Old Oct 08, 2012, 06:30 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
the HDT shuby will give you a loud high pitch wine. but will put out some great performance. i think its a lil more then the 4000.
the carbon reinforcements on the intake really beef it up. looking very good so far.
stoneenforcer is offline Find More Posts by stoneenforcer
Old Oct 09, 2012, 01:55 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Anybody know where I can buy .75oz carbon fiber cloth?
super kupfer is offline Find More Posts by super kupfer
Old Oct 09, 2012, 07:55 PM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
I have bought .75 oz at Norburn. Also bought from here once.
http://www.ippnet.com/home.html
my mistake, missed the Carbon part!
172AMD is offline Find More Posts by 172AMD
Old Oct 11, 2012, 12:31 AM
Joined Jan 2010
Been working on the nose gear retract mount as you can see by the pics, only thing left is to build the last part of the mount (a plate thats going to go 90deg. from the new bulkhead and thats going to be supported by the fuse sides) but first we have to figure out how deep in the fuse the nose retract is going to have to sit since the electrics are not as low profile as the air ones.
Ones all glued I'm going to start working on the gear doors for all the legs.
Old Oct 11, 2012, 12:36 AM
Joined Jan 2010
This would still be a lot of help if anybody knows where I can buy it anywhere in Canada or the USA.
Old Oct 11, 2012, 05:42 AM
bsetiawan is offline
Find More Posts by bsetiawan
Joined Apr 2009
You can try http://www.mcmaster.com/#fabric/=jo7kpf
bsetiawan is offline Find More Posts by bsetiawan
Old Oct 11, 2012, 05:55 AM
Joined Apr 2009
A few more places that sells Carbon Fiber materials
http://www.carbonmods.co.uk/Default.aspx
http://www.acpsales.com/OnlineStore.php
http://www.solarcomposites.com/
Old Oct 11, 2012, 06:04 AM
bidule is offline
Find More Posts by bidule
jean-claude Terrettaz
bidule's Avatar
Carp, Ontario, Canada
Joined Mar 2000
http://www.cstsales.com/
bidule is offline Find More Posts by bidule
Old Oct 11, 2012, 08:43 AM
Joined Jan 2010
Thanks guys, your support is much appreciated.
Old Oct 13, 2012, 05:11 PM
Joined Jan 2010
Guys, disregard post #49 as I decided to revise the nose gear mount assembly.
Old Oct 19, 2012, 11:25 PM
Joined Jan 2010
Been waiting for some electronics to show up, Going to use:
1. Hitec HS-5087MH (Elevons, Steering, possible functional Canards dual or single servo operation).
2. Hitec HS-7115TH (Rudder).
3. TamJet's Upgrade alum. trinion gear for the eflite 15-25 retracts.
4. TamJet's main wheel brake set.
5. Jet Tronics electric Brake Valve.
6. CC 120amp Ice2 HV (ESC).
7. TamJet's anti spark.
Still waiting for my offset gear door hinges and HV rx.
Anyways, I have completed the installation of the main & nose gear mounts to the airframe (pictures will come soon), next Im going to work on renforcing the bottom of the fuse (just under the intake ducts) with some carbon cloth and after that we start working on the ducting install and the fan bulkhead (need to order the fan unit ASAP).
Old Oct 20, 2012, 11:29 AM
High Dynamic Thrust
Joined Feb 2007
15-25's? i assume your flying off pavement. no struts?
Old Oct 20, 2012, 01:47 PM
skyhawk is offline
Find More Posts by skyhawk
A-4 nut!!
skyhawk's Avatar
Vancouver B.C.
Joined Apr 2002
Super,
I go here for all my glassing needs. They have everything - glass, kevlar, carbon fiber...they're down in Burnaby.
http://www.fibertek.ca/
skyhawk is offline Find More Posts by skyhawk
Old Oct 20, 2012, 03:49 PM
Joined Jan 2010
Originally Posted by skyhawk View Post
Super,
Thanks, much appreciated:-)
Been looking for a local place for a long time.
Old Oct 20, 2012, 03:59 PM
Joined Jan 2010
Grass or pavement and no struts.....not using the stock wire gear, using the thicker ones provided in the kit.
Eflite 15-25 (3mm wire), Aeronaut Rafale stock (4mm wire).
Discussion Sky e master F-18F for 120mm EDF RCPLIOTTW Electric Ducted Fan Jet Talk 761 Aug 09, 2016 10:52 PM
Yippee! 120mm EDF RED ARROW "HAWK" -by ASM jofro Electric Ducted Fan Jet Talk 7 Jul 14, 2012 12:24 AM
For Sale Aeronaut Rafale Buccaneer Driver Aircraft - Electric - Jets (FS/W) 2 Jun 21, 2012 09:38 AM
For Sale FS EDF Jet Rafale C by aeronaut MT4 Display Only Aircraft - Electric - Jets (FS/W) 2 Mar 18, 2009 04:21 PM
Aeronaut Rafale C / EJF Rafale Jedimaster65 Electric Ducted Fan Jet Talk 3 Feb 15, 2004 05:32 AM
