Old Nov 29, 2012, 10:48 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
Just bench ran the TJ120, this thing has insane thrust and sounds sweeeeeeeeet.
After that session I have a lot of crazy things running through my mind , the thought that stands the most in my head is my TJ120 in a brand new BVM Electra (don't tell my wife).
I wonder if you need to mod the intakes on the Electra in order to marry the TJ120, how much mod do you have to do?
super kupfer is offline Find More Posts by super kupfer
Old Nov 29, 2012, 11:23 PM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Send Tam a PM or email. He will have the best answer to your questions regarding the Electra. I believe he has done some work with them. Regarding your wife "is easier to ask for forgiveness than for permission" like the old saying says!
Gamalier is offline Find More Posts by Gamalier
Old Nov 29, 2012, 11:26 PM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
"I wonder if you need to mod the intakes on the Electra in order to marry the TJ120, how much mod do you have to do? "
I don't know! But I do think You should get one.
172AMD is offline Find More Posts by 172AMD
Old Nov 29, 2012, 11:57 PM
Joined Jan 2010
I personally don't think she would mind as long as I first finish my YA F-16 but that is currently getting delayed due to this build (will have to get back on it as I'm about half way on the 16).
Old Nov 30, 2012, 12:00 AM
Joined Jan 2010
Do you have one???
Old Nov 30, 2012, 12:32 AM
eazyp2 is offline
Find More Posts by eazyp2
United States, OH, Columbus
Joined Oct 2007
It will need to be modified' I just fitted the tj120 to my bvm t33 in the shop /
eazyp2 is offline Find More Posts by eazyp2
Old Nov 30, 2012, 12:36 PM
172AMD is offline
Joined Aug 2006
Originally Posted by super kupfer View Post
Do you have one???
No.
Old Dec 01, 2012, 06:37 PM
Joined Jan 2010
Test fitting the canard wings and they look awesome on this plane (will have to start working on them).
Old Dec 01, 2012, 06:46 PM
Joined Jan 2010
Picture #1: You can see the 5mm projecting flange overlap of the intake duct that is glued to the inside of the fuse (a bit hard to see with the hysol).
Picture #2: I re-enforced the flange with two layers of 1K carbon cloth.
Old Dec 01, 2012, 06:49 PM
Joined Jan 2010
I decided to ditch all the hardware for the nose steering servo mount and decided to take a simpler approche (will glue fasten all tonight).
Old Dec 02, 2012, 07:49 AM
Downwind3Zero is offline
Find More Posts by Downwind3Zero
It's like an addiction!
Downwind3Zero's Avatar
NY, Rochester
Joined Oct 2003
Great build man!!
Chris
Downwind3Zero is offline Find More Posts by Downwind3Zero
Old Dec 02, 2012, 12:07 PM
Joined Jan 2010
Originally Posted by Downwind3Zero View Post
Great build man!!
Chris
Much appreciate
Old Dec 12, 2012, 09:28 PM
Joined Jan 2010
Had the in-laws for a week and a half for a visit and my sons 2nd. birthday so things were on hold.
Anyways now that everybody has left, its time to get back to work.
I started by gluing the mounting blocks that secure the rear of the fuse to the front fuse (still need to make and glue the fan mount and create a glue fillet on this side of the bolckhead).
Old Dec 12, 2012, 09:36 PM
Joined Jan 2010
Started working on the intake lips, I ditched the fiberglass lips as I did on my first build as I like this way better due to simplicity (created a lip using zpoxy and micro baloon), it will still need to be shaped once dry.
I also glued the front bulkhead as you can see on the first picture.
Old Dec 12, 2012, 09:41 PM
Joined Jan 2010
Re-enforced the wing/fuse seam using one layer of 1K carbon (Surprizingly the wing is a lot stronger then I thought it would be, and thats before I layed the carbon cloth).
I still may lay another layer.
Discussion Sky e master F-18F for 120mm EDF RCPLIOTTW Electric Ducted Fan Jet Talk 755 Jun 02, 2015 08:42 AM
Yippee! 120mm EDF RED ARROW "HAWK" -by ASM jofro Electric Ducted Fan Jet Talk 7 Jul 14, 2012 12:24 AM
For Sale Aeronaut Rafale Buccaneer Driver Aircraft - Electric - Jets (FS/W) 2 Jun 21, 2012 09:38 AM
For Sale FS EDF Jet Rafale C by aeronaut MT4 Display Only Aircraft - Electric - Jets (FS/W) 2 Mar 18, 2009 04:21 PM
Aeronaut Rafale C / EJF Rafale Jedimaster65 Electric Ducted Fan Jet Talk 3 Feb 15, 2004 05:32 AM
