Old Oct 26, 2012, 01:51 AM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Hi guys.
Here are some pictures of my nose gear mount........yes I changed it again for the third time due to last minute decision to go with offset hinges instead of the stock (sorry having a blond moment).
super kupfer is offline Find More Posts by super kupfer
Old Oct 26, 2012, 02:01 AM
Joined Jan 2010
In regards to the eflite 15-25 electric retracts, the stock main wire struts are plug and play if you use TamJet trinion upgrade.
In regards to the nose gear wire strut, the stock fits the eflite like it was made for it, but I went with the stock eflite one (just preference).
Old Oct 26, 2012, 02:58 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
looking good!
stoneenforcer is offline Find More Posts by stoneenforcer
Old Oct 26, 2012, 06:39 PM
Joined Jan 2010
Originally Posted by stoneenforcer View Post
looking good!
Old Oct 26, 2012, 06:50 PM
Joined Jan 2010
More pictures of the gear retracts
Would like to get some nice struts for it instead of the ST wire ones, I should see what Tam has for a replacement nose strut but the mains may have to stay wire due to there shape/bend.
Old Oct 26, 2012, 07:01 PM
High Dynamic Thrust
Joined Feb 2007
the front wire will love to break that trunion. especially if you have to land with a lil rudder, ... the nose wheel will touch down turned and snap it. seen it a hundred times. better put on a tam strut, trailing link.
Old Oct 26, 2012, 07:02 PM
Joined Jan 2010
Next Im going to work on getting the ducts in, they fit excellent as you can tell by the pictures.
This weekend Im going to cut a new motor bulkhead (stronger one) since 120mm EDF units put out much more power now days then back when this plane was designed.
To finalize the duct install, I have to cut 5mm off the outer front lip leaving a projecting flange thats going to overlap the inside of the fuse (stay tuned for pics).
Old Oct 26, 2012, 07:05 PM
Joined Jan 2010
Too bad tam doesnt make alum front trinion gear, but you are right in regards to the trailing link.......will have to make it happen.
Men I love the color of the Kevlar, that mustardy color looks so cool
Old Oct 26, 2012, 07:16 PM
Joined Jan 2010
Can anybody tell me what they think of the TJ120 EDF unit as that may be an option I am considering for this plane.
Really need to order the fan unit.
Current unit options Im looking at:
1. TF4000 (what I had on the original Rafale I built a while back)
2. DS-94 HDT
3. TJ120
Old Oct 27, 2012, 06:09 AM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
I will go with a Stumax 100 mm on 8- 10 cells much lighter setup. You are a talented builder the the new adaptor will de a piece of cake to build.
If you have the $$ the new HST 90 mm Schubeler with~mouth ~ on 12 cells .
bidule is offline Find More Posts by bidule
Old Oct 27, 2012, 09:31 AM
shamu is offline
Find More Posts by shamu
Joined Oct 2009
2. DS-94 HDT
3. TJ120
If i had to build a new one i would go with the TF 4000 (Easy install and perfekt fitting) and a Dynamax Rotor Cut Down to 118mm from Tam :-)
shamu is offline Find More Posts by shamu
Old Oct 27, 2012, 01:53 PM
Joined Jan 2010
I prefer to stay with a 120mm size unit.
Would like to have a 12cell setup but fly with a 10cell for lower amp draw (once an a while I would put a lighter 12cell battery for some extra excitement )
Old Oct 27, 2012, 02:03 PM
Joined Jan 2010
That could be an option but If I go this route I think I have a CS120 rotor clicking around somewhere.
BTW, what trailing struts did you use on yours??? (Saw yours on a pic on your profile......love the arctic camo).
Old Oct 27, 2012, 02:04 PM
Joined Jan 2010
This is all great options but I'm still looking for your 2cents on the TJ120 unit.
Old Oct 27, 2012, 02:28 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
A Tam Jets TJ120 would be insane if your Rafale! A PnP unit produces +13 pounds of thrust. You would have better then 1=1 thrust to weight ratio! A big price tag but not so big for a RTR edf unit. That would be awesome!
BadLemon is offline Find More Posts by BadLemon
Discussion Sky e master F-18F for 120mm EDF RCPLIOTTW Electric Ducted Fan Jet Talk 760 Jun 26, 2016 01:10 PM
Yippee! 120mm EDF RED ARROW "HAWK" -by ASM jofro Electric Ducted Fan Jet Talk 7 Jul 14, 2012 12:24 AM
For Sale Aeronaut Rafale Buccaneer Driver Aircraft - Electric - Jets (FS/W) 2 Jun 21, 2012 09:38 AM
For Sale FS EDF Jet Rafale C by aeronaut MT4 Display Only Aircraft - Electric - Jets (FS/W) 2 Mar 18, 2009 04:21 PM
Aeronaut Rafale C / EJF Rafale Jedimaster65 Electric Ducted Fan Jet Talk 3 Feb 15, 2004 05:32 AM
