 04:42 PM
dutchcommando is offline
Find More Posts by dutchcommando
making crashing a lifestyle!
dutchcommando's Avatar
The Netherlands, UT, Soest
Joined Feb 2012
the list as Stevis said..
but nowadays i just flash them to simonK firmware when i get them..
nothing more to do anymore with settings.. just throttle cali and use and abuse!
dutchcommando is offline Find More Posts by dutchcommando
Old Sep 30, 2012, 06:32 PM
2400RDR is online now
Find More Posts by 2400RDR
Out of helis, sanity returning
United States, FL, Lake City
Joined Feb 2009
I flash mine with SimonK too. No muss no fuss. They work better for multirotors too when flashed.
2400RDR is online now Find More Posts by 2400RDR
Old Sep 30, 2012, 06:53 PM
The Engineer
Singapore
Joined Dec 2009
Not all can flash.. at least my Trust 55 is not on the list.. I forgot to take a look at the circuit when I remove one of the shrink. Now that I put it back with bullets soldered, I dun have a bigger shrink to pass through that size now if I cut open.
There is this timing setting: auto, 7deg for multi poles motor, and 30deg for out runner! My motor is both multi and OR! I opt for 7deg since its a disc shape with 24poles.
Yes freq I choose 16khz.
Old Sep 30, 2012, 08:50 PM
NtiT is offline
Joined Sep 2012
7 is for in runners, with usually less than 5 poles. 30 is for more poles, like almost all outrunners. Choose 30 definately for a motor with 24 poles.
Old Sep 30, 2012, 09:28 PM
The Engineer
Singapore
Joined Dec 2009
Ok will switch to that.
Just another elementary question on the Tx. I know this is a multi rotor heli setup, but we have to chose Acro mode as model type?
Old Sep 30, 2012, 10:33 PM
NtiT is offline
Joined Sep 2012
Yep. The FC uses normal THR/RUD/AIL/ELE input instead of anything pre-mixed for helicopters.
Discussion How do you workout what Kv motor for your hull hp88 Racing Boats - Electric 16 May 27, 2012 08:50 PM
Discussion how much line do you store on your winch webdragon Thermal 17 Apr 21, 2012 07:40 PM
Question Where do you get your trim designs and how do you test them? dedStik The Builders Workshop 16 Mar 15, 2012 03:32 PM
Discussion How do you set up DR/expo on realflight 6? Dr.JJ Simulators 7 Feb 23, 2012 05:20 AM
