Old Nov 14, 2012, 11:43 AM
172AMD is offline
Find More Posts by 172AMD
Richmond B.C. Canada
Joined Aug 2006
Originally Posted by super kupfer View Post
Not on the maiden but they do have about 500' of a nice cut runway (as good as a golf fairway).
Can't say at this point as the biggest problem in Ridge is the limited airspace.
Been flying my 8lb Habu 32 at Ridge this year. Airspace is not a problem for landing or takeoff. The limited airspace does limit the speeds though!
Even at 10lbs your Rafale will have a lower wing load.
Nice work so far, look fwd to video also.
172AMD is offline Find More Posts by 172AMD
Old Nov 14, 2012, 02:04 PM
super kupfer is offline
Find More Posts by super kupfer
Anything that gives me a High
super kupfer's Avatar
Canada, BC, Richmond
Joined Jan 2010
I guess that may fit the bill as I'm a bit concern whether the airframe would handle a full throttle flight.
super kupfer is offline Find More Posts by super kupfer
Old Nov 14, 2012, 06:10 PM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
this is one of those cicumstances where a g load meter would be nice to play with
stoneenforcer is offline Find More Posts by stoneenforcer
Old Nov 14, 2012, 11:34 PM
Joined Jan 2010
LOL, no time to look at a meter while flying.
Old Nov 15, 2012, 03:47 PM
BadLemon is offline
Find More Posts by BadLemon
Just having fun before I die!
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
sk
You should send an email to Aeronaut and see if the air frame can handle your power setup.
BadLemon is offline Find More Posts by BadLemon
Old Nov 15, 2012, 05:59 PM
Joined Jan 2010
Originally Posted by BadLemon View Post
sk
I think I'm just going to take it easy at first and not push it too hard.
Old Nov 15, 2012, 07:32 PM
BadLemon is offline
BadLemon's Avatar
DeKalb,IL
Joined Dec 2008
They made have a couple of suggestions on areas to reinforce. I really like what you have done so far.
Old Nov 15, 2012, 08:52 PM
Joined Jan 2010
So far the only reinforcement I have done to the actual shell is laying some 1k carbon cloth on the bottom of the fuse as most people have done (just under the
ducting, that stiffened the fuse), still need to figure out the wings as there is no wing spare that goes through the fuse, the wings have balsa reinforced glass spares, the wings get glued to the side of the fuse like most het jets and then there's two layers of glass cloth and resin to reinforce the joint.
Old Nov 18, 2012, 03:24 PM
Joined Jan 2010
Pictures to reference post #127 (should give you some idea).
Old Nov 18, 2012, 08:19 PM
Double E is offline
Find More Posts by Double E
Double E's Avatar
Atlanta, GA
Joined Mar 2009
Be sure to drill some small holes through the carbon So your epoxy can flow into them and create a stronger bond when cured. It lets the epoxy act like a rivet.
Double E is offline Find More Posts by Double E
Old Nov 18, 2012, 08:47 PM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
You can install a wing tube. It will be tricky but its possible. You can cut a small hole thru the carbon fiber. Then get an aluminum tube and cut notches in one of the ends to use it as a drill. Set the wing equally spaced to allow to the tube to be centered. You can build support wedges out of balsa or foam (just like a shuck). The only part you might not like is the removing of a little slice of the wing to allow the cutting of the inner part of the foam inside the wing.
Gamalier is offline Find More Posts by Gamalier
Old Nov 18, 2012, 10:26 PM
Joined Jan 2010
Hi, that's a good idea, Thanks.
Old Nov 18, 2012, 10:31 PM
Joined Jan 2010
I was thinking about it but each of the wing panels are only 12.5" long (stubby little wings).
Old Nov 19, 2012, 05:10 AM
Gamalier is offline
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Either use a shorter tube or you can use 1/2 or 3/8 (13 or 10mm) carbon rods and install them as anti rotation pins. 4" in the front 8" in the back. They will give you extra strength and you can use regular drills to make the holes.
Discussion Sky e master F-18F for 120mm EDF RCPLIOTTW Electric Ducted Fan Jet Talk 758 Jun 23, 2016 10:09 AM
Yippee! 120mm EDF RED ARROW "HAWK" -by ASM jofro Electric Ducted Fan Jet Talk 7 Jul 14, 2012 12:24 AM
For Sale Aeronaut Rafale Buccaneer Driver Aircraft - Electric - Jets (FS/W) 2 Jun 21, 2012 09:38 AM
For Sale FS EDF Jet Rafale C by aeronaut MT4 Display Only Aircraft - Electric - Jets (FS/W) 2 Mar 18, 2009 04:21 PM
Aeronaut Rafale C / EJF Rafale Jedimaster65 Electric Ducted Fan Jet Talk 3 Feb 15, 2004 05:32 AM
