Espritmodel.com Heli Air
Old Dec 27, 2012, 02:20 PM
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
glassed. retracts mounted. dry fitted vert stab. several degrees of alpha for self rise take off
still need to do a ton of sanding, create radio and battery tray, enforce front lg mount, build canopy latch and mount. need one more pilot to. then.... prime and isaeli desert camo paint.
stoneenforcer is offline Find More Posts by stoneenforcer
Old Dec 27, 2012, 07:25 PM
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Looks good and would be interested to see how this mirage 2000 would look with Israeli camouflage (too bad it's not a mirage 3)
super kupfer is online now Find More Posts by super kupfer
Old Dec 28, 2012, 07:13 AM
High Dynamic Thrust
Joined Feb 2007
i wanted a 3 so bad, but settled for the 2000. really there is no option for 90-120 size mirages. excluding a jhh, which is tons more work then then this one.
Old Dec 28, 2012, 04:20 PM
Joined Jan 2010
The only thing I'm not crazy about with the JHH mirage is the oversize intakes, the real mirage had small and slick intakes like the rest of the plane.
The mirage 3 in real life looks soooo sexy
Personally I would love to find a Mirage 3 kit that has a good scale line but on another note I would love to find a Byron Kfir kit (another one that's on my bucket list to build one day).
Old Dec 28, 2012, 04:47 PM
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
what type of glue did you use to glue the wooden frames inside the fueselage? and what type of glue do you use to glue wood to wood? i dont have a lot of balsa & composite building experience. i was thinking of using wood glue for wood to wood glueing, and epoxy, for wood to fiberglass. thanks. cant wait to see you maiden.
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Dec 28, 2012, 07:24 PM
Joined Jan 2010
I used hysol glue for everything, but if cost is a problem for you then use epoxy.
Use 30min epoxy for wood to wood, as for wood to glass (like the bulkheads or gear sub-assy) I would glue using a mix of resin and micro balloon (tip: use a syringe to apply the mix for better control).
BTW, prior to gluing wood to composite, rough area with sand paper and clean with alcohol, it's very important.
I hope this will help you.
Old Dec 28, 2012, 08:43 PM
gchrisgo34's Avatar
Joined Nov 2010
very helpfull, thanks
Old Dec 28, 2012, 08:51 PM
Joined Jan 2010
So last night I got the vertical fin on.
The fin is not very stiff and got a bit of flex to it all due to no bulkheads in the rear fuse and the composite being so thin, Going to have to add some carbon to the inside of the rear fuse to stiffen things up.
She looks great, I have a bit more filling and sanding to get things perfect to my satisfaction and then it's paint.
Old Jan 12, 2013, 12:41 AM
Joined Jan 2010
Hi, guys.
I'm a little bit behind as I spent most of the holiday smoking churchill's and drinking Johnnie Walker.
Anyways, I finally finished with the priming with a few touch ups to go over.
Color is coming pretty soon.
Old Jan 12, 2013, 12:44 AM
Joined Jan 2010
BTW, any ideas of how to get paint into the ducts????
Wish I had one of those "honey I shrunk the kids" machines.
Old Jan 12, 2013, 07:59 AM
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Originally Posted by super kupfer View Post
Hi, guys.
There should be a like button for this statement
Plane looks great!
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Jan 20, 2013, 12:57 PM
High Dynamic Thrust
Joined Feb 2007
SK, whats the latest?? SHe flying yet??
Old Jan 20, 2013, 04:53 PM
Joined Jan 2010
Still working on the finishing process, painting is time consuming (I have to admitt that I took a bit of a break to work on other things).
Should have pics next week hopefully once I feel satisfied with the painting finish.
Old Jan 21, 2013, 07:48 AM
High Dynamic Thrust
Joined Feb 2007
same here for my mirage. im gonna prime it soon and then do the maiden before painting. Still got a few small things to get situated inside the fuse first.
looking forward to see your paint scheme
Old Jan 21, 2013, 10:15 AM
Joined Jan 2010
I decided to go with the orange/blue/white scheme as in post #198, that is also why its taking extra time.
Discussion Sky e master F-18F for 120mm EDF RCPLIOTTW Electric Ducted Fan Jet Talk 480 Yesterday 06:50 PM
Yippee! 120mm EDF RED ARROW "HAWK" -by ASM jofro Electric Ducted Fan Jet Talk 7 Jul 14, 2012 12:24 AM
For Sale Aeronaut Rafale Buccaneer Driver Aircraft - Electric - Jets (FS/W) 2 Jun 21, 2012 09:38 AM
For Sale FS EDF Jet Rafale C by aeronaut MT4 Display Only Aircraft - Electric - Jets (FS/W) 2 Mar 18, 2009 04:21 PM
Aeronaut Rafale C / EJF Rafale Jedimaster65 Electric Ducted Fan Jet Talk 3 Feb 15, 2004 05:32 AM
