Old Nov 15, 2012, 08:04 AM
sparkie624 is offline
Find More Posts by sparkie624
sparkie624's Avatar
Roanoke, VA
Joined Sep 2008
Originally Posted by crash74 View Post
I can only find a servo reverser. Where can I get a y reverser? Thx also I have no choice but to remove the tail. The y to the two elevator servos are back there. As for messing around devaluing my new hs82mg servos. No thx ill stick to a reverser and save the butchers work for a much cheaper servo. Lol p.s the flaps are the same way!! What were they thinking when they designed this bird??
Have never seen a "Y" Reverser, but just put a Reverser inline with a Y and you have the same thing.
sparkie624 is offline Find More Posts by sparkie624
Old Nov 15, 2012, 05:29 PM
crash74 is online now
Find More Posts by crash74
Addicted to Twins
crash74's Avatar
United States, AZ, Maricopa
Joined Jul 2011
what crap!!! the plans just suck...why even include them??? Doesn't say anything about reversed servos or does it state anywhere the recommended throws?? EVERY set of plane has a recommended seting for throws!!! what are you guys set at??? 1/4" up/down elevator and or ailerons????
crash74 is online now Find More Posts by crash74
Old Nov 15, 2012, 06:25 PM
Cubcrazy is online now
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
I set all my planes to 100% servo travel and then adjust how much my thumbs move. Setting manufacturer recommended throws is over-rated just as manufacturer CG is often unreliable. Dual rates? Expo? Humbug...
Flaps are a different story. I like to use multiple position flaps, and I usually set them up based on the full size counterpart, then tweak it if I don't like the performance. I have never seen a plane with opposed servos on flaps that didnt require a reversed servo on one side. Only way around it is to mount both servos in the same direction, or get a reverser, or open it up and reverse a servo.
-Cub
Cubcrazy is online now Find More Posts by Cubcrazy
Latest blog entry: Warning!! Graphic images of...
Old Nov 15, 2012, 07:20 PM
F-86FLIER4LIFE is offline
Find More Posts by F-86FLIER4LIFE
Landin' On The Canopy BAD
F-86FLIER4LIFE's Avatar
Lee's Summit, MO
-Cub
Or program your radio for it, in which case it will compensate when you plug in your flaps into two seperate channels. just sayin, love this thread!
F-86FLIER4LIFE is offline Find More Posts by F-86FLIER4LIFE
Old Nov 15, 2012, 08:30 PM
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Dammit..you got me..the ol' program a mix method.
-Cub
Old Nov 15, 2012, 10:39 PM
sparkie624's Avatar
Roanoke, VA
Joined Sep 2008
-Cub
Pretty much the same here.. except I used 125% on high and 75% on low rates. For the flaps I set 2 positions. 10 deg and 45 deg, measured with an inclineometer. They are cheap at Harbor Freight.
Old Nov 15, 2012, 10:40 PM
sparkie624's Avatar
Roanoke, VA
Joined Sep 2008
-Cub
More than one way to skin a cat.
Old Nov 16, 2012, 08:23 AM
Addicted to Twins
crash74's Avatar
Joined Jul 2011
The main reason I like to follow sudjest end guidelines for throws is that I have an edge 540 and the sudjest end throws were 1/4 up or down on the ailerons. I thought that wasn't enough throw so I made it full up and down. After takeoff with the slightest left aileron I did a roll 3' off the ground. I crapped my pants and after that I was told to use suggested throws as a starting point and adjust from there. So I do!,, maybe it does end matter with these cheap foamies but it sure does on sport / 3D planes.
Old Nov 16, 2012, 08:41 AM
sparkie624's Avatar
Roanoke, VA
Joined Sep 2008
In reference to my nose gear steering problem (where the nose steering wires either slipped or stretched), I have not instituted a fix that I have not installed yet, but went to my hobby shop and everything I found was too stiff. I went to HOBBY LOBBY craft store and got some silver wire and going to try to make my own and solder it so it cannot slip. Will keep everyone advised on this part of the project.
Old Nov 16, 2012, 09:12 AM
Addicted to Twins
crash74's Avatar
Joined Jul 2011
what about just using a "GOOD" pull pull system. DU-BRO has pull pull kits! just shorten it...ALOT!! same concept but better quality. also as for my nose steering I'm gonna try to Cris-cross the wires. when on the bigger planes when the wires run to the rear, its better to do that!!
Old Nov 16, 2012, 09:48 AM
sparkie624's Avatar
Roanoke, VA
Joined Sep 2008
My hobby store did not have it in stock... I will look for it on the internet.
Old Nov 16, 2012, 09:51 AM
sparkie624's Avatar
Roanoke, VA
Joined Sep 2008
Looked at the Dubro site, do you have a Part Number for it by chance?
Old Nov 16, 2012, 10:51 AM
Addicted to Twins
crash74's Avatar
Joined Jul 2011
the one I have is cat. no. 517 it is a 2-56 pull-pull system..
this would work better for this plane
this is what I have on hand good luck.
Old Nov 16, 2012, 10:52 AM
Addicted to Twins
crash74's Avatar
Joined Jul 2011
I have been doing some reading on the servo reversers... I get ALOT of mixed reviews.... some say NO causes fire...alot of speed issues...etc.... So i bit the bullet and took plane apart flipped servos and moved the controle horns!!
Old Nov 16, 2012, 08:28 PM
Addicted to Twins
crash74's Avatar
Joined Jul 2011
She is almost ready...lol I forgot to hook up front steering!
Duke B60 Test Video (1 min 49 sec)
Question Nitroplanes Aerosky 55" Extra and Sbach rcninja 3D Foamies 220 Jul 16, 2014 07:30 AM
Discussion AeroSky B60 Tim B. Electric Plane Talk 100 Jun 19, 2014 03:45 PM
Discussion FLY FLY Beechcraft Duke B60 Hollywood2979 Foamies (Kits) 0 Jul 16, 2012 01:51 PM
For Sale FS/FT Keurig B60 Special Edition...Used only 5 times Bombo Non R/C Items (FS/W) 1 Feb 21, 2011 12:58 PM
For Sale Keurig B60 Special Edition Gourmet Single-Cup Home-Brewing System thannamhbfp Non R/C Items (FS/W) 1 Dec 18, 2009 03:53 AM
