Old Feb 08, 2013, 07:14 PM
sparks is offline
Find More Posts by sparks
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Seems a waste to have such a nice slot in the wing and not use it, I pushed a strip of light ply in the slot, marked it flush with the wing and cut it. Pushed it back in and used thin CA to lock it down. Now my wings will not flex like the plane in the video does during aerobatics. Note that I had to extend the slot to tie it into the main spar.
sparks is offline Find More Posts by sparks
Old Feb 08, 2013, 07:20 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
I used all the same servos on the model, no reversing required.
All it takes is to reposition the servo to the proper orientation , mark the foam and cut.
Example: the ailerons are correct on this model both servo arms facing outboard. This will give you opposite control movement.
On the flaps they have the same arrangement requiring reversal.
Arranging the servo arms to face the same direction will make the travel the same direction. (this modification was done on the elevator too. )
Pain in the backside?
Perhaps but I have stronger smoother servos i can trust and don't have to worry about stripping gears in a special servo because I bumped a door way.
I don't see any advantage to designing a model that requires reversed servos . . .wait, Think it could be that they make money selling "special" electronics?
Old Feb 08, 2013, 07:26 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
I went a little overkill on the motors but I have used motors like the stock type on other models and either had bearing problems or simply smoked the windings.
look at your motor windings now, they won't have that shiny copper look after several flights.
To Identify the firewall location I assembled the motor and slid it into the cowl and marked its depth on the nacelle.
This location was measured from the mark to the aft end of the factory slot.
A line was drawn parallel to the factory slot and a rotary tool was used to cut the slot slightly wider than the firewall material.
The wing was held upright while the firewalls were tac bonded with epoxy.
then a better bond was made when it set up.
The black plastic plates were used to make sure the thrust lines were the same.
BTW- the factory setting was 1.2 degrees nose down and left to right was zero.
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
more tomorrow?
Old Feb 08, 2013, 07:52 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Originally Posted by sparks View Post
more tomorrow?
Thanks for posting.....very good info, as I plan on ordering the "kit" version and supplying my own motors and electrics. BTW, as there is no offset, left to right, are you using counter rotating props?
bamaguy is offline Find More Posts by bamaguy
Old Feb 08, 2013, 08:41 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
I have a bit of prop testing to do .
I have three sets of three blade props to choose from and only one set is available as counter rotating .
The down side is going counter rotating will require me to trash a spinner. ( stock props only turn one direction. )
I may have to shop for a set of spinners to try it out.
Old Feb 08, 2013, 09:42 PM
sparkie624 is offline
Find More Posts by sparkie624
sparkie624's Avatar
Roanoke, VA
Joined Sep 2008
Since I'm clumsy and know it, I decided to attach the winglets with rare earth magnets they are stored where the battery goes. I don't know if they will stay on in flight but what I do know is I will eventually break them off. I'll let you know how it works out.
Great idea... Wish I had thought of it. Let us know how it works out.
sparkie624 is offline Find More Posts by sparkie624
Old Feb 09, 2013, 10:18 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
steering
Tiny servos for steering may work on a smooth surface but I'm flying off grass and don't want to be grounded because the plastic gears stripped.
Besides, the servo being off center is sure to keep the gear from going into the gear well straight and could hang up on the way out.
I pierced holes with a sharpened piece of piano wire in the gear bay and exited just below the battery tray. ( leave the wire in place 4 now)
The next holes went from the corner of the wing saddle to the bottom of the battery tray. watch your angles.
A razor was used to cut a slot through the wing saddle in the direction of the gear servo.
Sullivian tubing was threaded through the holes using the piano wire as a guide.
The photo shows a cable but the stiffness keeps turning the gear as it goes in just as I suspected it would with an offset servo. . I have switched to a strong nylon thread and it works great every time.
May look like allot of trouble but it is dependable now and if I need to adjust the steering I can do it without flipping it on its back at the field.
Last edited by sparks; Feb 09, 2013 at 10:25 AM. Reason: Photos dident go through.
Old Feb 09, 2013, 10:47 AM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
I hear you loud and clear on that point! Even tho our field has paved runway, I use 11 or 13 gram metal geared servos for steer servos and use DENTAL FLOSS as steer cables. That stuff will not stretch as nylon can and thin CA makes the knots permanent!
Old Feb 09, 2013, 12:45 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
great tip!
I love these threads, I've been at this for 22 years and have never tried Dental floss .
I was thinking that the stretch I get from nylon acts as a servo saver and tension regulator but it does cause a slop feel in the steering so I guess the regulator myth is Busted.
Love the avatar! had to show my wife and she laughed too.
Old Feb 09, 2013, 01:24 PM
sparkie624's Avatar
Roanoke, VA
Joined Sep 2008
Nice idea.. Just added it to my Grocery List... Thanks.
Old Feb 09, 2013, 08:46 PM
gewiens is offline
Find More Posts by gewiens
Look Up!
gewiens's Avatar
Canada, MB, Niverville
Joined Apr 2008
You guys are making me sick. When the heck are these coming back into stock? They told me end of January but thats since past.
gewiens is offline Find More Posts by gewiens
Old Feb 09, 2013, 08:59 PM
Allelectric is offline
Find More Posts by Allelectric
Allelectric's Avatar
Sedona, Arizona
Joined Nov 2006
They've been telling me "two weeks" for the past three months! LOL!
Allelectric is offline Find More Posts by Allelectric
Old Feb 09, 2013, 09:59 PM
gewiens is offline
Look Up!
gewiens's Avatar
Joined Apr 2008
Got so impatient that i bought a dynam 310 to tie me over till this shipment comes from a different universe.
Old Feb 10, 2013, 12:11 PM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
pilots
Obviously are not all in agreement on the pilots, I've seen that some say they look great or at least the guy in the video liked them.
I think they look like twin, teen, pot heads and little ones at that; they can barely see over the glare shield.
What's with the black leather helmets and goggles?
Must be recycled WW1 pilots from another kit.
Question Nitroplanes Aerosky 55" Extra and Sbach rcninja 3D Foamies 220 Jul 16, 2014 07:30 AM
Discussion AeroSky B60 Tim B. Electric Plane Talk 100 Jun 19, 2014 03:45 PM
Discussion FLY FLY Beechcraft Duke B60 Hollywood2979 Foamies (Kits) 0 Jul 16, 2012 01:51 PM
For Sale FS/FT Keurig B60 Special Edition...Used only 5 times Bombo Non R/C Items (FS/W) 1 Feb 21, 2011 12:58 PM
For Sale Keurig B60 Special Edition Gourmet Single-Cup Home-Brewing System thannamhbfp Non R/C Items (FS/W) 1 Dec 18, 2009 03:53 AM
