Old Nov 05, 2012, 06:23 AM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
just dont have an opening to close to the fan itself or it'll run louder and with less results. *ripple before the blades*
stoneenforcer is offline Find More Posts by stoneenforcer
Old Nov 05, 2012, 09:25 AM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Thanks for the tip, I have seen so meny different configurations (cuts) that I had to ask what is the best way.
super kupfer is offline Find More Posts by super kupfer
Old Nov 05, 2012, 11:56 PM
Joined Jan 2010
I did some work on the ducting today, Finished all the duct fitting to the fuse, Just need to finish my new fan bulkhead.
Old Nov 06, 2012, 12:06 AM
Joined Jan 2010
The new fan bulkhead.
Was cut from a 1mm carbon plate (Dont know how much of the inside panels I'm going to cut as I need to leave some meat for the actual fan mounts).
Tonight I'm going to laminate the 1mm carbon pc. to a 3mm aircraft ply and then tomorrow trim all the excess material.
Old Nov 06, 2012, 03:08 AM
FoxausRhens is offline
Find More Posts by FoxausRhens
FoxausRhens's Avatar
Germany, RP, Koblenz
Joined Nov 2011
Nice Work you do there, but I think the eflite Retracts you use are not strong enough for this plane. I have use them in a jepe f-86 with a weight of 3,6 kg , behind 4 flights I change the main gear because it looks that it break every moment. Now I have Jepe retracts for the main gear it is usable about 4kg.
It look much more strong then the eflite.
With regards from Germany
Alex
FoxausRhens is offline Find More Posts by FoxausRhens
Old Nov 06, 2012, 09:42 AM
Joined Jan 2010
Alex
Thanks for the compliment, I appreciate it.
In regards to the retracts, I figure since the flying weight of the Aeronaut Rafale is the same as the Eflite Habu32/F4 Phantom then the Eflite retract should work (BTW, I upgraded the trunions on the mains to alum TJ and I'm using a trailing strut on the nose gear so I'm hoping that would help).
Old Nov 06, 2012, 12:52 PM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Regarding the retracts:
If you want something stronger than the EFlite without breaking the bank you can try this ones. I will use them in a Grumania Eurofighter 1:10 that I just ordered a week ago.
http://www.wingspanretracts.com/LGM690T-95
Gamalier is offline Find More Posts by Gamalier
Old Nov 06, 2012, 01:42 PM
Joined Jan 2010
Thanks but they are too big to fit on my retract mounts + already committed to the Eflite's.
I think the Eflite's would work fine as long as I keep the weight down (below 9lbs, the upgraded trunions should help a lot.......in the worse case if I upgrade, I would go for the 46 size retracts).
Old Nov 06, 2012, 01:46 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
This jet should be impressive at 7.75lbs rtf.
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Nov 06, 2012, 01:50 PM
Joined Jan 2010
I hope she doesn't fall apart in the air.
Old Nov 06, 2012, 02:41 PM
Gamalier is offline
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
When I read 7.75 pounds.
I searched for this aircraft. Now I realized this will be a bullet with the TJ120. My best suggestion would be don't push it too hard in the maiden to avoid any problems.
Old Nov 06, 2012, 02:55 PM
High Dynamic Thrust
Joined Feb 2007
8lbs with a 120mm. awwwwwweeesome!!
the intake looks good with proper splitter mate to rotor. good job.
Old Nov 06, 2012, 04:53 PM
Gamalier is offline
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Here is the take-off picture.
Buddy - Ready Super Kupfer?
Super - Ready just let it go!
Buddy - Sure?
Super - Yeah this thing is a ROCKET!!
Old Nov 06, 2012, 06:19 PM
Joined Jan 2010
Buddy - Sure?
LOL, yaaaa something like that
Old Nov 06, 2012, 10:12 PM
jefffassbinder is offline
Find More Posts by jefffassbinder
jefffassbinder's Avatar
United States, CA, Chino Hills
Joined Jan 2011
Auw
If your bird is 7-8 pounds your airplane is going to be ballistic. I have that same fan in many of my airplanes some in excess of 25 lbs. Your airframe better be super strong as your thrust is going to be 2:1 and that should be insane. Good luck and your build technique looks great. Short take offs. But thinking about this on 12s 3.5 lbs, plus 2 lbs on fan you may not be 2:1 but very much in the 1.5:1 range which is still awesome.
jefffassbinder is offline Find More Posts by jefffassbinder
Discussion Sky e master F-18F for 120mm EDF RCPLIOTTW Electric Ducted Fan Jet Talk 761 Aug 09, 2016 10:52 PM
Yippee! 120mm EDF RED ARROW "HAWK" -by ASM jofro Electric Ducted Fan Jet Talk 7 Jul 14, 2012 12:24 AM
For Sale Aeronaut Rafale Buccaneer Driver Aircraft - Electric - Jets (FS/W) 2 Jun 21, 2012 09:38 AM
For Sale FS EDF Jet Rafale C by aeronaut MT4 Display Only Aircraft - Electric - Jets (FS/W) 2 Mar 18, 2009 04:21 PM
Aeronaut Rafale C / EJF Rafale Jedimaster65 Electric Ducted Fan Jet Talk 3 Feb 15, 2004 05:32 AM
