Old Oct 01, 2012, 09:55 AM
Samjet's Avatar
Joined Mar 2010
Rafale 120mm to 90mm jetfan90
Hi
I am also building the Aeronaut Rafale Aramid version.
I have converted it to 90 mm with the Jetfan90. Mainly because of the sound but also because of the effeciency at high speeds.
I am using the Het 700-1200kv motor w/ 10s 4000 mah.
I have used the eflite 15-25 retracts. They fit but you need another way to make the nose gear door close than the method used in the manual. Pictures will follow...
Samjet is offline Find More Posts by Samjet
Old Oct 01, 2012, 10:01 AM
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Originally Posted by stoneenforcer View Post
being this is powered by a 120, im rather surprised by the smaller fuse size. i almost ordered this until I saw the dimensions. maybe its just me, but seems a bit small for a 120 size craft.? this 120 is about the size of this 90 powered..
http://www.hobby-lobby.com/eurofight...34375_prd1.htm
the overall FRAME weight is about the same or heavier for the foam verison as it has way more servos, lights ect..... minus the batts.
Yes, it's a very very light airframe, the glass/Kevlar is very thin (about 1mm).
With today's EDF technology I should be able to make this baby go really good.
super kupfer is offline Find More Posts by super kupfer
Old Oct 01, 2012, 10:04 AM
Joined Jan 2010
Originally Posted by Samjet View Post
Hi
Would love to see pictures of the nose gear installation and 90mm conversion.
Old Oct 01, 2012, 10:44 AM
EDF Crazy's Avatar
UK
Joined Oct 2007
Originally Posted by super kupfer View Post
Yes, it is the Kevlar one.
My original I built stock but have noticed that some people have moded to have plugin wings, rudder, even functional canards.
I'm defiantly adding rudder, not sure about the plugin wings and maybe functional canards just for kicks.
i wouldnt change the the wings to be plugin, it could make the build process to complicated. Im sure Herb tried one with functional canards and it made no difference in the way it flew. also you cant have the canard on a common shaft because the root edges of the canards are not parallel, and the shaft would be in the way for putting batteries in too. A rudder would be nice tho.
EDF Crazy is offline Find More Posts by EDF Crazy
Old Oct 01, 2012, 11:11 AM
Joined Jan 2010
What does the full size Rafale uses the canards for? Is it pitch & roll or pitch only or brake.
Old Oct 01, 2012, 03:31 PM
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
they make for a tighter turning radius in any direction. ive flown with and without them on my euro and it does make a difference when your doing high alpha and tight high G turns. it helps me when pulling into hovering and very high alpha manuevers
stoneenforcer is offline Find More Posts by stoneenforcer
Old Oct 01, 2012, 03:52 PM
Neil Jarvis
Neil Guildford's Avatar
Surrey U.K.
Joined Sep 2004
I've got one of these in my loft....I like the idea of plug in wings.
Neil Guildford is offline Find More Posts by Neil Guildford
Old Oct 01, 2012, 05:40 PM
Joined Jan 2010
I found these pics on one of the build threads noted on post #7.
Old Oct 01, 2012, 09:24 PM
High Dynamic Thrust
Joined Feb 2007
the wing span on this jet is only about 36". you think its worth the effort and added weight of removable wings?
if you do build them, the habu32 uses a good guide mount , i think would be suitable for this euro.
Old Oct 01, 2012, 11:10 PM
Joined Jan 2010
Personally I don't know if I would do the mod for the removable wings, but the pictures are for those who are interested.
Old Oct 02, 2012, 12:52 AM
Joined Jan 2010
I started work today by cutting new main gear mounts (Only need to drill the holes for the retracts), I cut it out of solid aircraft ply.
Next I will tac glue the assembly using CA and dry fit it in the fuse, if all looks good I will epoxy/hysol the entire assembly together getting it ready to final gluing in the fuse.
I would like to see if I can find some struts that would work in this aircraft, will have to look around.
Also I intend to upgrade the retracts trinion to TamJets alum. one, will have to make an order from him soon as I need other things from him as well.
Old Oct 02, 2012, 03:17 PM
Joined Sep 2012
If you build it, that son of yours in the picture could fly it! Just don't wait until he can't fit in!
Eli Lipschitz is offline Find More Posts by Eli Lipschitz
Reply With Quote  (Disabled)
Old Oct 02, 2012, 08:25 PM
Joined Jan 2010
You mean like that.............that's when he was much smaller
Old Oct 03, 2012, 03:34 PM
Samjet's Avatar
Joined Mar 2010
Hello
This is the mounting I have made for the jetfan 90mm. I am working on a balsa duct to combine with the existing glasfiber duct.
Description: mounting for a 90 mm fan
Old Oct 04, 2012, 06:12 PM
Joined Jan 2010
Well, I got the bulkheads/main gear assembly all glued with CA (going to touch it up with epoxy/hysol), I also test fitted in the fuse and all looks great.
Next, I would be gluing assembly to the fuse, I would like to do a better job on it then I did last time when I used Hysol, it was/got messy......any tips????
Discussion Sky e master F-18F for 120mm EDF RCPLIOTTW Electric Ducted Fan Jet Talk 480 Today 06:50 PM
Yippee! 120mm EDF RED ARROW "HAWK" -by ASM jofro Electric Ducted Fan Jet Talk 7 Jul 14, 2012 12:24 AM
For Sale Aeronaut Rafale Buccaneer Driver Aircraft - Electric - Jets (FS/W) 2 Jun 21, 2012 09:38 AM
For Sale FS EDF Jet Rafale C by aeronaut MT4 Display Only Aircraft - Electric - Jets (FS/W) 2 Mar 18, 2009 04:21 PM
Aeronaut Rafale C / EJF Rafale Jedimaster65 Electric Ducted Fan Jet Talk 3 Feb 15, 2004 05:32 AM
