Old Dec 13, 2012, 08:33 AM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
SK, that laminate on the under wing joint is pointless and provides very little to no added strength as a thin laminate when used in that fashion, especially after sanding. Wrong geometry of application.
shes looking really nice and I love the carbon you added to the intake. nice touch. I just did carbon intakes and ducting on my mirage 2000 last night. still have hours of building...
cheers,
stoneenforcer is offline Find More Posts by stoneenforcer
Old Dec 13, 2012, 09:57 AM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
cheers,
You are right, After sanding this morning I lost about 30% of it.
Looks like I'm going to add another two layers of 1K (it's the first time I use 1K for this type of application as I normally use a 3K cloth).
Live & Learn
super kupfer is offline Find More Posts by super kupfer
Old Dec 13, 2012, 03:25 PM
High Dynamic Thrust
Joined Feb 2007
i wouldnt bother adding another lam. it still wont serve a purpose and will only cause cosmetic flaws. That is a flex point and will continue to do so with or without your lamination(s).
now, laying that lam along the spar would make a difference!
Old Dec 13, 2012, 04:37 PM
Joined Jan 2010
To tell you the truth, I don't even know if I should have put any cloth on as last night I supported both sides of the wing and put 25lbs weight on the fuse and the wing was solid with only some flex.
I guess I'm just trying to somewhat follow the instruction manual.
BTW, I got carbon cloth inside the wing panel right at the root of each spar (I will try to take a pic once I open the servo bays in the wing).
Old Dec 13, 2012, 11:51 PM
Joined Jan 2010
Added another 2 layers of 1K cloth and it's waaaay better (will take a picture tomorrow after some sanding).
Old Dec 14, 2012, 08:01 AM
High Dynamic Thrust
Joined Feb 2007
im using 8gram carbon mat tissue, multi layered on my mirage intake splitters, internal lams ect....
1/2oz glass on fuse and wings.
Old Dec 14, 2012, 09:21 AM
Joined Jan 2010
What do you think about carbon tissue? never used it before.
Old Dec 14, 2012, 07:28 PM
High Dynamic Thrust
Joined Feb 2007
8gram is very thin tissue. its a matt format which is tougher to soak with resin. the fibers are held together with some sort of binder, but break loose after a few brush strokes. its tougher to use this material on tight contours and curves. best for flat surfaces. I'm using it to lam battery tray, all wood parts, ect...
Old Dec 15, 2012, 12:46 AM
Joined Jan 2010
As far as I see it, it looks good to me, Im going to put one more coat of resin followed by some sanding and we are ready for filler primer.
Old Dec 15, 2012, 05:05 AM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Looks good to me - can't hurt right
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Dec 15, 2012, 09:52 AM
gchrisgo34 is offline
Find More Posts by gchrisgo34
gchrisgo34's Avatar
United States, GA, Jonesboro
Joined Nov 2010
hello sir, awesome job building your rafale!! i love the looks of that jet. been eyeballing the 70mm foamie that HK sells. im currently building the ys-11 HK sells. its my first fiberglass airframe. im also having some difficulty figuring out how to mount the nose wheel. im planning to fallow your design, and im wondering how you were able to cut the wood form, that matches the inside of the fueselage? the complex curves, how did you get the wood mount to match so nicely? you're doing an excellent job too, thanks
gchrisgo34 is offline Find More Posts by gchrisgo34
Old Dec 15, 2012, 10:03 AM
gchrisgo34's Avatar
Joined Nov 2010
heres what im working on. as you can see, im dealing with a nose gear problem, trying to figure out how to mount it. i plan to do something like you've done. thanks
Old Dec 15, 2012, 12:42 PM
Joined Jan 2010
Originally there was a bulkhead there which I just extended, so it was easy for me to do this mod, what I would suggest for you to do is to cut it out of cardboard as it's a lot easier to trim and find the correct fit, once you got that figured out then just use it as a pattern to cut one out of ply or whatever you choose to use for material.
That's what I have done in the past and it works great and saves time (you can also use the wire technic where you bend it to the contour and use it to trace a line on your building material).
Old Dec 15, 2012, 06:36 PM
gchrisgo34's Avatar
Joined Nov 2010
thanks sir, thats some great advice. im sure ill be using it soon. you're doing a great job on your build, & ill be keeping an eye on it. looking forward to seeing the first flight.
Old Dec 16, 2012, 11:55 PM
Joined Jan 2010
Last night did 3 layers of 1K carbon cloth on the top side Fuse/Wing seem and today did some sanding followed by a final coat of zpoxy resin mixed with some carbon powder (helps fill all the small little pin holes).
Tomorrow, we start sanding the entire front fuse (Getting ahead start on the finishing), once finished we will add the canard wings and canopy attachment (Then we will be ready for some primer and paint).
Discussion Sky e master F-18F for 120mm EDF RCPLIOTTW Electric Ducted Fan Jet Talk 760 Yesterday 01:10 PM
Yippee! 120mm EDF RED ARROW "HAWK" -by ASM jofro Electric Ducted Fan Jet Talk 7 Jul 14, 2012 12:24 AM
For Sale Aeronaut Rafale Buccaneer Driver Aircraft - Electric - Jets (FS/W) 2 Jun 21, 2012 09:38 AM
For Sale FS EDF Jet Rafale C by aeronaut MT4 Display Only Aircraft - Electric - Jets (FS/W) 2 Mar 18, 2009 04:21 PM
Aeronaut Rafale C / EJF Rafale Jedimaster65 Electric Ducted Fan Jet Talk 3 Feb 15, 2004 05:32 AM
